Spartacus
(Spartacus)
February 24, 2024, 7:20pm
1
Hi there,
is there anybody who can help with mushroom empleate card?
I wanted to combine the mushroom mod with the ha_card mod? I can only use one of these mods.
Goal is to remoce the light gry circle around the icon and to change the text color in the primary and secondary line.
type: custom:mushroom-template-card
primary: '{{ ''online'' if states(entity) == ''on'' else ''offline'' }}'
icon: '{{"mdi:wifi" if states(entity)=="on" else "mdi:wifi-off"}}'
entity: binary_sensor.cupra_born_car_is_online
multiline_secondary: false
layout: vertical
icon_color: '{{ ''green'' if states(entity) == ''on'' else ''red'' }}'
fill_container: false
card_mod:
style: |-
ha-card {
{% if
is_state('binary_sensor.cupra_born_car_is_online','on') %}
--card-primary-color:
{%else%}
--card-primary-color:#7E7E7E;
{% endif %}
} mushroom-shape-icon$: >
.shape {
--icon-symbol-size: 21px;
--icon-size: 100px;
Edwin_D
(Edwin D.)
February 24, 2024, 7:25pm
2
Spartacus:
style: |-
I don’t know about the rest, but the |- here should be removed.
Spartacus
(Spartacus)
February 24, 2024, 7:37pm
3
I checked this but then I get an eror!
Edwin_D
(Edwin D.)
February 24, 2024, 7:56pm
4
Indentation is important in yaml, so you need to fix it. It seems to be indented too deep to me. It should be 2 spaces deeper than ha-card I think.
Check docs for card-mod, the “style” option’s value is ether a string or a dictionary, you are trying to use both simultaneously.
This is correct:
style: |-
ha-card {
but only for this “string” ha-card part.
The next expression with “$” is a part of dictionary which cannot be combined with a “string” part like you did.
Go to a huge card-mod thread → 1st post → link at the bottom → others → combining.
Spartacus
(Spartacus)
February 24, 2024, 8:13pm
6
hm!
It will not wor:
layout: vertical
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--icon-symbol-size: 20px;
--icon-size: 0px;
this is worling as it should!
and this is also working!
layout: vertical
card_mod:
style: |-
ha-card {
{% if
{%else%}
{% endif %}
but not together, I tried sevaral cobinations!
Spartacus
(Spartacus)
February 24, 2024, 8:27pm
7
hä?!?! I do not understand, what you mean!
Just read the last sentence of my post.
Spartacus
(Spartacus)
February 24, 2024, 8:36pm
9
it would be very nice, if you can post the link, I do not find it!
Spartacus
(Spartacus)
February 24, 2024, 8:45pm
11
sorry, I’m sorry, I have no idea what you mean! The riddle is obviously too high for me! Anyway, thank you! I don’t see what that has to do with what I want.
You need to learn step by step on simple examples if you wish to use card-mod.
The link I provided contains a lot of tutorial examples - including an explicit answer to
Spartacus
(Spartacus)
February 24, 2024, 9:09pm
13
Ok, thank you, you can learn a lot and I learn every day. But, you can’t learn everything there is in the world, that’s just the way it is. When I buy a car, I want to drive it, not design it build it up and then drive it. Certain things have to be there!
Yes, I know, this is not a consumer product and I am grateful for people who develop the whole thing and support it. But my aspiration is different, so I like to learn from examples. It’s enough for me if I can handle it. Here I have obviously reached my limits and then I have to leave it at that! That’s just the way it is! “Schuster bleib bei deinen Leistent”, as a german saying goes.
Thanks for the support, I’ll break this off here.
That is why I gave you a path to a list of examples.
Check out this thread if you are going to learn about modding mushroom cards
You had serval issue as @Ildar_Gabdullin pointed out.
One that wasn’t mentioned was:
a color wasn’t defined here and I have found
if states
works best for the first portion of the if statement.
The link I sent you has a great section on what the $
and .: |
does as well as healthy guide to everything mushroom.
