Custom Component: Dreame Vacuum
When i try to connect my L20 Ultra to my home assistant I get “No supported devices found in this Xiaomi Miio cloud account on selected country.”. I cant figure out what I am doing wrong, is the L20 U no added or is it that I use the Dreame app and not the Xiaomi app? Thankful for all ideas!
@tasshack
Please add support for L10s pro ultra heat. I have a dreamehome app
I do not know if it is correlated, but right now when I try the latest beta with every option off and low-resolution map I get this error
Ten błąd pochodzi z niestandardowej integracji.
Rejestrator: custom_components.dreame_vacuum.dreame.map
Źródło: custom_components/dreame_vacuum/dreame/map.py:6269
integracja: Dreame Vacuum (dokumentacja, Problemy)
Pierwsze zdarzenie: 18:00:49 (2 zdarzenia)
Ostatnio zalogowany: 18:00:49
Map render Failed: Traceback (most recent call last): File "/config/custom_components/dreame_vacuum/dreame/map.py", line 6025, in render_map image = self.render_objects(cached_layers, map_data, robot_status, station_status, image, object_scale) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/config/custom_components/dreame_vacuum/dreame/map.py", line 6508, in render_objects or self.config.mopping_settings ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ AttributeError: 'MapRendererConfig' object has no attribute 'mopping_settings'
And after a few seconds my home assistant core stuck, becomes unavailable and I have to reboot the device
If you could add the device that means it is supported but you have actually found a bug that happens when all of the objects are disabled and you can bypass it by enabling at least one of the icon, name, order, suction_level, water_volume, cleaning_times or cleaning_mode objects until I fix this on the next Beta release.
@tasshack
Stuck and reboot problem appeared because I had previously roborock s50 and Xiaomi vacuum map extractor. When I got rid of them I was finally able to successfully add new dreame vacuum with all the features from the list and with high res map.
Btw L10s Pro Ultra Heat is found as model : r2338a
Im sure it has asked before, and couldnt find this from github, but is there “pin and goto” option available ?
Was thinking like moving robot near trash bin to clean it from hairs etc…
Awesome job btw !
dreame_vacuum.vacuum_goto service is available on Beta.
Hi, under the map I don’t see the option to clean by room selection, but I only see Zone Cleanup and Pin & Go. Did I do something wrong?
Open card config and press Generate Rooms Config button.
I found it, thank you!
Appreciate you sharing this useful information.!
Hi there,
I am trying to set up my L20s with the current beta version (awesome work, thank you!). I was able to set up the device and also add a card (using the “xiaomi-vacuum-map-card”). Everythings great, I think, but I am missing a button to switch cleaning modes. I guess I’ll have to add that myself manually?
Is the dreame-vacuum-card that was shown above usable already (looks great!)?
Hello. When I select the rooms I want to clean in Home Assistant, the vacuum still cleans all my rooms. How to make the vacuum cleaner really clean only the rooms that I specify on the map in Home Assistant? Does it somehow depend on the settings in the mobile phone?
Probably pressing the wrong button on the card.
Work in progress.
I do not know what I am doing wrong. Under the map I select the item Rooms, select for example two rooms on the map and press the icon to start the vacuum cleaner. The vacuum cleaner still cleans all the rooms.
  • Delete the card
  • Press add and select the card
  • Select vacuum entity
  • Select camera entity (Current map, not the saved one)
  • Press generate rooms config
  • Save
I’m done with that. But if I choose the Rooms option from the three options (Zone Cleanup, Pin & Go, Rooms) and mark only two rooms on the map and press the Start icon, all the rooms start cleaning.
Just bought the A1 lawnmower today. Would it be possible to add it to the supported models or is this strictly for vacuums? Thanks.
I think more than 100 supported vacuums are enough for one project also project name is dreame-vacuum not dreame-lawnmower.
