Community Hass.io Add-on: Homebridge
I’ve corrected the date error… as shown in your picture :wink:
Hello guys!
I’ve noticed that these new accessories has appeared after the latest update:
I like this idea of controlling the air flow power on my climates accessories but would like to hide them out. Is it possible? I have now one of these “fans” for each climate configured on my HA setup.
I have not set “fan” for supported_types on my config, neither on my HA devices list on the dev tab., that is why I am confused.
Thanks a lot!
Hi, I am trying to install the ‘Homebridge’ addon for the first time on HA and getting the following error. I am new to HA and kind of clueless on how to fix this versioning issue.
Thanks.
    [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 10-homebridge: applying...
[fix-attrs.d] 10-homebridge: exited 0.
[fix-attrs.d] 20-dbus: applying...
[fix-attrs.d] 20-dbus: exited 0.
[fix-attrs.d] 30-avahi: applying...
[fix-attrs.d] 30-avahi: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: Homebridge v2.4.0
 HomeKit support for your Home Assistant instance using Homebridge
 By: Franck Nijhof <[email protected]>
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 03-version-requirements.sh: executing...
Version 103 is not a valid version.Error: "No Major.Minor.Patch elements found"FATAL: You Supervisor version is: 103
FATAL: This add-on requires: >=0.82.0
FATAL: Please consider upgrading.
[cont-init.d] 03-version-requirements.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
This has been broken due to a change in the output of the Hass.io Supervisor API, which is shipped with Supervisor 103.
This change has been reverted in Supervisor 103.1. To update do the following:
If you are running 103 or older, an update button would appear right after. Hit it, to install the Supervisor 103.1. After this is done, everything will function normally again.
Thank you so much, I couldn’t figure out what happened! Cheers bro!
I’m still getting a error, supervisor is updated
500 Internal Server Error
Server got itself in trouble ^ SyntaxError: Unexpected token < in JSON at position 0 at JSON.parse () at Request.request [as _callback] (/usr/lib/node_modules/homebridge-homeassistant/index.js:101:38) at Request.self.callback (/usr/lib/node_modules/homebridge-homeassistant/node_modules/request/request.js:186:22) at emitTwo (events.js:126:13) at Request.emit (events.js:214:7) at Request. (/usr/lib/node_modules/homebridge-homeassistant/node_modules/request/request.js:1163:10) at emitOne (events.js:116:13) at Request.emit (events.js:211:7) at IncomingMessage. (/usr/lib/node_modules/homebridge-homeassistant/node_modules/request/request.js:1085:12) at Object.onceWrapper (events.js:313:30)
Is this from the broken supervisor?
Another issue appear indeed! Seems to be another one with the Supervisor. We are looking into it and wil get back to you asap.
Thanks man, I’ll check in the morning.
I appreciate you and your work!
Issue seems to be fixed now in Supervisor 103.2.
To upgrade:
Nice! HomeKit stopped working last night, now I was looking into a solution and directly found this thread (trough google) with the solution. I could have searched for hours without finding this one!
Thx alot, that’s what I love about Home-Assistant, things get solved quickly!
@frenck Thank you for the quick response. I might have bunch of more questions later as I am planing to using the homekit with non off-the-shelf products.
:tada: Release v2.5.0
This release is exciting, at least, for me it is. I’ve been working on this for months! And for you? Well, almost nothing changed :stuck_out_tongue:
So what did change? I’ve updated the workflows of the Community Hass.io Add-ons project. Things include:
  • Replaced CircleCI and CodeClimate. We are now using GitLab CI, backed by a couple of custom servers building and testing these add-ons.
  • All add-ons are now scanned during built and release by Clair to prevent security issues in our add-ons.
  • All add-ons are constantly scanned and monitored by Anchore.io. We will be notified immediately in case of security issues occur. (Major thanks to Anchore.io for helping us out!)
  • The add-ons repository is now entirely generated and automatically synced with all the add-ons. This ensures repositories are in sync, never forgotten and releases are almost instantly.
  • The base images that these add-ons are built on are entirely revised.
  • All add-ons have been updated to follow the Docker best practices. These are checked on every code change by GitLab CI.
  • All add-ons had maintenance. All software is updated to the latest and greatest and the documentation has been revisited.
  • There are now 2 bots in place on the GitHub project. The Add-ons Assistant is helping us out with the GitHub issues and pull requests and the AddonsBot is fully active taking care of updating code across the different GitHub Repositories.
  • We now have Edge & Beta add-ons repositories available. This allows everybody to test the latest and greatest (in case you don’t care about stability that much, or just wanna help out!)
  • I’ve removed all the PayPal, Bitcoin, … buttons. If you’d like to show your appreciation, then please, just buy me a coffee.
So that’s quite a lot, right? So what changed in this specific add-on?
Full Changelog
Added
  • Adds .yamllint configuration
  • Adds all architectures to add-on config
  • Adds Probot configuration
  • Adds add-on README template
  • Adds Gitlab CI
  • Adds option to run Homebridge insecure (#94)
Fixed
  • Fixes Markdownlint warning in License
  • Fixes hadolint warnings
  • Fixes Markdown linting warnings
Changed
  • Replaces Changelog with GitHub releases
  • Updates README
  • Upgrades Homebridge to v0.4.42
  • Upgrades add-on base image to v1.4.1
Removed
  • Removes CodeClimate
  • Removes CircleCI
Hey everyone, got working homebridge on my phone, then failed to connect mothers and fathers iphones. When I delete myself - I can add one phone, but then nothing, iphone just does not see the home assistant. What am I suppose to do to connect more than one device?
You can share your “home” with other people within the Home app.
Hello my homebridge on hassio is not working!
Is giving me a error!
Error loading shared library libexpat.so.1: Exec format error (needed by /usr/bin/dbus-daemon)
Error relocating /usr/bin/dbus-daemon
Originally posted in Discord but thought it may be more meaningful here…
Hello all, I am moving to hass.io from a raspbian install and I need to use the Homebridge add-on to control an old receiver through serial. With that I need to install the homebridge-denon-rs232
plugin along with the Homebridge add-on. From the logs I can see that the plugin requires [email protected] node package and tries to compile it from source but errors out on:
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
…/src/serialport_unix.cpp:32:26: fatal error: linux/serial.h: No such file or directory
#include <linux/serial.h>
Is it possible to do what I am trying to with hass.io? I am new to resinOS / hass.io so still working my way around not having direct terminal access…
Thanks for any help!
Resolved my issue by installing the linux-headers package as part of the homebridge add-on.
:tada: Release v2.6.0
Full Changelog
Changed
  • Moves build-env to latest
  • Upgrades base image to v1.4.2
  • Upgrades git to 2.15.2-r0
  • Rewrites GitLab CI
  • Upgrades base image in GitLab CI to 1.4.2
  • Updates Homebridge to 0.4.43
  • Updates node-gyp to 3.7.0
Hi guys,
Has anyone had success with legacy Lifx as yet? I’m getting the below :confused:
[2018-6-24 20:10:02] Loading 1 platforms...
[2018-6-24 20:10:02] [HomeAssistant] Initializing HomeAssistant platform...
[2018-6-24 20:10:02] [HomeAssistant] Fetching HomeAssistant devices.
[2018-6-24 20:10:02] Loading 0 accessories...
Load homebridge-lifx-lan.LifxLan
[2018-6-24 20:10:02] [homebridge-lifx-lan.LifxLan] Ignoring LIFX Platform setup because it is not configured
This is a pretty clear error message. You need to do some configuration. Please check the manual of the plugin you are trying to use.
PS: Use code blocks for logs, code and configurations
