I have a Conbee II that originally worked fine. After some time, it started to give me issues were it will disconnect and then, reconnect. If I create a new HA installation, I can get the Conbee II stick to work fine until I restart the server. It isn’t always the first restart that initializes this error either. I experienced similar behavior of the stick working fine and after disconnecting/reconnecting it, it begins to disconnect/reconnect in a loop by itself on a separate computer (Windows 10) with only deCONZ loaded on it.
This is the error I get in HA on loop:
cdc_acm 2-2:1.0: failed to set dtr/rts
Server info:
Windows 10 running Docker for Ubuntu holding the server
Everything is always up-to-date when I experience this issue since my solution in the past was to recreate the server. (I was having other issues along with this which kept me from identifying this as the problem. As far as I can tell, this is the only issue left.)
Quick side note: If running this on a raspberry pi would resolve this issue, please let me know.
Thanks for any help you can provide!
