If you have a smart button, at least this is the case with the ZigBee buttons I have, you can setup an automation to do that as the buttons support push/hold/release. I’m not clear on what it is that you want Home Assistant to support as this would be a hardware & automation setup that you can already accomplish.
OK, I would change your title and request because it sounds like you want an Input Helper that functions that way. It’s important to be detailed when putting out feature requests.
I’m not sure how much interest this sort of request would have given this can be accomplished with 2 helpers right now. The fact that you want dimming would still be up to you to hook up the automations with helpers.
I think there is similar (or the same) requests already: Front end button release event @timnolte - can you share more info how to achieve it with 2 helpers right now ?
