[Custom Component] Alarmo - browser managed alarm system
Any change to share the custom card code you’re using?
I’ve been using jcooper-korg card for a few days and the size is fantastic.
you you have a mix of that and the Alarmo card I’ll love to use it.
You don’t need Keymaster. Your lock sends a zwave event when it is locked and unlocked. That event data will contain a user id of some sorts for the code that triggered the event. Use the information in that event to trigger an automation that arms or disarms alarmo when authorized users lock or unlock the door.
This is my card code in the post below. Let me know if you have any specific questions.
Jason
Hi! I wanted to use Alarmo to be able to enable/disable users to disarm the alarm. Basically I want to create a guest user that only has permissions to disarm when my guest mode is active. Is there a way to do this? Thanks!
You could create a guest user with its own code, for that user you have these settings:
Seems like this is what you need right?
The only issue is that the “guest mode” is a manual action (you have to create the user in Alarmo).
I could add some toggle switches to the GUI for disabling/enabling users, but there is no easy way to link a “guest mode” to the configuration of users.
Thank you for the quick reply!
I wanted to avoid having to manually switch the “allow for disarming” for the guest. My idea is to enable guest mode automatically when the router detects some of my allowed guests and if they are present they can disarm the alarm. This needs to be controlled in an automation.
With the way it’s done right now I think I can create an automation that catches the disarming with the changed_by: guest. If the guest disarmed the alarm and the guest mode is off, I will arm again or even trigger it. But I would like to have a more seamless solution, if possible.
I see one scenario where you have a guest mode attribute on the alarm and then one switch on the user to say if it’s a guest or not, and if the alarm guest mode is on, then all the guest users can disarm.
Another more complex solution would be to create a sensor per user like: sensor.alarmo_user_guestA with some user options as sensor attributes (the allow arm and disarm only I guess), this way you could change the permissions per user in the automations.
What do you think? Will you eventually develop some solution like this?
This is awesome BTW. I haven’t gotten it all setup yet since I didn’t have sensors that could really be used by the alarm, but I recently got some and I’m going to start using it.
Looks great! I’ll update if I find any issues and if I think of anything else that can be done.
Thanks for this.
-P
@neliss another thing I would like to have is the possibility to use is the same or equivalent services of the manual alarm control panel, i.e., alarm_control_panel.alarm_trigger, alarm_disarm, etc… this would allow for a very easy transition for those that have already done their implementation with the native alarm_control_panel, which is my case. This also adds another level of flexibility that can be very powerful.
Please let me know your thoughts on the guest mode stuff as well as for the services.
You can use them. Except for alarm_control_panel.trigger, that is done by sensors.
I agree it could be nice for some. But I don’t consider this a priority now (there is quite a long todo list still).
This zigbee home security keypad can be incorporated easily via zigbee2mqtt and node red
Alarmo publishes its state to zigbee2mqtt/<keypad name>/set via mqtt
mode for the keypad can be one of disarm, arm_day_zones, arm_night_zones, arm_all_zones, exit_delay, entry_delay, not_ready, in_alarm, arming_stay, arming_night, arming_away
And Node-Red listens to topic zigbee2mqtt/<keypad name> for payload.action and payload.action_code from the keypad and sends the new alarm state to Alarmo.
The change node changes the keypads payload.action to Alarmo format ( disarm to alarm_disarm ect.)
The keypads alarm state (led status) is always in sync with Alarmo.
Just installed alarmo;
HA log filled with:
[frontend.js.latest.202104073] https://hassio.rossco.dynu.com/api/panel_custom/alarmo:1806:3097 TypeError: e.triggers is undefined
Suggestions?
Please report this issue in my Github project, so we can follow up on it.
It seems a harmless issue and a 5 min fix.
How pass parameters to alarmo action script?
Have this action:
modes:
  • armed_away
    triggers:
  • state: triggered
    actions:
  • service: script.turn_on
    service_data:
    entity_id: script.flash_light
    device: sonoff_100028e0e9
    area: ‘1618921001’
    When I try it, get error: “extra keys not allowed @ data[‘device’]”
    The script was working before I added parameters.
    Are parameters supported for alarmo actions?
is Alarmo 64bits compatible?
cant’ do step 3 in “install” instructions:
“3. Go to Configuration → Integrations and click the big orange ‘+’ button. Look for Alarmo and click to add it”.
Alarmo doesn’t appear, … not showed in integrations list.
Any help would be appreciate
Clear your browser cache. This is 10/10 times the issue.
Thax a lot,
After 3 restart, it didn’t appear, … but after a refresh page it appears.
Solved.
@neliss FYI; Nuked bwalarm (have to revert HA to configure) now recommending Alarmo for my users: https://www.rossco.org/modules/publisher/item.php?itemid=13#Alarmo_Alarm
Running on x86_64 and aarch64 (S9xxx TV boxes)
Please check that I’m not misrepresenting anything / doc’m additions / suggestions.
Obviously; Consider Alarmo very useful. Good work.
Regards;
Bill
Hi all,
I am currently integrating Alarmo in my HA.
I can arm the different Areas seperately however, when I’m trying to arm the system using the Master, this doesn’t do anything.
Do you have any idea? Do you need any further information?
Thanks for your much appreciated support
Hi . Can I install Alarmo and use with a Xiaomi gateway? I tried but it’s no working for me .
