I love this place… thank you. will have a blast in the morning.
While @firstof9 workaround will give you the right output, there is a more convenient way. If you use bruh’s code for the multisensor, there is an option to directly acquire data in C or F, instead of doing a conversion later on
For° F (as it is already in bruh’s code)
float newTempValue = dht.readTemperature(true);
For °C (simply remove the true)
float newTempValue = dht.readTemperature();
Then the value will be directly acquired in °C, and there is no need to convert it.
Hi, can we hook up air quality sensor with it?
something like this:
You’d need to modify the code to do so and make sure you had enough pins available to support the device.
can you please help me to modify the the code?
Give this a try:
https://raw.githubusercontent.com/firstof9/ESP-MQTT-JSON-Multisensor/MQ-support/bruh_mqtt_multisensor_github/bruh_mqtt_multisensor_github.ino
MQ135 Library:
Have anyone had truble with the USB cables when connecting to the ESP-8266?
I orderd 10 new cards, did try 3 But no luck
only troubles I have is when I connect the sensors on the wrong pins
Do i need to connect the sensors before i can flash IT? I have just put the USB cable in my computer and the card just flash blue once
No, you can flash it anytime and connect the sensors later, thats how I did on the inicial Bruh sensor since everything came from China in split orders, I just connected them as they arrived
Allright, damn, maybe im just unlucky
Did your card blink blue once when connected to PC?
Did u install any drivers?
Dont remember about the led, but on Ubuntu I didnt install any adicional drivers (all done within Arduino ide) and on Windows I had to install the drivers prio to Arduino ide, I dont know now the exact link but you can easy find them on google
Allright
Well i do not even get the computer too search after new hardware and i did try 2 computers.
Do u have Windows 7 or 10?
depends on the cable.
there are data cables and power cables.
with a power cable you would feed power to the esp but it wont be seen by your pc.
Windows 10, have you installed the drivers https://www.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx ?
To make the motion sensor into a binary sensor:
binary_sensor:
- platform: mqtt
state_topic: "BruhNode/YourTopic"
device_class: motion
value_template: '{{ value_json.motion }}'
payload_on: 'motion detected'
payload_off: 'standby'
that’s nice to have.
Although my problem is that it takes 5-6 seconds going from motion detected to standby. Anyway to change the code and make it 1 second?
Yes, im gonna try too get a new micro USB cable. I have tried the one from aeotec 6-in-1 sensor and one from a Sony mobile
I have 2 of them up and running but I can’t seem to find the correct line to disable blue led that is starting when the sensor is plugged in. Can anyone point me in the right direction?
