Custom Component: Dreame Vacuum
Nobody can help you if you don’t explain what are you trying to achieve.
Hi all,
Can anyone help me with my wait for trigger?
Why does it not recognized the change of status to “returning to dock”?
Thx!
Hello. I have dreame bot d9 max, i am using dreamehome APP. I try to connect robot on Xiaomi app home app but app cannot find robot.
How i can use robot with Xiaomi app and use this
Integration?
How i choose beta dreamehome version?
Hi everyone,
i’m stuck in configuration whit the account :
I don’t undeerstand what login he want, i use the credential on the app DreamHome, the credential Xiaomi Mio Cloud and the credential Xiaomi.
Can anyone help me pleasae?
You have to install dev version, not master. Dev have integration with dreamehome app.
I am having the same problem (user of dreamehome app here) and tried this suggestion but still cannot login with my dreame account.
Maybe i did something wrong? I added the repository using the dev version, i.e.:
wget -O - https://raw.githubusercontent.com/Tasshack/dreame-vacuum/dev/install | bash -
Hi
remove it and download it again it worked for me now !
:fire: dreame-vacuum-card :construction:
roomzone
Hey,
thank you - this worked for me as well. the important part is to enable “beta versions”. With the latest version, i.e. v2.0.0b12, i was able to login with my dreame account and see my robot, but… then while initializing it is restarting whole HA :slight_smile: so it is not able to complete initialization.
That means your system does not have enough memory available to run this integration. Enable low resolution map setting and try again.
@tasshack - Any ETA on X30 Ultra support?
I’ve already installed the latest beta version.
Thanks!
Awesome, I have increases the memory for my VM and now it is working. Thank you!
Hi, its awesome!!! it will be in future updates?
This is not in the scope of the integration, you should read the documentations of HA regarding automations and services. One of the reason this project is part of the HA and not a standalone project is not to explain how basic things are done like you asked.
In fact if you had checked the documentation for the integration you would see the page regarding this card and how to create it.
You are not clumsy, just lazy to make some research and read some documents from the internet. Also you think that somebody will do it for you by asking help without actually explaining what you are trying to achieve with the project.
This is not a customer support and nobody including the author will help you in here if you ask how to do the most basic things without reading anything online.
There are tons of video guides in the YouTube especially regarding the robot vacuum setups.
Read thread. Super Thanks for all the work.
Just got an L10s Ultra. I know I need the beta. I want to use the Native Dreame App. I also want to know its ok to update the Device Firmware in the Dreame app. So best you know its ok?
It’s ok to update the device firmware while using the Dreamehome with this integration.
Awesome. Thanks for getting back to me.
v2.0.0b13
New devices has been added to the supported devices list.
Name Model
Mova G20 r2450
Mova G30 r2435
Mova G30 Pro r2455
L10s Plus r2363a
L10s Pro Gen 2 r2364a
L10s Pro Ultra r9309a
L30 Pro Ultra r9317a
P10s Pro r2462
S10 Pro Ultra (Double Roller Brush) r9312
S30 Pro r2412
S30 Pro Ultra r2424
S30 Pro Ultra (Ultra-Thin embedded) r2310d
X30 Master r2450m
X30 Ultra r9316h
X30 Ultra r9316k
X40 r2426
X40 Pro r2416
X40 Pro (Ultra-Thin embedded) r2310e
X40 Ultra r2416a
X40 Ultra r2416c
X40 Ultra r2416h
X40 Ultra r2416n
X40 Ultra Complete r2449a
X40 Ultra Complete r2449k
Ko-Fi PayPal.Me
