Hi all,
I have a question is there a way to connect cloud9 to a bitbucket repo?
Hi all,
It supports git⦠it doesnāt matter where the repo is hosted.
Thanks Frenck,
Im not able to set it up can you show me how?
Could9 IDE is pretty well documented, so just do a quick Google search ![]()
Release v0.7.0This release adds authentication
against Home Assistant.
From now on, you have to log in with the same username and password and you use to log on to the Home Assistant frontend. No need to provide credentials in the add-on configuration anymore (so, those can be removed).
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck or https://buymeacoff.ee/frenck
I am not getting prompted for a user name and password. Config is default. I have tried in a incognito window.
Try cleaning the browser cache/cookies, or (just for test) try to open in anonymous modeā¦
Iām still using legacy PW. How do I login if I have no username and only a legacy password? Usernames as blank and homeassistant didnāt work. I tried to add a username and password to the config and it removes them.
You have to use the HA auth now - canāt use legacy anymore for this addon.
Has anyone had issues with scrolling in the terminal? It seems that oh my zsh is constantly detecting the terminal in applicationKeypad mode and interprets scrolling as the up and down keys. This in turn means that if you run something like hassio homeassistant check, you canāt scroll back up in the terminal window to see the output, it just scrolls through the previously used commands at the prompt. There have been a few other people with similar issues in other projects. Itās something to do with the terminal configuration, but Iām honestly not familiar enough with zsh to know how to diagnose it.
I have the same issue
Ditto that!
Iāve Just set this up and forwarded the port etc but Iām getting ā401 Access Deniedā when i click on āOPEN WEB UIā - does anyone know what I may be doing wrong please?
Tried both Chrome and Edge.
The system log
XX.XXX.XXX.XX - - [12/Dec/2018:15:21:39 +0000] āGET / HTTP/1.1ā 401 29 ā-ā āMozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.110 Safari/537.36ā
XX.XXX.XXX.XX - - [12/Dec/2018:15:21:40 +0000] āGET /favicon.ico HTTP/1.1ā 401 29 āhttps://XXXXX.duckdns.org:8321/ā āMozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.110 Safari/537.36ā
2018/12/12 15:21:52 [info] 761#761: *6 client closed connection while waiting for request, client: XX.XXX.XXX.XX, server: 0.0.0.0:8321
Thank you.
Release v0.7.1Added the colordiff package (thanks for the suggestion @adonnolux) and added support for serial devices.
Getting this message while starting the IDE :
Cloud9 is up and running
PANIC: unprotected error in call to Lua API (bad light userdata pointer)
INFO: Starting the NGINX daemon
HA is running on a Pine64 with Debian 64 bits⦠looks to be releated to nginx
found this (having the exact same problem): arm64: unprotected error in call to Lua API (bad light userdata pointer) Ā· Issue #2802 Ā· kubernetes/ingress-nginx Ā· GitHub
Anyway to update nginx in the IDE docker ?
Release v0.7.2This version contains an important security fix, and it is strongly recommend for ALL installations to be upgraded to this version immediately.
The authentication against Home Assistant can be bypassed by an anonymous and unauthorized user. The issue has been mitigated in the latest release.
To be clear on the subject: This is an add-on issue and not an issue with the Home Assistant authentication itself.
Exact details of the vulnerability are not disclosed in order to give our users the time to upgrade.
Thanks to Lars Larsson for responsibly reporting this vulnerability.
Affects all releases that support authentication against Home Assistant, add-on versions v0.7.0 and higher. Older releases are not affected.
Hi ! I donāt know if itās been answer or if itās the last addon update (Iām still new to home assistant and Hass.io)
I donāt have any user and password in my config but when I start the IDE addon it ask me a user/password
I canāt add a username and password my config is always override
I disable the ssl
It uses your home assistant username and password.
nop ⦠it doesnāt workā¦
This is my setup.
"log_level": "info",
"ssl": false,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"packages": [],
"init_commands": []
What does the logfile in the addon say?
