HI
Using the windspeed and temperature, im trying to create the WindChill formula in a template.
should be this:
Tgevoel(°C) = 13,12 + 0,6215Tlucht + 0.3965 (Tlucht - 28,676)*S10m0,16
valid for:
Tlucht = -46 … +10 °C en S10m = 4,8 … 177 km/h (1.34 … 49 m/s)
with my given sensors this should be something like:
sensors:
wind_chill:
friendly_name: "Wind Chill"
unit_of_measurement: 'C'
value_template: "{13.12 +{ 0.6215*{{states.sensor.br_temperature.state}}+ {0.3965*{{states.sensor.br_temperature.state}} - 28.676}*{{states.sensor.br_temperature.state}}*0.16}"
There’s plenty of issues here, but the documentation isnt helping me yet. Please have a look with me?
Thanks,
Marius
fabaff
(Fabian Affolter)
February 5, 2018, 4:55pm
2
Use the “Templates” in the Developer tools to check if you have a syntax error in your template and if you are able to evaluate it.
yes i am:
no error, but no value either yet…
did a mistake, should have used windgust (maybe speed) but thats a detail:
{13.12 +{ 0.6215*{{states.sensor.br_temperature.state}}+ {0.3965*{{states.sensor.br_temperature.state}} - 28.676}*{{states.sensor.br_windgust.state}}*0.16}
fabaff
(Fabian Affolter)
February 5, 2018, 5:22pm
4
Mariusthvdb:
Will not work inside a template. You are doing math.
Ok Thanks. But now what?
Python script for something this small?
Or ill have to look for assistance with @olskar who also wrote https://github.com/olskar/home-assistant/blob/2fc65ab1f7c476e9df4530b3bd83718f6710eaf4/homeassistant/components/sensor/mold_indicator.py
Was hoping for some simpler template option tbh.
Cheers,
Marius
fabaff
(Fabian Affolter)
February 5, 2018, 10:33pm
6
Replace it with a ( and the closing one ()) inside the template.
im really sorry, but i don’t fully understand what you say i should change:
(13.12 + 0.6215*{{states.sensor.br_temperature.state}} +
0.3965*({{states.sensor.br_temperature.state}}- 28.676)*{{states.sensor.br_wind_gust.state}}*0.16)
or
(13.12 + 0.6215*states.sensor.br_temperature.state +
0.3965*(states.sensor.br_temperature.state-28.676)*states.sensor.br_wind_gust.state*0.16)
both wont work…
must be missing the crucial point here…
Marius
this should be the correct math, now how to get it calculated:
(13.12 +( 0.6215*{{states.sensor.br_temperature.state}}))+ (0.3965*({{states.sensor.br_temperature.state}} - 28.676))*({{states.sensor.br_temperature.state}}*0.16)
or even this:
13.12 +0.6215*{{states.sensor.br_temperature.state}}+ 0.3965*({{states.sensor.br_temperature.state}} - 28.676)*{{states.sensor.br_temperature.state}}*0.16
fabaff
(Fabian Affolter)
February 6, 2018, 3:43pm
9
Seems to work for me
{% set temperature = 25 %}
The temperature is {{ temperature }}.
The calculated value is {{ (13.12 + (0.6215 * temperature ) +
(0.3965 * ( temperature - 28.676 )) * (temperature * 0.16)) | round(2) }}.
yes, works here too.
but when i replace {{temperature}} with {{states.sensor.br_temperature.state}} this is displayed:
Error rendering template: TemplateSyntaxError: expected token ':', got '}'
{{ (13.12 + (0.6215 * {{states.sensor.br_temperature.state}} ) +
(0.3965 * ({{states.sensor.br_temperature.state}} - 28.676 )) * ({{states.sensor.br_temperature.state}} * 0.16)) | round(2) }}
spot the error…
fabaff
(Fabian Affolter)
February 6, 2018, 7:37pm
11
Remove the {{ }} around the variables.
