Yesterday, after doing a simple restart, suddenly hassio didn’t come back online. The front-end wouldn’t load so it seemed, but after doing a lot of research it seems more is going on.
Because I couldn’t get to my files (didn’t have Samba nor SSH installed) I had to restore an older backup from February. I reinstalled hassio by overwriting the SD card with a fresh install. After installing Samba I copied the old backup file in the backup folder. It wasn’t discovered at first, but then I made a full backup using the hassio interface. I deleted the file that popped up in the backup folder and gave my own backup file that name. Then I was able to restore the backup file.
Now the strange stuff begins. The backup seems to be succesfully restored. I can still access my files with samba. I see many files, including the config files, are replaced with the backup files. Though, again the webapplication won’t load. The browser says “Err_connection_refused”.
When opening the log file through Samba there are no errors that make sense. Only some connection error with my chromecast. That shouldn’t keep the front-end from loading.
In my backup file there was SSL implemented, so of course I tried connecting with my own domain, using https. No result.
[...] Many starting up messages...
2019-03-03 12:39:49 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 0.3 seconds.
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=device_tracker>
2019-03-03 12:39:49 DEBUG (MainThread) [pytradfri.api.aiocoap_api] Status: 2.05 Content, Received: []
2019-03-03 12:39:49 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.owntracks
2019-03-03 12:39:49 DEBUG (SyncWorker_6) [pyHS100.protocol] > (33) {"system": {"get_sysinfo": null}}
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Finished group request in 0.058 seconds
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.keuken, old_state=None, new_state=<state light.keuken=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Keuken, supported_features=63 @ 2019-03-03T12:39:49.564360+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.group_for_wakeup, old_state=None, new_state=<state light.group_for_wakeup=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Group for wakeup, supported_features=63 @ 2019-03-03T12:39:49.568211+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.kantoor, old_state=None, new_state=<state light.kantoor=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Kantoor, supported_features=63 @ 2019-03-03T12:39:49.572004+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.woonkamer, old_state=None, new_state=<state light.woonkamer=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Woonkamer, supported_features=63 @ 2019-03-03T12:39:49.575728+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.slaapkamer, old_state=None, new_state=<state light.slaapkamer=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Slaapkamer, supported_features=63 @ 2019-03-03T12:39:49.579688+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.kantoor_2, old_state=None, new_state=<state light.kantoor_2=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Kantoor, supported_features=63 @ 2019-03-03T12:39:49.583475+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.overloop, old_state=None, new_state=<state light.overloop=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Overloop, supported_features=63 @ 2019-03-03T12:39:49.587363+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.entertainmentruimte_1, old_state=None, new_state=<state light.entertainmentruimte_1=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Entertainmentruimte 1, supported_features=63 @ 2019-03-03T12:39:49.591243+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.group_1, old_state=None, new_state=<state light.group_1=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Group 1, supported_features=63 @ 2019-03-03T12:39:49.595040+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.group_2, old_state=None, new_state=<state light.group_2=off; min_mireds=153, max_mireds=500, is_hue_group=True, friendly_name=Group 2, supported_features=63 @ 2019-03-03T12:39:49.598922+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=group, service=set, service_data=object_id=all_lights, name=all lights, visible=False, entities=['light.entertainmentruimte_1', 'light.group_1', 'light.group_2', 'light.group_for_wakeup', 'light.kantoor', 'light.kantoor_2', 'light.keuken', 'light.overloop', 'light.slaapkamer', 'light.woonkamer']>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Finished light request in 0.104 seconds
