I’m trying to group 2 thermostats (they’re in the same room). I already have a light group which works fine but when I try creating the climate group HA shows an error:
"Configuration invalidCHECK CONFIGURATION
Platform error climate.group - No module named ‘homeassistant.components.group.climate’".
With all due respect, this page doesn’t help, cause I am trying to do the same thing.
Use the group integration instead, so as a noob I go to configure and integrations, well there isn’t a group one there. The only instruction is an example of yaml code.
I’ve marked tobi-bo’s post as the solution. You can do this in future. Click the three dots icon below the post that helped you to show the solution button.
Also in future please don’t post pictures of text. Post the text correctly formatted. That way it is a lot easier for others to help you using copy/edit/paste.
I want to create a group of climate entities (thermostats) and to be able to count the thermostat on / off states to make it visible within a mushroom chips template card. I tried the solution here GitHub - daenny/climate_group: Home Assistant Climate Group. But it only shows on but does not give any number of on entities within the group.
it hasnt had any activity in years and there are pull requests still waiting to add external temp sensor.
it would be better if this was absorbed into the main build of home assistant but it would still need someone to maintain it
Hi, @magiva,
I found the possibility with climate_group some days ago. I have a question and I hope you to be able - and so friendly - to help me:
So far, I only managed to build one group, but I woul like to build a second one. Perhaps, the question or rather the answer is too simple, but I am not yet an expert on Home Assistant…
I have tried several times but did not succeed. Could you please give me a hint to solve this problem? Thanks a lot!
