Did you see it?
"open_position": 100,
"close_position": 0,
"shading_position": 0,
The roller blind has moved to the shading position. And this is set to 0.
Did you see it?
ok got it, i changed the shading position from 25% to 0% and for me it was supposed not to be in condition for shading. I will try again to see if i can enable/disable the shading as expected.
Thanks for your help
But I need the trace of 8:00.
Shit - already gone for today. Will check tomorrow
Hi, I have an error when I try to import the blueprint into my home assistant automation
I get the following error :
Invalid blueprint: extra keys not allowed @ data[‘blueprint’][‘input’][‘actions_section’][‘collapsed’] etc…
The error is relly long. I don’t relly know what could happend, I can import some other blueprint without any issue… If someone have an idea.
Thx a lot
Please update your core version. See latest changelog.
Edit: I have now also included a note in the first post.
Thx a lot
i have the latest HA Core and Blueprint installed. The shutters do not drive as before the update
One example where the shutter is set to drive down between 17:00 to 19:00 depending on the brightness.
use_blueprint:
path: hvorragend/cover_control_automation.yaml
input:
blind: cover.hm_lc_bl1_fm_oeq0257910
auto_options:
- auto_up_enabled
- auto_down_enabled
- auto_brightness_enabled
cover_status_options: cover_helper_enabled
cover_status_helper: input_text.rollo_kinder_sz_cover_status
time_up_early: '06:45:00'
time_up_early_non_workday: '08:30:00'
time_up_late: '08:00:00'
time_up_late_non_workday: '09:30:00'
time_down_early: '17:00:00'
time_down_early_non_workday: '17:00:00'
time_down_late: '19:00:00'
time_down_late_non_workday: '19:30:00'
default_brightness_sensor: sensor.wetterstation_lichtintensitat
brightness_up: 100
brightness_down: 20
workday_sensor: binary_sensor.workday_sensor
resident_sensor: input_boolean.rollladen_automatik_schalter
contact_sensor: binary_sensor.kinder_schlafzimmer_fenster
ventilate_position: 20
shading_forecast_sensor: weather.forecast_home
ignore_after_manual_config:
- ignore_ventilation_after_manual
17:00:00 - Vor 2 Stunden
We have exceeded 19:00 now but nothing happened.
It started the drive down with the non workday time 19:30 but we have a workday now.
The same i observed with the drive up. It will always take the non workday time on workday, too.
I had the same problem this morning. The workday_sensor had not updated, it was still the weekend. I had to reload the workday_sensor integration. Bug in 2024.06.x ?!
That’s right. Simply reload the integration of the workday_sensor. Then the sensor should come on
It is not a CCA bug.
Please see: Work Day Integration Issue · Issue #119248 · home-assistant/core · GitHub
Will be fixed in 2024.6.2
I agree, right after i just reloaded the workday sensor CCA is working again. So nothing to see here
Hello, I have now created a cover status helper for all the shutters. It worked once, but now the shading is not working again. I have even more problems now because the shutters are also being lowered at 10 p.m. even though the lux value is still over 2 lux. They should only be lowered when the lux value is under 2 lux.
alias: ES_Ro_Fest_Links
description: ""
use_blueprint:
input:
blind: cover.hmipw_drbl4_00165f29980809_ch2
auto_options:
- auto_up_enabled
- auto_down_enabled
- auto_shading_enabled
cover_status_helper: input_text.ro_es_fest_links
close_position: 30
shading_position: 70
default_brightness_sensor: sensor.raspberry_sv_wm_lux
brightness_down: 2
brightness_up: 5
shading_brightness_sensor: sensor.raspberry_sv_wm_lux
shading_sun_brightness_start: 8000
shading_sun_brightness_end: 5000
shading_azimuth_start: 200
shading_azimuth_end: 300
shading_elevation_max: 90
shading_temperatur_sensor1: sensor.raspberry_sv_wm_temperatur
shading_min_temperatur1: 2
time_up_early: "04:00:00"
time_up_early_non_workday: "05:00:00"
time_up_late: "05:00:00"
time_up_late_non_workday: "07:00:00"
time_down_early: "22:00:00"
time_down_early_non_workday: "23:00:00"
time_down_late: "00:00:00"
time_down_late_non_workday: "00:00:00"
Traces
https://drive.google.com/file/d/10j5SLa3Nt9ZkoB_Ix6gVd83PqtAOV6Cg/view?usp=sharing, https://drive.google.com/file/d/1Glr-DKRKuxehTgI-rrONUHag5DuTwfer/view?usp=sharing, https://drive.google.com/file/d/1zGoNUOlQ_-byM4O-4TfumJXKOKskGjKc/view?usp=sharing
I cannot access your traces.
This works differently. 22:00 is the default value for the latest time. Then it doesn’t matter how bright it is.
Do you now have access to the traces?
But I set the late time to 11 p.m. on Workday and 12 a.m. on not Workday.