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Hue color lamp 1: GamutType(red=XYPoint(x=0.6915, y=0.3083), green=XYPoint(x=0.17, y=0.7), blue=XYPoint(x=0.1532, y=0.0475))
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Hue color lamp 2: GamutType(red=XYPoint(x=0.6915, y=0.3083), green=XYPoint(x=0.17, y=0.7), blue=XYPoint(x=0.1532, y=0.0475))
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Hue color lamp 3: GamutType(red=XYPoint(x=0.6915, y=0.3083), green=XYPoint(x=0.17, y=0.7), blue=XYPoint(x=0.1532, y=0.0475))
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Hue color lamp 4: GamutType(red=XYPoint(x=0.6915, y=0.3083), green=XYPoint(x=0.17, y=0.7), blue=XYPoint(x=0.1532, y=0.0475))
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Hue color lamp 5: GamutType(red=XYPoint(x=0.6915, y=0.3083), green=XYPoint(x=0.17, y=0.7), blue=XYPoint(x=0.1532, y=0.0475))
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Hue ambiance spot 1: None
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Hue ambiance spot 2: None
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Dimmable light 1: None
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Dimmable light 2: None
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.components.hue.light] Color gamut of Color temperature light 1: None
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=None, new_state=<state group.all_lights=off; entity_id=('light.entertainmentruimte_1', 'light.group_1', 'light.group_2', 'light.group_for_wakeup', 'light.kantoor', 'light.kantoor_2', 'light.keuken', 'light.overloop', 'light.slaapkamer', 'light.woonkamer'), order=11, auto=True, friendly_name=all lights, hidden=True @ 2019-03-03T12:39:49.627553+01:00>>
2019-03-03 12:39:49 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.hue entity: light.color_temperature_light_1
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.color_temperature_light_1, old_state=None, new_state=<state light.color_temperature_light_1=off; min_mireds=153, max_mireds=500, friendly_name=Color temperature light 1, supported_features=43 @ 2019-03-03T12:39:49.634597+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.hue_color_lamp_5, old_state=None, new_state=<state light.hue_color_lamp_5=off; min_mireds=153, max_mireds=500, friendly_name=Slaapkamer, supported_features=63 @ 2019-03-03T12:39:49.638593+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.hue_color_lamp_2, old_state=None, new_state=<state light.hue_color_lamp_2=off; min_mireds=153, max_mireds=500, friendly_name=Televisie, supported_features=63 @ 2019-03-03T12:39:49.642666+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.hue_ambiance_spot_1, old_state=None, new_state=<state light.hue_ambiance_spot_1=unavailable; friendly_name=Spot kamerkant, supported_features=43 @ 2019-03-03T12:39:49.646627+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.hue_color_lamp_3, old_state=None, new_state=<state light.hue_color_lamp_3=off; min_mireds=153, max_mireds=500, friendly_name=Kantoor, supported_features=63 @ 2019-03-03T12:39:49.650725+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.hue_ambiance_spot_2, old_state=None, new_state=<state light.hue_ambiance_spot_2=unavailable; friendly_name=Spot raamkant, supported_features=43 @ 2019-03-03T12:39:49.654617+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.hue_color_lamp_4, old_state=None, new_state=<state light.hue_color_lamp_4=off; min_mireds=153, max_mireds=500, friendly_name=Kantoor, supported_features=63 @ 2019-03-03T12:39:49.658779+01:00>>
2019-03-03 12:39:49 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.hue entity: light.dimmable_light_2
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmable_light_2, old_state=None, new_state=<state light.dimmable_light_2=off; friendly_name=Dimmable light 2, supported_features=41 @ 2019-03-03T12:39:49.665529+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.hue_color_lamp_1, old_state=None, new_state=<state light.hue_color_lamp_1=off; min_mireds=153, max_mireds=500, friendly_name=Salontafel, supported_features=63 @ 2019-03-03T12:39:49.669556+01:00>>
