EdgeOS
Description
Provides an integration between EdgeOS (Ubiquiti) routers to Home Assistant.
How to
Requirements
- EdgeRouter with at least firmware version 2.0
- EdgeRouter User with ‘Operator’ level access or higher
- Traffic Analysis set to ‘Enabled’ (both
dpiandexportenabled undersystem/traffic-analysis) - To enable / disable interfaces an
adminrole is a required
Installations via HACS
- In HACS, look for “Ubiquiti EdgeOS Routers” and install and restart
- In Settings → Devices & Services - (Lower Right) “Add Integration”
Setup
To add integration use Configuration → Integrations → Add EdgeOS
Integration supports multiple EdgeOS devices
| Fields name | Type | Required | Default | Description |
| Host | Textbox | + | - | Hostname or IP address to access EdgeOS device, can hold also port (HOST:PORT), default port is 443 |
| Username | Textbox | + | - | Username of user with Operator level access or higher, better to create a dedicated user for that integration for faster issues identification |
| Password | Textbox | + | - |
EdgeOS Device validation errors
| Errors |
| Cannot reach device (404) |
| Invalid credentials (403) |
| General authentication error (when failed to get valid response from device) |
| Could not retrieve device data from EdgeOS Router |
| Export (traffic-analysis) configuration is disabled, please enable |
| Deep Packet Inspection (traffic-analysis) configuration is disabled, please enable |
| Unsupported firmware version |
Encryption key got corrupted
If a persistent notification popped up with the following message:
Encryption key got corrupted, please remove the integration and re-add it
It means that encryption key was modified from outside the code,
Please remove the integration and re-add it to make it work again.
Options
Configuration → Integrations → {Integration} → Options
| Password | Textbox | + | - | |
| Clear credentials | Check-box | + | Unchecked | Will reset username and password (Not being stored under options) |
Debugging
To set the log level of the component to DEBUG, please set it from the options of the component if installed, otherwise, set it within configuration YAML of HA:
logger:
default: warning
logs:
custom_components.edgeos: debug
Components
System
| Entity Name | Type | Description | Additional information |
| {Router Name} Unit | Select | Sets whether to monitor device and create all the components below or not | |
| {Router Name} CPU | Sensor | Represents CPU usage | |
| {Router Name} RAM | Sensor | Represents RAM usage | |
| {Router Name} Uptime | Sensor | Represents last time the EdgeOS was restarted | |
| {Router Name} Unknown devices | Sensor | Represents number of devices leased by the DHCP server | Attributes holds the leased hostname and IPs |
| {Router Name} Firmware Updates | Binary Sensor | New firmware available indication | Attributes holds the url and new release name |
| {Router Name} Log incoming messages | Switch | Sets whether to log WebSocket incoming messages for debugging |
Changing the unit will reload the integration
Per device
| {Router Name} {Device Name} Monitored | Sensor | Sets whether to monitor device and create all the components below or not | |
| {Router Name} {Device Name} Received Rate | Sensor | Received Rate per second | Statistics: Measurement |
| {Router Name} {Device Name} Received Traffic | Sensor | Received total traffic | Statistics: Total Increment |
| {Router Name} {Device Name} Sent Rate | Sensor | Sent Rate per second | Statistics: Measurement |
| {Router Name} {Device Name} Sent Traffic | Sensor | Sent total traffic | Statistics: Total Increment |
| {Router Name} {Device Name} | Device Tracker | Indication whether the device is or was connected over the configured timeframe |
Per interface
| {Router Name} {Interface Name} Status | Switch | Sets whether to interface is active or not | Available only if user level is admin
| {Router Name} {Interface Name} Status | Binary Sensor | Indicates whether interface is active or not | Available only if user level is not admin
| {Router Name} {Interface Name} Connected | Binary Sensor | Indicates whether interface’s port is connected or not | |
| {Router Name} {Interface Name} Monitored | Switch | Sets whether to monitor interface and create all the components below or not | |
| {Router Name} {Interface Name} Received Rate | Sensor | Received Rate per second | Statistics: Measurement |
| {Router Name} {Interface Name} Received Traffic | Sensor | Received total traffic | Statistics: Total Increment |
| {Router Name} {Interface Name} Received Dropped Packets | Sensor | Received packets lost | Statistics: Total Increment |
| {Router Name} {Interface Name} Received Errors | Sensor | Received errors | Statistics: Total Increment |
| {Router Name} {Interface Name} Received Packets | Sensor | Received packets | Statistics: Total Increment |
| {Router Name} {Interface Name} Sent Rate | Sensor | Sent Rate per second | Statistics: Measurement |
| {Router Name} {Interface Name} Sent Traffic | Sensor | Sent total traffic | Statistics: Total Increment |
| {Router Name} {Interface Name} Sent Dropped Packets | Sensor | Sent packets lost | Statistics: Total Increment |
| {Router Name} {Interface Name} Sent Errors | Sensor | Sent errors | Statistics: Total Increment |
| {Router Name} {Interface Name} Sent Packets | Sensor | Sent packets | Statistics: Total Increment |
Unit of measurement for Traffic and Rate are according to the unit settings of the integration
Services
Update configuration
Allows to set:
- Consider away interval - Time to consider a device without activity as AWAY (any value between 10 and 1800 in seconds)
- Log incoming messages - Enable / Disable logging of incoming WebSocket messages for debug
- Store debug data - Enable / Disable store debug data to ‘./storage’ directory of HA for API (edgeos.debug.api.json) and WS (edgeos.debug.ws.json) data for faster debugging or just to get more ideas for additional features
- Unit of measurement
- Update API interval - Interval in seconds to update API data
- Update Entities interval - Interval in seconds to update entities
More details available in Developer tools → Services → edgeos.update_configuration
service: edgeos.update_configuration
device_id: {Main device ID}
unit: Bytes
log_incoming_messages: true
consider_away_interval: 180
update_api_interval: 30
update_entities_interval: 1
Endpoints
| Endpoint Name | Method | Description |
| /api/edgeos/list | GET | List all the endpoints available (supporting multiple integrations), available once for integration |
| /api/edgeos/{ENTRY_ID}/ha | GET | JSON of all HA processed data before sent to entities, per integration |
| /api/edgeos/{ENTRY_ID}/api | GET | JSON of all raw data from the EdgeOS API, per integration |
| /api/edgeos/{ENTRY_ID}/ws | GET | JSON of all raw data from the EdgeOS WebSocket, per integration |
Authentication: Requires long-living token from HA
Examples
List
Request
curl https://ha_url:8123/api/edgeos/list
-H "Accept: application/json"
-H "Authorization: Bearer {token}"
Home Assistant Data
Request
curl https://ha_url:8123/api/edgeos/{ENTRY_ID}/ha
WebSockets Data
Request
curl https://ha_url:8123/api/edgeos/{ENTRY_ID}/ws
API Data
curl https://ha_url:8123/api/edgeos/{ENTRY_ID}/api