i tried that:
{{ (13.12 + (0.6215 * states.sensor.br_temperature.state ) +
(0.3965 * (states.sensor.br_temperature.state - 28.676 )) * (states.sensor.br_temperature.state * 0.16)) | round(2) }}
but then nothing at all is displayed in the result window.
fabaff
(Fabian Affolter)
February 6, 2018, 7:59pm
13
If the state is missing (wrong name, not set, etc) then the variables are evaluates blank.
sure, but it is there:
strange, the state is correct, the math is correct (using your temperature statement ), and yet there’s no result combining the two.
fabaff
(Fabian Affolter)
February 6, 2018, 10:26pm
15
I think that it’s not working because we were missing the conversion 13.12 + (0.6125 * float(states.sensor.br_temperature.state)..... Jinja could be more strict than expected.
BIngo!
Now thesis obviously incorrect (freezing 2 degrees celsius at the moment), but the math is passing, thanks you very very much!
while this has become a template sensor formatting thread, please let me ask you another boggling question:
why does:
- platform: rest
resource: http://192.168.xxx.xxx/api/dmH4lHTTsBu1gzhEuVkbV52AwSQpojSYxaxM9pQq/sensors/2
value_template: "{{ as_timestamp(value_json.state.lastupdated) | timestamp_custom ('%H:%M') }}"
name: 'Update Dimmer switch'
show the time in the desired format:
and
hue_dimmer_switch_1_updated:
friendly_name: 'Dimmer switch1 update'
value_template: "{{states.sensor.hue_dimmer_switch_1.attributes.last_updated | timestamp_custom ('%H:%M')}}"
show (no matter what i change in the timestamp formatting, or even delete it):
the latter 2 are the same sensors with either states.sensor.hue_dimmer_switch_1.attributes.last_updated or states.sensor.hue_dimmer_switch_1.last_updated
the timestamp doesn’t work in these sensors?
btw this is better:
"{{ (13.12 + 0.6215*float(states.sensor.br_temperature.state) + 0.3965*float(states.sensor.br_temperature.state) - 28.676) * float(states.sensor.br_wind_gust.state)*0.16) | round(2) }}"
yields:
which feels more appropriate right now
Thanks again! Also learned that the starting and ending () are necessary for the | round(2) to work correctly. Magic.
Have a final solution worked out and also created another formula, the Steadman.
both sensors for you to use and adapt as you need to localize:
sensors:
jagti_windchill:
value_template: "{{ (13.12 + 0.6215*float(states.sensor.br_temperature.state) +
0.3965*(float(states.sensor.br_temperature.state) - 28.676) *
(float(states.sensor.br_wind_speed.state)*3.6)*0.16) | round(2) }}"
unit_of_measurement: "°C"
friendly_name: Jag/Ti WindChill
# Tchill(°C) = 13,12 + 0,6215*Tair + 0.3965*(Tair - 28,676)*S10m0,16
# S10m = windspeed (km/h) at anemometer_height = 10 m, Tair in °C
steadman_windchill:
value_template: "{{ (1.41 - 1.162*float(states.sensor.br_wind_speed.state) +
0.98*float(states.sensor.br_temperature.state) +
0.124*float(states.sensor.br_wind_speed.state)**2 +
0.0185*float(states.sensor.br_wind_speed.state)*
float(states.sensor.br_temperature.state)) | round(2) }}"
friendly_name: Steadman WindChill
# Tchill(°C) = 1.41 - 1.162*S + 0.98*Tair+0.0124*S2 + 0.0185*S*Tair
# Tair in °C en S= in m/s.
fabaff
(Fabian Affolter)
February 12, 2018, 6:14pm
19
I guess that we should add those sensors to the documentation.
Hjb
February 12, 2018, 8:28pm
20
For the JAG/TI sensor there is a small typo; iT should be **0.16 (double asterisk).
Anyway thanks for this, very helpfull.