2019-03-03 12:39:49 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new light.hue entity: light.dimmable_light_1
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmable_light_1, old_state=None, new_state=<state light.dimmable_light_1=off; friendly_name=Dimmable light 1, supported_features=41 @ 2019-03-03T12:39:49.676822+01:00>>
2019-03-03 12:39:49 DEBUG (SyncWorker_6) [pyHS100.protocol] < (613) {"system":{"get_sysinfo":{"sw_ver":"1.5.4 Build 180815 Rel.121440","hw_ver":"2.0","type":"IOT.SMARTPLUGSWITCH","model":"HS110(EU)","mac":"D8:0D:17:3E:7A:11","dev_name":"Smart Wi-Fi Plug With Energy Monitoring","alias":"Wasmachine","relay_state":0,"on_time":0,"active_mode":"none","feature":"TIM:ENE","updating":0,"icon_hash":"","rssi":-56,"led_off":0,"longitude_i":47044,"latitude_i":525197,"hwId":"044A516EE63C875F9458DA25C2CCC5A0","fwId":"00000000000000000000000000000000","deviceId":"8006A5E6A508A4A719DC6E518FA8BB1B1AFB3620","oemId":"1998A14DAA86E4E001FD7CAF42868B5E","next_action":{"type":-1},"err_code":0}}}
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.verlichting_slaapkamer, old_state=<state group.verlichting_slaapkamer=unknown; entity_id=('light.hue_color_lamp_5',), order=5, view=True, friendly_name=Verlichting slaapkamer, icon=mdi:hotel, hidden=True @ 2019-03-03T12:39:49.160060+01:00>, new_state=<state group.verlichting_slaapkamer=off; entity_id=('light.hue_color_lamp_5',), order=5, view=True, friendly_name=Verlichting slaapkamer, icon=mdi:hotel, hidden=True @ 2019-03-03T12:39:49.684416+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.verlichting_woonkamer, old_state=<state group.verlichting_woonkamer=unknown; entity_id=('light.hue_color_lamp_1', 'light.hue_color_lamp_2', 'light.hue_color_lamp_3'), order=1, view=True, friendly_name=Verlichting woonkamer, icon=mdi:chair, hidden=True @ 2019-03-03T12:39:48.688305+01:00>, new_state=<state group.verlichting_woonkamer=off; entity_id=('light.hue_color_lamp_1', 'light.hue_color_lamp_2', 'light.hue_color_lamp_3'), order=1, view=True, friendly_name=Verlichting woonkamer, icon=mdi:chair, hidden=True @ 2019-03-03T12:39:49.689093+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.verlichting_kantoor, old_state=<state group.verlichting_kantoor=unknown; entity_id=('light.hue_color_lamp_4',), order=4, view=True, friendly_name=Verlichting kantoor, icon=mdi:desktop-tower-monitor, hidden=True @ 2019-03-03T12:39:49.155075+01:00>, new_state=<state group.verlichting_kantoor=off; entity_id=('light.hue_color_lamp_4',), order=4, view=True, friendly_name=Verlichting kantoor, icon=mdi:desktop-tower-monitor, hidden=True @ 2019-03-03T12:39:49.694068+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=group, service=set, service_data=object_id=all_lights, name=all lights, visible=False, entities=['light.color_temperature_light_1', 'light.dimmable_light_1', 'light.dimmable_light_2', 'light.entertainmentruimte_1', 'light.group_1', 'light.group_2', 'light.group_for_wakeup', 'light.hue_ambiance_spot_1', 'light.hue_ambiance_spot_2', 'light.hue_color_lamp_1', 'light.hue_color_lamp_2', 'light.hue_color_lamp_3', 'light.hue_color_lamp_4', 'light.hue_color_lamp_5', 'light.kantoor', 'light.kantoor_2', 'light.keuken', 'light.overloop', 'light.slaapkamer', 'light.woonkamer']>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.verlichting_boven, old_state=<state group.verlichting_boven=unknown; entity_id=('group.verlichting_kantoor', 'group.verlichting_slaapkamer'), order=7, view=True, friendly_name=Verlichting boven, icon=mdi:arrow-up-circle, hidden=True @ 2019-03-03T12:39:49.186122+01:00>, new_state=<state group.verlichting_boven=off; entity_id=('group.verlichting_kantoor', 'group.verlichting_slaapkamer'), order=7, view=True, friendly_name=Verlichting boven, icon=mdi:arrow-up-circle, hidden=True @ 2019-03-03T12:39:49.705348+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.verlichting_beneden, old_state=<state group.verlichting_beneden=unknown; entity_id=('group.verlichting_eetruimte', 'group.verlichting_keuken', 'group.verlichting_woonkamer'), order=6, view=True, friendly_name=Verlichting beneden, icon=mdi:arrow-down-circle, hidden=True @ 2019-03-03T12:39:49.168090+01:00>, new_state=<state group.verlichting_beneden=off; entity_id=('group.verlichting_eetruimte', 