I upgraded Hassbian to 0.96.5 and now I have an issue with cloud acess
Invalid config
The following components and platforms could not be set up:
* [cloud](https://home-assistant.io/components/cloud/)
Please check your config.
I don’t know why because I didn’t modified the configuration.yaml …
Log Details (ERROR)
Fri Jul 26 2019 21:42:54 GMT+0200 (heure d’été d’Europe centrale)
Error during setup of component cloud
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 153, in _async_setup_component
hass, processed_config)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/cloud/__init__.py", line 142, in async_setup
from hass_nabucasa import Cloud
File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 16, in <module>
from .remote import RemoteUI
File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/remote.py", line 16, in <module>
from .acme import AcmeClientError, AcmeHandler
File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/acme.py", line 9, in <module>
import OpenSSL
File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/crypto.py", line 16, in <module>
from OpenSSL._util import (
File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/_util.py", line 6, in <module>
from cryptography.hazmat.bindings.openssl.binding import Binding
File "/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 15, in <module>
from cryptography.hazmat.bindings._openssl import ffi, lib
ImportError: /usr/lib/arm-linux-gnueabihf/libssl.so.1.1: version `OPENSSL_1_1_1' not found (required by /srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so)
You’ll find my configuration.yaml
homeassistant:
# Name of the location where Home Assistant is running
# name: Home
# Location required to calculate the time the sun rises and sets
# latitude: 0.672232
# longitude: 5.665709
# Impacts weather/sunrise data (altitude above sea level in meters)
# elevation: 342
# metric for Metric, imperial for Imperial
# unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
# time_zone: UTC
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
# introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Text to speech
tts:
- platform: google_translate
service_name: google_say
language: 'fr'
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
media_player:
- platform: onkyo
host: 192.168.0.12
- platform: synologydsm
host: 192.168.0.9
username: admin
password: vkgc54KL
monitored_conditions:
- cpu_total_load
- memory_real_usage
- network_up
- disk_smart_status
- volume_percentage_used
- volume_disk_temp_avg
- platform: statistics
entity_id: sensor.consommation_lave_linge
name: Stats Lave Linge
max_age:
minutes: 5
- platform: scrape
resource: http://192.168.0.3/details.xml
select: 'PrimaryValue'
index: 0
unit_of_measurement: "°C"
value_template: "{{ value.split(' ')[0] | round(2) }}"
- platform: scrape
index: 1
- platform: scrape
name: Température Extérieure
index: 2
system_health:
alarm_control_panel:
- platform: manual
code: xxxx
pending_time: 30
delay_time: 20
trigger_time: 4
disarmed:
trigger_time: 0
armed_home:
pending_time: 0
delay_time: 0
ios:
nest:
client_id: xxx
client_secret: xxx
google:
client_id: xxx
client_secret: xxxx
camera:
- platform: mjpeg
still_image_url: http://192.168.0.20:80/video.cgi
mjpeg_url: http://192.168.0.20:80/video.cgi
username: xxx
password: xxx
authentication: basic
File “/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/cli/base_command.py”, line 188, in main
status = self.run(options, args)
File “/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/commands/uninstall.py”, line 75, in run
auto_confirm=options.yes, verbose=self.verbosity > 0,
File “/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/req/req_install.py”, line 831, in uninstall
uninstalled_pathset.remove(auto_confirm, verbose)
File “/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/req/req_uninstall.py”, line 388, in remove
moved.stash(path)
File “/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/req/req_uninstall.py”, line 277, in stash
renames(path, new_path)
File “/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/utils/misc.py”, line 405, in renames
shutil.move(old, new)
File “/usr/local/lib/python3.7/shutil.py”, line 575, in move
rmtree(src)
File “/usr/local/lib/python3.7/shutil.py”, line 491, in rmtree
_rmtree_safe_fd(fd, path, onerror)
File “/usr/local/lib/python3.7/shutil.py”, line 449, in _rmtree_safe_fd
onerror(os.unlink, fullname, sys.exc_info())
File “/usr/local/lib/python3.7/shutil.py”, line 447, in _rmtree_safe_fd
os.unlink(entry.name, dir_fd=topfd)
PermissionError: [Errno 13] Permission denied: ‘top_level.txt’
