Hi. I am very new to Home Assistant and have been reading the documentation and forums but I’m stuck.
I’m running hass.io on a Pi3 with a Razberry board.
I have got Home Assistant running and also the Z-Wave component. If you look at the attached image you can see Z-Wave and on the right Light and Switch. The devices under Light and Switch are Z-wave devices and I can control them from here. These were all configured automatically.
The question I have is how do I control my Garage Door Controller and put it under Switch?
Did you include it the garage door controller using secure inclusion? In the Z-Wave control panel this means using the “ADD NODE SECURE” button, not the “ADD NODE” button. Sometimes Z-Wave garage door controllers require this. You will need to set a network key to do this. https://www.home-assistant.io/docs/z-wave/installation/#network_key
There is an older thread that mentions this controller, and they are using it like a switch w/o Barrier support: Aeon Labs ZW062 Garage Door controller - stateful commands. I also have a Linear (broken one) so that threw me off. Maybe there’s a newer version that disable that behavior. The device does support the Binary Switch class for some reason.
Yes, when it’s running under Z-Wave-Me it sees it as a switch. It also doesn’t fully complete the interview and it’s the BarrierOperator that doesn’t complete.