'group.verlichting_keuken', 'group.verlichting_woonkamer'), order=6, view=True, friendly_name=Verlichting beneden, icon=mdi:arrow-down-circle, hidden=True @ 2019-03-03T12:39:49.708978+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=off; entity_id=('light.entertainmentruimte_1', 'light.group_1', 'light.group_2', 'light.group_for_wakeup', 'light.kantoor', 'light.kantoor_2', 'light.keuken', 'light.overloop', 'light.slaapkamer', 'light.woonkamer'), order=11, auto=True, friendly_name=all lights, hidden=True @ 2019-03-03T12:39:49.627553+01:00>, new_state=<state group.all_lights=off; entity_id=('light.color_temperature_light_1', 'light.dimmable_light_1', 'light.dimmable_light_2', 'light.entertainmentruimte_1', 'light.group_1', 'light.group_2', 'light.group_for_wakeup', 'light.hue_ambiance_spot_1', 'light.hue_ambiance_spot_2', 'light.hue_color_lamp_1', 'light.hue_color_lamp_2', 'light.hue_color_lamp_3', 'light.hue_color_lamp_4', 'light.hue_color_lamp_5', 'light.kantoor', 'light.kantoor_2', 'light.keuken', 'light.overloop', 'light.slaapkamer', 'light.woonkamer'), order=11, auto=True, friendly_name=all lights, hidden=True @ 2019-03-03T12:39:49.627553+01:00>>
2019-03-03 12:39:49 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.verlichting_alles, old_state=<state group.verlichting_alles=unknown; entity_id=('group.verlichting_beneden', 'group.verlichting_boven'), order=8, view=True, friendly_name=Alle verlichting, icon=mdi:lightbulb-on-outline, hidden=True @ 2019-03-03T12:39:49.194667+01:00>, new_state=<state group.verlichting_alles=off; entity_id=('group.verlichting_beneden', 'group.verlichting_boven'), order=8, view=True, friendly_name=Alle verlichting, icon=mdi:lightbulb-on-outline, hidden=True @ 2019-03-03T12:39:49.717898+01:00>>
2019-03-03 12:39:50 DEBUG (SyncWorker_6) [pyHS100.protocol] < (613) {"system":{"get_sysinfo":{"sw_ver":"1.5.4 Build 180815 Rel.121440","hw_ver":"2.0","type":"IOT.SMARTPLUGSWITCH","model":"HS110(EU)","mac":"D8:0D:17:3E:7A:11","dev_name":"Smart Wi-Fi Plug With Energy Monitoring","alias":"Wasmachine","relay_state":0,"on_time":0,"active_mode":"none","feature":"TIM:ENE","updating":0,"icon_hash":"","rssi":-56,"led_off":0,"longitude_i":47044,"latitude_i":525197,"hwId":"044A516EE63C875F9458DA25C2CCC5A0","fwId":"00000000000000000000000000000000","deviceId":"8006A5E6A508A4A719DC6E518FA8BB1B1AFB3620","oemId":"1998A14DAA86E4E001FD7CAF42868B5E","next_action":{"type":-1},"err_code":0}}}
2019-03-03 12:39:50 DEBUG (SyncWorker_6) [pyHS100.protocol] > (34) {"emeter": {"get_realtime": null}}
2019-03-03 12:39:50 DEBUG (SyncWorker_6) [pyHS100.protocol] < (107) {"emeter":{"get_realtime":{"voltage_mv":232209,"current_ma":37,"power_mw":0,"total_wh":2819,"err_code":0}}}
2019-03-03 12:39:50 DEBUG (SyncWorker_6) [pyHS100.protocol] > (33) {"system": {"get_sysinfo": null}}
2019-03-03 12:39:50 DEBUG (SyncWorker_6) [pyHS100.protocol] > (55) {"emeter": {"get_daystat": {"month": 3, "year": 2019}}}
2019-03-03 12:39:50 DEBUG (SyncWorker_6) [pyHS100.protocol] < (192) {"emeter":{"get_daystat":{"day_list":[{"year":2019,"month":3,"day":1,"energy_wh":0},{"year":2019,"month":3,"day":2,"energy_wh":0},{"year":2019,"month":3,"day":3,"energy_wh":0}],"err_code":0}}}
2019-03-03 12:39:50 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.wasmachine, old_state=None, new_state=<state switch.wasmachine=off; current_power_w=0.00, total_energy_kwh=2.819, voltage=232.2, current_a=0.04, today_energy_kwh=0.000, friendly_name=Wasmachine @ 2019-03-03T12:39:50.556832+01:00>>
2019-03-03 12:39:50 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=group, service=set, service_data=object_id=all_switches, name=all switches, visible=False, entities=['switch.wasmachine']>
2019-03-03 12:39:50 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, old_state=None, new_state=<state group.all_switches=off; entity_id=('switch.wasmachine',), order=12, auto=True, friendly_name=all switches, hidden=True @ 2019-03-03T12:39:50.571596+01:00>>
2019-03-03 12:39:50 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
2019-03-03 12:39:50 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
2019-03-03 12:39:50 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=toggle>
2019-03-03 12:39:50 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 1.3 seconds.