layout: vertical
card_mod:
style:
.shape {
--icon-size: 0px;
ha-card {
{% if states('binary_sensor.cupra_born_car_is_online','on') %}
--card-primary-color: #821b1b;
{%else%}
{% endif %}
Spartacus
(Spartacus)
February 25, 2024, 3:35pm
17
ok, I think I habe it! Two open points are left:
how I can I reduce the space between the Icons and the first line
is it possible to use the keyword “entity” in the card-mod section (see post before)
The code:
type: custom:stack-in-card
cards:
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 1fr 1fr 1fr 1fr 1fr
margin: null
cards:
layout: vertical
card_mod:
style:
.shape
{% if is_state('binary_sensor.cupra_born_car_is_online','on') %}
--shape-animation: ping 2s infinite;
--icon-size: 40px;
@keyframes ping
0%
box-shadow: 0 0 5px 1px rgba(var(--rgb-green), 0.7);
100%
box-shadow: 0 0 5px 15px transparent;
{%else%}
--icon-size: 40px;
{% endif %}
ha-card
border: none !important;
{%else%}
{% endif %}
primary: '{{ ''Motor läuft'' if states(entity) == ''on'' else ''Motor aus'' }}'
icon: >-
{{"mdi:engine-outline" if states(entity)=="on" else
"mdi:engine-off-outline"}}
entity: binary_sensor.cupra_born_engine_status
layout: vertical
icon_color: '{{ ''green'' if states(entity) == ''on'' else ''grey'' }}'
card_mod:
style: |
ha-card
{% if is_state('binary_sensor.cupra_born_engine_status','on') %}
{%else%}
{% endif %}
primary: '{{states(entity)}} %'
icon: >-
{{"mdi:battery-charging-high" if
states("sensor.cupra_born_charging_state")=="charging" else
"mdi:battery-10" if states(entity)<"10"else "mdi:battery-20" if
states(entity)<"20"else "mdi:battery-30" if states(entity)<"30"else
"mdi:battery-40" if states(entity)<"40"else "mdi:battery-50" if
states(entity)<"50"else "mdi:battery-60" if states(entity)<"60"else
"mdi:battery-70" if states(entity)<"70"else "mdi:battery-80" if
states(entity)<"80"else "mdi:battery-90" if states(entity)<"90"else
"mdi:battery-charging-100" if states(entity)<"100"}}
entity: sensor.cupra_born_state_of_charge
layout: vertical
icon_color: >-
{{ 'red' if states(entity)<"10" else 'amber' if
((states("sensor.cupra_born_charging_state")=="charging")or
states(entity)<"70")else ('green' if ((states(entity) ==
states("number.cupra_born_target_state_of_charge")or
states(entity)<"80"))) }}
secondary: >-
{{ 'charging' if
states("sensor.cupra_born_charging_state")=="charging" }}
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
.shape
{% if is_state('sensor.cupra_born_charging_state','charging') %}
--icon-size: 40px;
@keyframes ping
0%
box-shadow: 0 0 5px 1px rgba(var(--rgb-amber), 0.7);
100%
{%else%}
--icon-size: 40px;
{% endif %}
ha-card
--card-primary-color:;
--card-secondary-color:#00CC00;
{%else%}
--card-secondary-color:;
{% endif %}
primary: '{{ ''geöffnet'' if states(entity) == ''on'' else ''verschlossen'' }}'
icon: '{{"mdi:car-door" if states(entity)=="on" else "mdi:car-door-lock"}}'
entity: binary_sensor.cupra_born_overall_status
layout: vertical
icon_color: '{{ ''amber'' if states(entity) == ''on'' else ''green'' }}'
card_mod:
style: |
ha-card
{% if is_state('binary_sensor.cupra_born_overall_status','on') %}
{%else%}
{% endif %}
primary: '{{ ''Heinzung an'' if states(entity) == ''on'' else ''Heizung aus'' }}'
icon: '{{"mdi:radiator" if states(entity)=="on" else "mdi:radiator-off"}}'
entity: light.lidl_edison_bulb_2
layout: vertical
icon_color: '{{ ''red'' if states(entity) == ''on'' else ''grey'' }}'
secondary: >-
{% if states("light.lidl_edison_bulb_2")=="on" %} {{'Temperatur:'}}
{{(states("number.cupra_born_target_climate_temperature")|int)}}
{{"°C"}} {%endif%}
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card
{% if is_state('light.lidl_edison_bulb_2','on') %}
{%else%}
{% endif %}
- type: markdown
content: >-
<hr>
<br/>
<img src = '/local/Cupra-Logo.png'
align='middle'
width='100'
height='59'></img> <font color="#B3773F"><font
size="5">{{'  '}}Fahrzeugübersicht</font></font><br/>
<font color="#B3773F"><font size="4">UN - AC 999</font></font>
<hr>
<br/>
Parkposition am {{as_timestamp(state_attr('sensor.cupra','last_changed'))|
timestamp_custom('%d.%m.%Y um %H:%M')}} Uhr:
|{{'  '}}{{(state_attr('sensor.cupra','street'))}} {{
(state_attr('sensor.cupra','street_number'))}}
|{{'  '}}{{(state_attr('sensor.cupra','postal_code'))}}
{{(state_attr('sensor.cupra','city'))}}
verbleibende
Ladezeit:|{{states("sensor.cupra_born_remaining_charging_time")}} min.
verbleibende
Aufheizzeit:|{{'    '}}{{states("sensor.cupra_born_remaining_climatisation_time")}}
min.
