SmartIR is very interesting to me but do you plan to use any other controller than the Broadlink? I’m thinking also in some DIY device with an infrared emitter for example with an ESP8266 chip. Has someone done such integration with SmartIR?
I don’t recall using my rm mini on 92.0 as I only ran it for 2 days, so it may not have worked. I am sure it works now though on 92.1. When I run into issues like this I try and start again with the device code. Rather than carry code from 91.3 read the readme again and write code from scratch. It always helps me and rarely is it a platform issue.
@brent0np actually i install hassio 0.91.1 on raspberry at first and i got the problem with adding broadlink rm mini 3. Then i have to downgrade hassio to 0.91.3, and the broadlink work fine except the broadlink.send thing.
Anw, i will take a snapshot and try to upgarde to 0.92.1 again. I will let u guys know the result soon. Thanks @brent0np@aidbish1
Does anyone has issue with climate.smartir high cpu usage? I’m running 0.92.1 hass.io on RPI 3B and noticed that after enabling climate component and restart the CPU in a few minutes jumps 100% and pretty much stays entire time. Wasn’t the case before recent smartir updates.
Logs don’t show anything interesting. The component works, however HA is running at 100%. Not sure what to check in config. Disabling updater, smartir and climate.smartir puts CPU back to normal 4-8% range. Either of those components enable -> CPU 100.
I use this smartir component which works perfectly , i face one strange issue when using this with emulated hue , when i ask alexa to turn on or off , it does not respond to that , but for changing tempreture it works while ac is on , the strange thing if i ask alexa to turn off the group that ac component in it turns off with other ac in that group , any recommendation to make it work for on and off commands through alexa
Sorry,
just to understand clearly what you did:
1- you created a script for every channel you frequently use
2- you exposed the scripts to google assistant (it should see them as scenes)
3- you configured a routine in the google home app with matching key words to activate the specific scene
Hi guys, I think the problem is my broadlink, i went to store and exchange for another broadlink and it works fine now. I’m able to see the broadlink.send and successfull using smartir to control my tv. But now how can i lear command? I used call service “broadlink.learn” with data:
“host”: “192.168.1.28”
and get this error: ERROR (MainThread) [homeassistant.components.broadlink] Failed to connect to device
