ok cool, amazing stuff you make. ill hop back over again to the Github
This add-on is so great. Thank you thank you! This is what Iāve been hoping to do since starting home assistant.
One minor annoyance is that there is such limited control over what components are added to HomeKit from home assistant. I have many groups and automations that i donāt want showing up, but in order to add a few i have to add all of them. I wish i could pick exactly which components were added.
Like i said itās a minor annoyance. Everything else is great!
@themanieldaniel, there actually is very good control over what you make visible within HomeKit. You can use one of two methods to manage this as described in the documentation. Within the āconfig.jsonā config file, which is in the āHomeBridgeā folder you can either:
- Set ādefault_visibilityā to āhiddenā, and then individually customise which entities are visible in your ācustomize.yamlā file using āhomebridge_visible: trueā
or
- Set ādefault_visibilityā to āvisibleā (note this is default in HASS.io) and then individually customise which entities are hidden in your ācustomize.yamlā file using āhomebridge_hidden: trueā
I use the first option. It can be used for devices, groups, scenes and automations.
Oh, thank you so much for the clarification. I thought I had read all the documentation. I must not have. That is great. I will implement option 1 since I have only a few items that I want HomeBridge to communicate with.
contribution entered. Hope its the right thread: Home couldn't connect to this accessory. Ā· Issue #216 Ā· home-assistant/homebridge-homeassistant Ā· GitHub
Please have another look @frenck.
Thanks for any suggestions you might have,
Marius
Hello. Iāve installed this app, and connected to it using the default code and the iOS Home app. I ahvenāt changed anything at all in the config.json.
Homebridge sees devices (in the log), and the Home app sees them too, but the Home app cannot connect to any of them.
Any advice/something obvious Iāve missed?
Thanks,
James
EDIT - this fixed itself!
Hi! Home App sees āHome Assistantā, but cannot connect to Home App, any suggestions?
This is what happened to me, but it eventually rsolved itself after a few hours.
Iāve had a couple instances where HomeKit took a while to catch up to significant changes I was making in devices. Iām using my phone, and Apple TV and share access with a couple people with one or more devices each, and I think it just took a little while to sync all the changes around through that ecosystem. Not sure if thatās your issue, but just a thought.
Hi all, Iāve tried the troubleshooting instructions on Github, but HA isnāt showing up in the iOS Home app and the Homebridge logs keeps throwing errors. Process is:
- Start Homebridge, looks good, logs end with
Server startup complete. Host name is hassio.local. Local service cookie is 1949741333.
- Some seconds later, the error below begins repeating:
Error: Not a valid username: 02:23:45:67:89:ab. Must be 6 pairs of colon-separated hexadecimal chars (A-F 0-9), like a MAC address.
at Server._loadConfig (/usr/lib/node_modules/homebridge/lib/server.js:215:13)
at new Server (/usr/lib/node_modules/homebridge/lib/server.js:57:38)
at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:26:16)
at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (module.js:635:30)
at Object.Module._extensions..js (module.js:646:10)
at Module.load (module.js:554:32)
at tryModuleLoad (module.js:497:12)
at Function.Module._load (module.js:489:3)
at Function.Module.runMain (module.js:676:10)
Iāve tried several different usernames, all giving the same error. My config file:
"bridge": {
"name": "Home Assistant",
"username": "02:23:45:67:89:ab",
"port": 51826,
"pin": "123-45-678"
"description": "Homebridge for Home Assistant",
"accessories": [],
"platforms": [
"platform": "HomeAssistant",
"name": "HomeAssistant",
"host": "http://hassio/homeassistant",
"password": "",
"default_visibility": "visible",
"supported_types": [
"automation",
"binary_sensor",
"climate",
"cover",
"device_tracker",
"fan",
"group",
"input_boolean",
"light",
"lock",
"media_player",
"remote",
"scene",
"script",
"sensor",
"switch",
"vacuum"
"logging": true,
"verify_ssl": true
I had this working about 6 months back when I tried then, not sure why Iām unable now. Any advice appreciated!
Uppercase your username: 02:23:45:67:89:AB
Brilliant solved
Cheers
Hi!
