I’ve just added Home Assistant to my house and am trying — but failing — to pair some older Z-wave controlled Bali Blinds with it. I’d appreciate any advice.
I’m using a Zooz 800 USB controller and several Zooz 800 repeaters, managed using Z-Wave JS UI.
The blinds in question are described here and I was able to find the following older threads referencing this (but the instructions didn’t work for me): here and here.
I’ve reset the blinds, and then I place them into inclusion mode (LED confirms this). I go to Z-Wave JS UI, click the hamburger menu, then the infinity sign, and the Nodes Manager appears. I choose “inclusion”, hit next, type in name/location, hit next, choose default security, hit next, and then I get 30 seconds of inclusion… during which no new devices are found. Any advice on what I might be doing wrong?
Notes
Honestly this is the first attempt I’ve made to adopt a Z-wave device that doesn’t have Smart Start, so I may be doing something really boneheaded….
Note that the blinds have to be added through a repeater, because they are far away from where the hub must be located. The repeater shows up as successfully connected in Z-Wave JS UI, and it’s quite close to the blinds.
I don’t know anything about the security level supported by these older blinds (i.e., no encryption vs. S0 vs. S2). I’m assuming the “Default” option has me covered there (though I did also try adopting with S0 and with “no encryption” security and had the same result).
Assuming you don’t have an RF coverage gap, you might be experiencing a bug in the SDK where NWI of a 500 series device doesn’t work through 700/800 series repeaters. Allegedly it works on the second attempt, but will reliably fail the initial inclusion. Have you tried immediately starting a second inclusion attempt after the first fails (e.g. don’t factory reset or do anything else in between)?
Thanks! I tried several times back to back and nothing appeared to work… Then miraculously an hour later I opened my Z-Wave JS UI device list and the blinds are happily listed there (albeit without security)
Now if I could only get the devices to appear in Home Assistant… but I appear to be having this issue…
I’m having trouble pairing my bali blinds zwave to my HA as well. Similar to you, I have the zwave JS add-on setup in addition to the zwave integration all set up. The blinds have been reset by holding for 7 seconds, the light flashing orange, and the blind jogging. When I go to add new device in HA, it says its searching. I press and hold the blind for 3 seconds allowing it to go into pairing mode - flashing green. I have the blind in the same room as the Zooz 800 dongle, however it does not pair. I’ve also tried restarting the add-on’s etc. Somehow it seems like your blinds randomly showed up? I’m curious how that worked?
EDIT: It turns out that my Bali Blinds just aren’t able to reconnect to a zwave controller. I tried to pair them to a Bali remote and it didn’t work there either. It must be something defective with the firmware that its running