2019-03-03 12:39:50 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=switch>
2019-03-03 12:39:50 INFO (MainThread) [homeassistant.loader] Loaded zwave.switch from homeassistant.components.zwave.switch
2019-03-03 12:39:50 INFO (MainThread) [homeassistant.components.switch] Setting up switch.zwave
2019-03-03 12:39:50 INFO (MainThread) [homeassistant.loader] Loaded tradfri.switch from homeassistant.components.tradfri.switch
2019-03-03 12:39:50 INFO (MainThread) [homeassistant.components.switch] Setting up switch.tradfri
2019-03-03 12:39:50 DEBUG (MainThread) [pytradfri.api.aiocoap_api] Executing 192.168.178.24 get ['15001']
2019-03-03 12:39:50 DEBUG (MainThread) [coap] Sending message <aiocoap.Message at 0x7042a8b0: Type.CON GET (ID 60945, token b'\x00\x00\xeb\xee') remote <aiocoap.transports.tinydtls.DTLSClientConnection object at 0x70576dd0>, 3 option(s)>
2019-03-03 12:39:50 DEBUG (MainThread) [coap] Exchange added, message ID: 60945.
2019-03-03 12:39:50 DEBUG (MainThread) [coap.requester] Timeout is 93.0
2019-03-03 12:39:50 DEBUG (MainThread) [coap.requester] Sending request - Token: 0000ebee, Remote: <aiocoap.transports.tinydtls.DTLSClientConnection object at 0x70576dd0>
2019-03-03 12:39:50 DEBUG (MainThread) [coap] Incoming message <aiocoap.Message at 0x70576f90: Type.ACK 2.05 Content (ID 60945, token b'\x00\x00\xeb\xee') remote <aiocoap.transports.tinydtls.DTLSClientConnection object at 0x70576dd0>, 2 option(s), 2 byte(s) payload>
2019-03-03 12:39:50 DEBUG (MainThread) [coap] New unique message received
2019-03-03 12:39:50 DEBUG (MainThread) [coap] Exchange removed, message ID: 60945.
2019-03-03 12:39:50 DEBUG (MainThread) [coap] Received Response: <aiocoap.Message at 0x70576f90: Type.ACK 2.05 Content (ID 60945, token b'\x00\x00\xeb\xee') remote <aiocoap.transports.tinydtls.DTLSClientConnection object at 0x70576dd0>, 2 option(s), 2 byte(s) payload>
2019-03-03 12:39:50 DEBUG (MainThread) [pytradfri.api.aiocoap_api] Status: 2.05 Content, Received: []
2019-03-03 12:39:51 ERROR (MainThread) [homeassistant.components.hue] Error connecting to the Hue bridge at 192.168.178.20
2019-03-03 12:39:54 DEBUG (SyncWorker_11) [pychromecast.discovery] get_info_from_service resolved service Chromecast-1793ed462f1a8ee6357021d90d4c38b2._googlecast._tcp.local. to service_info ServiceInfo(type='_googlecast._tcp.local.', name='Chromecast-1793ed462f1a8ee6357021d90d4c38b2._googlecast._tcp.local.', address=b'\xc0\xa8\xb2\x19', port=8009, weight=0, priority=0, server='1793ed46-2f1a-8ee6-3570-21d90d4c38b2.local.', properties={b'id': b'1793ed462f1a8ee6357021d90d4c38b2', b'cd': b'648005B1767B2D078B9DC0DC43E5D2FF', b'rm': b'3376AAEE704DE13D', b've': b'05', b'md': b'Chromecast', b'ic': b'/setup/icon.png', b'fn': b'Chromecast', b'ca': b'4101', b'st': b'0', b'bs': b'FA8FCA8CEB73', b'nf': b'1', b'rs': False})
2019-03-03 12:39:54 DEBUG (SyncWorker_11) [pychromecast.socket_client] [Chromecast:8009] Resolved service Chromecast-1793ed462f1a8ee6357021d90d4c38b2._googlecast._tcp.local. to 192.168.178.25:8009
2019-03-03 12:39:54 DEBUG (SyncWorker_11) [pychromecast.socket_client] [Chromecast:8009] Connecting to 192.168.178.25:8009
Any ideas what to do next?
Thanks in advance!
Roy
