Within Alarmo there is indeed no function to trigger the alarm when the arming fails with open sensors.
You could however create an automation in HA to achieve your goal.
For example:
Thank you for the automation, I tested it and while it does work, it has a downside.
The same event triggers at the start of arming, so you do not get the âbypass sensorsâ question on the keypad when you forget a window, only a deaf ear
I tried to change the automation by looking at the trigger. But this event is missing the info to determine if it is a event at the start or end of arming:
But furthermore, I cannot get the tool to work at all. I do not understand how to connect it to my Ring Alarm panel, and the config instructions are lacking. I researched this for a couple hours on the web and couldnât find anything more than a 2-yr-old blueprint which should have worked in theory, but did not allow me to choose any devices (i.e. Ring Control Panel). So, Iâm unable to even start using Alarmo.
Hello, is there any way the Alarmo card can update the arm status if the state changes by external input. The builtin alarm card updates states fine.
If I arm the alarm, the card shows the state as expected. But if I then disarm the alarm from another place. ie a physical keypad or an app, then the Alarmo card still thinks the alarm is armed. Any ideas how to make it update?
Any help with an issue most appreciated. I am trying to have Alarmo run a script. The script is simple and works fine (it sets the volume on a cast device and then plays an mp3 on it).
When I try and add the script as an action in Alarmo it keeps saying action required in the task section.
When looking at the YAML section this is what it saysâŠ
I have a need to âAllow open while armingâ, and I see discussion in this thread and I see it was added. But I donât see it anywhere, not in sensors or general. Can someone point me in the right direction please?
Thank you for the reply. I suspected that was it, but itâs grayed out on all three of the door sensors. Do I have some other setting that is not compatible with that?
Hi, I hope it hasnât been discussed here yet otherwise I would have missed it.
Can someone tell me how to disable just one alarm using a dashboard button?
I have âaway, night, home and vacationâ under alarms and I just want to deactivate the ânight alarmâ with a button. Can anyone tell me how this works?
I donât have an active PIN code.
Here my code:
Hello there, Iâm trying to add an action to Alarmo that will⊠arm another alarm when Alarmo is armed (trying to control multiple alarm systems from Alarmo).
When I create an action, however, I cannot select a alarm_control_panel.something device to issue the arm command.
If I try with YAML, I cannot validate an action.
