I don’t see how this can be implemented with CCA. However, I also believe that CCA is not needed for this. Not everything has to run via automation.
The problem will be that you have to reverse the values for Open (100) and Close (0). This will not work. I have permanently linked the value 0 to the close status.
Or you have hardware in which you can invert the mode.
Okay thanks. I thought it would be possible to add something else like: TV position. This means that the roller shutters then move into the position that is stored here. This is actually a common problem where the light incidence is disturbing when watching television. Would have thought it would be cool if this happened automatically
in this case make another automation without CCA, like: when tv on than shutter down otherwise open! Maybe its neccessary to stop the normal CCA automation for that shutter during the tv is on, to prevent opening (additional action in the new automation!)!
I have some issue in configuring sun shading. I am not able to make it work and i would like some help.
Here is my configuration :
alias: Chambre Léon
description: ""
use_blueprint:
path: hvorragend/cover_control_automation.yaml
input:
blind: cover.volet_leon_low_speed
auto_options:
- auto_up_enabled
- auto_down_enabled
- auto_sun_enabled
- auto_shading_enabled
ignore_after_manual_config:
- ignore_shading_after_manual
reset_override_config: reset_timeout
reset_override_time: "00:00:00"
sun_elevation_up: -5
sun_elevation_down: -5
drive_delay_random: 55
shading_azimuth_start: 60
shading_elevation_min: 5
shading_temperatur_sensor1: sensor.temperature_chambre_leon_temperature
shading_min_temperatur1: 22
shading_temperatur_sensor2: sensor.viking_0203502038_35_01_temperature
shading_forecast_sensor: weather.forecast_home_2
shading_forecast_type: hourly
shading_weather_conditions:
- sunny
- partlycloudy
- clear
shading_waitingtime_end: 150
reset_override_timeout: 120
time_control: time_control_input
shading_min_temperatur2: 18
shading_forecast_temp: 18
shading_waitingtime_start: 150
check_config: true
time_up_early_non_workday: "09:00:00"
time_down_late: "23:00:00"
time_down_late_non_workday: "23:00:00"
shading_azimuth_end: 230
time_up_early: "07:00:00"
time_up_late: "09:00:00"
time_up_late_non_workday: "11:00:00"
check_config_debuglevel: debug
Thank you for your help.
Shading does not work for me, as well. Even when I force shading, nothing happens.
Please read the descriptions:
Then you should show me something so that I can help you. A blanket statement like “doesn’t work” doesn’t help anyone.
I am very sorry. I do not get any Log entries. I do not want to use the other optionas besides shading for now. But I have enabled them according to your post above. To be honest I do not even know what information you need and where to get it.
alias: test rolladen Arbeitszimmer
description: ''
use_blueprint:
input:
blind: cover.arbeitszimmer_rolladen
open_tilt_position: 100
close_tilt_position: 0
shading_position: 20
shading_tilt_position: 20
auto_options:
- auto_up_enabled
- auto_down_enabled
- auto_brightness_enabled
- auto_sun_enabled
auto_shading_start_force: input_boolean.test_rolladen
ventilate_tilt_position: 10
ventilate_position: 10
time_control: time_control_disabled
Please take a look on my quoted link two posts above.
Note
For support reasons, I would like to point out the following requirements if you want to use the shading, ventilation, etc.
Got the helper, finally. But still no shading for me.
alias: Arbeitszimmer Rolladen Auto
description: ''
use_blueprint:
input:
auto_options:
- auto_up_enabled
- auto_down_enabled
- auto_sun_enabled
drive_time: 30
workday_sensor: binary_sensor.workday_sensor
ventilate_position: 90
ventilate_tilt_position: 90
shading_forecast_temp: -10
shading_min_temperatur1: 0
auto_shading_end_condition: []
auto_shading_start_condition:
- condition: or
conditions:
- condition: state
entity_id: device_tracker.thinkpad
state: home
- condition: state
entity_id: device_tracker.unifi_d8_d0_90_32_73_c2_default
state: home
enabled: false
shading_azimuth_start: 215
shading_azimuth_end: 270
shading_elevation_min: 15
individual_config:
- allow_shading_multiple_times
check_config: false
check_config_debuglevel: warning
cover_status_helper: input_text.position_arbeitszimmer_rolladen_helfer
brightness_up: 83310
Then please upload the trace of the trigger “t_si_1” and I will take a look.
If you don’t find the trigger, then it is not “shading time”.
Just to be sure: you didn’t run the automation yourself, did you?
Thank you very much for your help. I somehow forgot to tick the option to actually use the position helper. For testing I used the Force Activation Sun Shading trigger. Sorry for bothering you. Schönes Wochenende.
Kein Problem. Danke.
One more question. DO I need to Enable sun elevation control in order to use Sun Shading Elevation Minimum/Maximum Value? I do not want the covers to open or close according to sun elevation. Thanks a lot.
No, this is not necessary. The option only supplements the daily opening and closing of the roller blinds.
New update
2024.07.06:
- Fixed: Return to shading after ventilation #43
- Fixed: When closing the ventilation contact, do not move the roller blind if it is already in the correct position #102
- Updated: Trigger name renamed to make debugging easier for beginners
- Added: Additional information on when a Cover Status Helper is required
- Added: License notification and notice about the new Take Control-feature
I am still struggeling. Sorry. You write “These first two options must be activated so that the blinds can be opened or closed at all” .
Does it mean no automation works if the to options are not active?
I want to use shading, only. But I had this two options activated becausse of what you wrote in the instructions within the blueprint. Then yesterday at 20:00 the blinds closed despite i have activated “ Disable time control and all time triggers”.
Then I deactivated the first two options in “ Automation options”. Today the blinds did not not closed according to the azimuth settings I made under “Sun Shading / Sun Protection”
Then please show me the trace.