Kilometerleistung:|{{states("sensor.cupra_born_odometer_in_kilometers")}}
km
Reichweite:|{{states("sensor.cupra_born_range_in_kilometers")}} km
letzter Trip:|{{states('sensor.cupra_born_odometer_in_kilometers') |int -
states('input_number.save_current_mileage')| int }} km
Motor ein: {{as_timestamp(states('input_datetime.on_time_engine'))|
timestamp_custom("%d.%m.%Y um %H:%M Uhr") }}
Motor aus: {{as_timestamp(states('input_datetime.off_time_engine'))|
{% if (((as_timestamp(states('input_datetime.off_time_engine')) -
as_timestamp(states('input_datetime.on_time_engine')))/60) |int)<=0%}
{%else%}
Die Fahrzeit betrug ca.
{{((as_timestamp(states('input_datetime.off_time_engine')) -
as_timestamp(states('input_datetime.on_time_engine')))/60) |int}} min.
{%endif %}
card_mod:
style:
ha-markdown $: |
img {
vertical-align: middle !important;
ha-card
card_mod:
style: |
ha-card {
Let’s start small with your formatting. I think you are going to need to shrink things for it to fit better.
I cleaned up the code a bit and got your animation working.
primary: '{{ ''Online'' if states(entity) == ''on'' else ''Offline'' }}'
layout: vertical
card_mod:
style:
.shape {
--icon-size: 40px;
{% set light_state = states(config.entity) %}
{% if light_state == 'on' %}
@keyframes ping {
0% {box-shadow: 0 0 0 0 green }
70% {box-shadow: 0 0 0 10px transparent;}
100% {box-shadow: 0 0 0 0 transparent;}
{% else %}
{% endif %}
mushroom-state-info$: |
.container {
--card-primary-font-size: 12px;
ha-card{
--card-primary-color: grey;
Spartacus
(Spartacus)
February 29, 2024, 6:53pm
19
@LiQuid_cOOled ,
thanks for you feedbak. I am currently on a business trip and I will check this out on the weekend. Sorry for the late response…
Spartacus
I worked on your card some more…let me know
cards:
layout:
margin: 0px 0px 0px 0px
cards:
primary: '{{ ''Online'' if states(config.entity) == ''on'' else ''Offline'' }}'
icon: '{{"mdi:wifi" if states(config.entity)=="on" else "mdi:wifi-off"}}'
entity: light.pc_lights
layout: vertical
icon_color: '{{ ''green'' if states(config.entity) == ''on'' else ''red'' }}'
card_mod:
style:
.shape {
--icon-size: 40px;
@keyframes ping {
70% {box-shadow: 0 0 0 5px transparent;}
{% else %}
{% endif %}
.container {
ha-card {
margin-left: -2px;
{% if is_state(config.entity,'on') %}
--card-primary-color: white;
{%else%}
{% endif %}
primary: '{{ ''Motor läuft'' if states(config.entity) == ''on'' else ''Motor aus'' }}'
icon: >-
{{"mdi:engine-outline" if states(config.entity)=="on" else
layout: vertical
icon_color: '{{ ''green'' if states(config.entity) == ''on'' else ''grey'' }}'
card_mod:
style:
.shape {
--icon-size: 38px;
.container {
ha-card {
margin-left: -20px;
{%else%}
{% endif %}
icon: >-
states("light.pc_lights")=="on" else
entity: sensor.basement_sensor
layout: vertical
icon_color: >-
((states(config.entity)=="charging")or
states(config.entity)<"70")else ('green' if ((states(config.entity) ==
states(config.entity)or
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
.shape {
--icon-size: 40px;
{% if is_state(config.entity,'charging') %}
@keyframes ping
0% { box-shadow: 0 0 5px 1px rgba(var(--rgb-amber), 0.7);
100% { box-shadow: 0 0 5px 15px transparent;
{% endif %}
.container {
ha-card
margin-left: -20px;
{%else%}
{% endif %}
primary: '{{ ''Geöffnet'' if states(config.entity) == ''on'' else ''Verschlossen'' }}'
icon: >-
entity: light.bed_lights
layout: vertical
icon_color: '{{ ''amber'' if states(config.entity) == ''on'' else ''green'' }}'
card_mod:
style:
.shape {
--icon-size: 38px;
.container {
ha-card
margin-left: -20px;
{%else%}
{% endif %}
primary: >-
{{ 'Heinzung an' if states(config.entity) == 'on' else 'Heizung aus'
icon: >-
{{"mdi:radiator" if states(config.entity)=="on" else
layout: vertical
icon_color: '{{ ''red'' if states(config.entity) == ''on'' else ''grey'' }}'
secondary: >-
{% if states(config.entity)=="on" %} {{'Temperatur:'}}
{{(states("entity)|int)}}
{{"°C"}} {%endif%}
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
.shape {
--icon-size: 38px;
.container {
ha-card
margin-left: -20px;
--icon-size: 40px;
{%else%}
{% endif %}
card_mod:
style: |
ha-card {