All of a sudden, over night, Homebridge stopped working on my hassio installation. I used it before I got to bed, an din the morning it was dead. Checking the logs, I found this:
[2017-12-26 11:12:21] Loading 0 accessories...
undefined:1
502: Bad Gateway
SyntaxError: Unexpected token : in JSON at position 3
at JSON.parse (<anonymous>)
at Request.request [as _callback] (/usr/lib/node_modules/homebridge-homeassistant/index.js:101:38)
at Request.self.callback (/usr/lib/node_modules/homebridge-homeassistant/node_modules/request/request.js:186:22)
at emitTwo (events.js:126:13)
at Request.emit (events.js:214:7)
at Request.<anonymous> (/usr/lib/node_modules/homebridge-homeassistant/node_modules/request/request.js:1163:10)
at emitOne (events.js:116:13)
at Request.emit (events.js:211:7)
at IncomingMessage.<anonymous> (/usr/lib/node_modules/homebridge-homeassistant/node_modules/request/request.js:1085:12)
at Object.onceWrapper (events.js:313:30)
I havenāt done any updates or reinstallation recently. I now tried to uninstall Homebridge, remove Homebridge folder and then reinstall it. Same issue when starting fresh.
Any ideas what the error might be?
Hassio 1.1
Supervisor 0.77
Hass: 0.60
Homebridge: 2.2.0
Interesting, since Supervisor 0.77 came out last night.
What URL are you using to access your Home Assistant in the /config/homebridge/config.json
file?
Last night? I did a restart of host yesterday, but Homebridge worked after that. Supervisor might have been updated in the restart.
Anyway, host config is "host": "http://hassio/homeassistant"
I did find some logs now for Supervisor where it does not seem to pleased that the internal IP does not match the one of the certificate. Remote access to hass work though.
17-12-26 10:47:26 ERROR (MainThread) [asyncio] Unhandled exception in event loop
File "uvloop/handles/stream.pyx", line 784, in uvloop.loop.__uv_stream_on_read_impl
File "uvloop/handles/stream.pyx", line 563, in uvloop.loop.UVStream._on_read
File "/usr/lib/python3.6/asyncio/sslproto.py", line 503, in data_received
ssldata, appdata = self._sslpipe.feed_ssldata(data)
File "/usr/lib/python3.6/asyncio/sslproto.py", line 201, in feed_ssldata
self._sslobj.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 694, in do_handshake
match_hostname(self.getpeercert(), self.server_hostname)
File "/usr/lib/python3.6/ssl.py", line 331, in match_hostname
% (hostname, dnsnames[0]))
ssl.CertificateError: hostname '172.30.32.1' doesn't match 'hass.perbjorn.com'
17-12-26 10:47:26 ERROR (MainThread) [hassio.api.proxy] Client error on API states request Cannot connect to host 172.30.32.1:8123 ssl:True [CertificateError: ("hostname '172.30.32.1' doesn't match 'hass.perbjorn.com'",)].
Hmmm ok, I might check this with @pvizeli, apparently, your Home Assistant is running in SSL mode, which causes the proxy function (introduced in Supervisor 0.77) of Hassio to flip. (Certificates donāt match).
You might be able to work around this issue for now, by setting the external URL of your Home Assistant in the configuration.
Using external address worked fine! Will use in the mean time. Thanks for help!
No problem!
The issue has been identified and fixed. A new Supervisor will roll out as soon as possible.
Thanks to @pvizeli for the quick help and fix!
The issue has been fixed and an update for the Supervisor was released; v0.78.
To update to the latest Supervisor, go into the Hass.io panel, go to the Advanced section, and reload the Supervisor. An update button will appear after a couple of seconds.
After the upgrade, you should be able to restore the URL to the original one (recommended).
HI all,
Hope I have a related issue, if not please point me to the correct place:
my homebridge install does it all, except for being connected to the appā¦ The app sees HomeAssistant but just wonāt connect.
Iāve been able to see all events happen in the Homebridge log, and am connecting to āhttps://domain.duckdns.org:8123ā, ssl enabled. As a matter of fact, this has been about the only setting for HomeBridge to succeed in installing without errors
[2017-12-26 12:45:53] Homebridge is running on port 51826.
(aside from the ever appearing :
** WARNING: Detected another IPv4 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Havenāt forwarded the port 58126, which is as it is supposed to? Or should I forward?
Cheers,
Marius
