@frenck & @e1miran sorry for confusion, i meant the share folder.
/share/shinobi will map to /share/shinobi in the docker image, too many hours of work last week. I just opened bash on the docker and confirmed so you should be ok to put the font in that folder and then reference from the container.
Hi @frenck, just managed to stream an onvif camera through Shinobi!
I now realize I can’t access the onvif stream from my iPhone (works fine on my PC). The mjpeg does work apparently. I’m just wondering if you have some experience with that. Is it the iPhone to blame? Shinobi? both?
@frenck Any change you’ll be updating the Shinobi addon? Else I’ll switch to a regular version on my Ubuntu server, but I really love the effort you’re putting into the addons. Makes it so much easier!
There are a couple of issues, like videos not being deleted and not being able to mount a harddrive in Hass.io
Yep, it is the last add-on on the list. Unfortunately I was unable to get it out before my vacation. I expect this week to be picking up on all notification and other stuff and aim for a release next week.
So here is a sad message. I’ve been working on this add-on quite some time lately. The more energy I put in to it, the more it becomes clear that this add-on has no future.
Therefore I have decided to drop this add-on in the near future and mark it deprecated immediately.
Reasoning:
The Shinobi project is not maturing. As a matter of fact, IMHO the quality of the project is degrading the last couple of months. Have you ever looked at the Shinobi source code? If you are a little into programming, you should. This is Shinobi (which is actually a single Javascript file): camera.js
I’ve spent a serious amount of time getting the add-on updated to the latest and greatest. It kind works, but has got several issues (for example, it fires MySQL queries at the SQLite database and therefore just fails). The road for getting at this point… was not fun at all.
The add-on has been marked experimental from the beginning and still is/was.
With the growth of the Community Add-ons Project, the expectations of it grow as well. Shinobi just isn’t going to live up to that expectation.
So now what?
The add-on will be available for another month or so. But because of upcoming changes to Hassio it would probably stop functioning sooner.
I’m planning on releasing alternative add-ons for handling CCTV’s on your system, but as with every add-on, building one can take some time.
Hi @frenck
Thanks for your efforts here.
After a few years of using Zoneminder and ditching it (due to unreliability), I did try Shinobi for a while but just couldn’t make it work for some of my cams.
I then tried MotionEye - I run it as a docker image on my Mac mini, and point the recorded video to my Drobo. It has been working reliably for the last 6 months or so - very solid. And it does remove old files (older than 30 days in my case)
Maybe that could be an alternative. My only issue is I can’t make it talk to my cheap Digoo M1Q cameras - my daughter has them in her bird aviary. Probably more my problem than MotionEyes - I’ve yet to figure it out.
This add-on was deprecated earlier and the time has come to remove it.
The sources stay available on GitHub, in case someone want to build it manually (or fork it).
If you are looking for an alternative, I can definitely recommend: MotionEye
