This is what i have in my config:
switch:
- platform: broadlink
host: 192.168.100.53
mac: 'B4:43:0D:CC:0F:58'
timeout: 15
type: rm2_pro_plus
Maybe try a type?
switch:
timeout: 15
type: rm2_pro_plus
Maybe try a type?
I did try with with type but it is still not added
There’s an open issue about RM mini on Github.
I try to downgrad to 0.91.3 and broadlink work fine now
It seems that you have rm2_pro. I also have it and have no problem with it after upgrading to 0.92.1. Looks like only the mini is affected.
It has been said that this issue was fixed on 0.92.1 (https://github.com/home-assistant/home-assistant/pull/23408). But I still have this problem on my hassio 0.91.2, can anyone help please ?
I have an 0.92 problem with Broadlink minis as well. Switches that were configured worked in HA after I called them from google voice, not from the HA panel. Scripts do not work at all.
I am having the same problem, the switch for rm pro doesnt work, any solution?
This is the error I get:
Error executing service <ServiceCall script.pc_off (c:58855c6f9f4b40c2a1096420021bc3b5)>
File “/usr/local/lib/python3.7/site-packages/homeassistant/core.py”, line 1147, in _safe_execute
await self._execute_service(handler, service_call)
File “/usr/local/lib/python3.7/site-packages/homeassistant/core.py”, line 1160, in _execute_service
await handler.func(service_call)
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/script/init.py”, line 114, in service_handler
context=service.context)
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/script/init.py”, line 172, in async_turn_on
kwargs.get(ATTR_VARIABLES), context)
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/script.py”, line 131, in async_run
await self._handle_action(action, variables, context)
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/script.py”, line 210, in _handle_action
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/script.py”, line 299, in _async_call_service
context=context
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/service.py”, line 89, in async_call_from_config
domain, service_name, service_data, blocking=blocking, context=context)
File “/usr/local/lib/python3.7/site-packages/homeassistant/core.py”, line 1115, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: (ServiceNotFound(…), ‘Service switch.broadlink_send_packet_192_168_0_105 not found’)
have you confirmed that’s the correct config for broadlink, pretty sure the switch.broadlink_send_pack is no longer valid
This is what I have in my switch.yaml file:
- platform: broadlink host: 192.168.0.105 mac: 'my mac address' type: rm2_pro_plus
Same here with rm mini, all my switches are reporting “Entity not available”… Any solution?
do you have an automation that calls switch.broadlink_send_packet
My RM mini is working fine with version 0.92.2! But I had to change my scripts recently from “switch.broadlink_send_packet” to “broadlink.send”.
# Broadlink IR-Blaster
host: Your-Broadlink-IP-Adress
mac: "Your-Broadlink-MAC-Adress"
friendly_name: RM mini 3
and in my Scripts/automations I use:
ir_device1:
alias: IR Device Command 1
- data:
packet: The-needed-IR-code=
service: broadlink.send
Good luck!
That seems to have done the trick for me, thanks!
If a few more people jump in with this as a solution I’m thinking to have a bash at changing the docs to reflect the working change…
yes I have a script which calls it
Can you post one of your scripts formatted?
You need to update it to the new format
the documentation already has a the correct example for the change
