Thank you for your time in keeping this alive!
Sorry to bother, I couldnât find anything regarding my following question.
Now, I have enabled hide_sidebar feature and it works great. But I would like to âunhideâ it when itâs unarmed to regain full control of my HassIO dashboard.
Any way you, or obviously anyone else reading this, can help me accomplish this?
To be honest, I donât see much of sense in that hide_sidebar
feature running HA 0.102 (i.e not 0.85 or similar) on my tablet as I have âAlways hide the sidebarâ in HA settings for that user.
Just swipe your screen (or click and drag your mouse) from left edge of the screen.
I know I asked this previously but I never did get it sorted out and just now trying to close out some ongoing HA issues. I find that my alarm warning automation keeps getting turned off somehow. Itâs not being caused by HA restarts as I have confirmed that it happens without a restart (so initial_state: 'on'
is not the issue here, which is set anyway). This is my only automation that isnât keeping itâs state over time. My thinking is that itâs happening when I arm / disarm the alarm system. Searching my config files finds absolutely no code to cause this behaviour. Is anyone else noticing this as well?
My automation.yaml only contains code for this alarm as all my other automations are in packages.
- id: alarm_armed_away
alias: '[Alarm] Away Mode Armed'
hide_entity: true
initial_state: 'on'
- platform: state
entity_id: alarm_control_panel.house
to: 'armed_away'
- data:
message: 'Alarm Away Mode Armed'
service: notify.html5
# service: notify.pushbullet
- data:
message: 'House alarm armed, away mode'
service: tts.google_translate_say
# service: notify.google_assistant_broadcast
entity_id: media_player.lounge_mini
- id: alarm_armed_home
alias: '[Alarm] Home Mode Armed'
hide_entity: true
initial_state: 'on'
- platform: state
to: 'armed_home'
- data:
message: 'Alarm Home Mode Armed'
- data:
message: 'House alarm activated, home mode'
- id: alarm_arming_away
alias: '[Alarm] Away Mode Arming'
hide_entity: true
initial_state: 'on'
- platform: state
to: 'pending'
# - data:
# message: 'House alarm activating'
- data:
message: 'House alarm activating, away mode'
- id: alarm_disarmed
alias: '[Alarm] Disarmed'
hide_entity: true
initial_state: 'on'
- platform: state
to: 'disarmed'
- service: switch.turn_off
entity_id: switch.alarm_siren1_switch
- service: script.turn_on
entity_id: script.alarm_lights_off
- service: notify.html5
# - service: notify.pushbullet
message: 'Alarm Disarmed'
- data:
message: 'House alarm disarmed'
- id: alarm_triggered
alias: '[Alarm] Triggered'
hide_entity: true
initial_state: 'on'
- platform: state
to: 'triggered'
- service: switch.turn_on
message: 'ALARM TRIGGERED!!! {{ states[states.alarm_control_panel.house.attributes.changed_by.split(".")[0]][ states.alarm_control_panel.house.attributes.changed_by.split(".")[1]].name }}'
# message: "The {{ trigger.to_state.attributes.friendly_name }} Smoke Alarm has TRIGGERED!!!" # use this as example to simplify the above
entity_id: script.alarm_lights_on
- id: alarm_warning
alias: '[Alarm] Warning'
hide_entity: true
initial_state: 'on'
- platform: state
to: 'warning'
message: 'ALARM Warning {{ states[states.alarm_control_panel.house.attributes.changed_by.split(".")[0]][ states.alarm_control_panel.house.attributes.changed_by.split(".")[1]].name }}'
- data:
message: 'House alarm tripped and authorities notified. Get out of the house'
Any ideas? Based on the above code it can only be occurring due to the alarm code in the custom_component as far as I can tell�
I have similar automations and they all seem to work and stay on
Do I get it right that only the last automation alarm_warning
becomes off
by itself?
I think there is nothing to do with the integration and would suggest you to create a new topic in Configuration so we could focus on debugging the issue there.
Try:
initial_state: true
Iâd say âremove initial_state everywhereâ but it wonât solve his issue
the alarm does not work with the new version of ha 0.103
Letâs not update to 0.103 until I sort it out.
I was naive enough to not check here first so I can confirm itâs not working on 0.103.0 Downgrading nowâŠ
Thatâs correct. This is the only automation out of many that turns itself off.
Ok, will do. Thanks
A new version that fixes this integration after updating HA to 0.103 is available.
I also adds a little bonusâŠ
Thank you for removing the panel_title!
Glad it works for you.
I hope to get its look a bit better soon, currently playing with the bottom bit
Next to updated working fine for me.
Gracias!!!
Thanks for you work
I installed the update and it works. But now I am locked out of the settings⊠Any ideas how to log in?
I got it working again, I didnât realize that I shouldnât have replaced my bwalarm.yaml when updating.
Live and learn.
-Bob
Thanks for the fix! Works like a charm again. Question though, I didnât notice anything different. Maybe because I use it for just a few days. Whatâs the bonus exactly?
Itâs in release notes. Basically, you can get rid of the panelâs title by setting it to empty string.
yes, as per Readme bwalarm.yaml
is not in the same folder as the code.
For a long time I am seeing this in my logs:
Not passing an entity ID to a service to target all entities is deprecated. Update your call to alarm_control_panel.alarm_arm_away to be instead: entity_id: all
But I never bothered as it is working properly.
Is it a problem, or should I ignore it?
I am using the alarm card from Lovelace to arm and disarm if that helps.
I just updated to your latest version of the alarm, but I am still getting it.
