It is possible to configure multiple WiFi networks in the go-e app, each with is own password. I could not test though whether the charger switches between them automatically or whether you have to switch manually when you change locations.
Thanks for the project. I will buy a go-charger or the Fronius wattpilot however i like the open source from go-echarger more.
Can I also charge with the integration only with Solarpower („PV-Überschuss“) in the wattpilot it is called eco-mode if i remember correctly.
Is it also possible to use the integration with the new version of the go-echarger? I think I read smth with closed API and so on. The version is the v3 iirc.
Would be really glad to hear from you since i have to order quiete fast (car is coming soon).
Thanks!
- In general PV charging is possible because you can select “single phase charging” and you are able to control the maximum current. I’ve no experience how to do it in detail. I hope we can extend the documentation of the project some day to provide some instructions.
- I’m just aware of different API flavours / versions (v1 vs. v2). The
goecharger_mqtt
component implements the newer API version (v2). Is there firmware version 3 or do mean a new hardware revision?
thank you!
Ad 2) I am not sure whether only SW or HW aswell.
I have a Fronius Inverter an a complete Victron 3 Phase setup with 10kwh batteries attached - all controlled with a Cerbo GX device from Victron.
Would be nice to charge only with PV and do not use the grid, additionally I would not want to switch from single phase charging to 3 phase manually. The Wallbox should do it automatically.
all this is possible with the Fronius wattpilot or the way more expensive Victron Wallbox or openWB. However the Fronius wattpilot is a closed ecosystem which i don’t like
You should try to talk to the go-e charger supported to get a better understanding what’s possible and what’s not. I assume the charger cannot talk to the inverter directly at the moment. You have to write all automations on your own to control the charger depending on your PV excess.
Ok thanks again! That is by now quite enough. So I will have a look to the three systems wattpilot, victron Wallbox and openWB.
Best
Daniel
SOLVED
Hi @syssi - and thanks for an integration that seems to be just what I need for my PV system
So I still have an issue like a couple of users above: My MQTT broker is working just fine with a lot of other integrations - and I see the go-eCharger (MQTT) integration using the serial number, but none of the entities are active and reachable…
I think the issue is with my mqtt URL in my app. I’ve given mqtt://192.168.1.3:1883 as this IP is where my HA is. And also I am not aware of any mqtt specific credentials. Any way to check the correct URL?
BTW my HA is installed as a virtual machine on my QNAP NAS
In my MQTT Broker log I now see this:
1661078345: New connection from 192.168.1.104:54005 on port 1883.
error: received null username or password for unpwd check
1661078345: Client disconnected, not authorised.
1661078360: New connection from 192.168.1.104:54006 on port 1883.
The go-eCharger is having 192.168.1.104 so it is trying but definitely need a specific username and pw. Hmm…
Gave one of my HA user credentials - now works!
(btw only use mqtt broker and charger locally)
Good job! If you find out how to add new users to your MQTT broker please share your knowledge.
Hi again,
As probably many others go-eCharger owners with solar panels on the roof I so much want to make an automation that charge my Tesla with excess solar power that would otherwise be exported to the grid…
I also acknowledge that there is a specific Tesla API available that some HA users have successfully taped into and hereby control the charging entirely from the Tesla + a grid power meter sensor.
However, with the new go-eCharger we now have the ability to control the charging entirely from the charger alone making it EV car independent. At least with the go-eCharger app alone I can now manually control the charging profile so that the total household consumption match the solar power produced:
I did this tedious manual job just to show that it was possible to match the solar power quite precisely.
And furthermore I did this without touching my Tesla - and I was even able to switch between 1 and 3 phases and back again on the fly. Well, it gave some short pauses in charging as can be seen but that is due to my Tesla wanting to think about the new charge situation. Go-eCharger just waited patiently!
But boy, would I want to have a script and automation just doing the same thing? Sure!
But in order to make the necessary calculation I need to know the actual charge power at all times. I can easily access the PSM key that control the phase switch (1 or 3) and the AMP key that control the current on the phases but the total power is “hidden” in place 12 (Total) of the NRG key that is an array:
U (L1, L2, L3, N), I (L1, L2, L3), P (L1, L2, L3, N, Total), pf (L1, L2, L3, N)
Question is how do I filter out “Total” from that key?
I would probably know how to do this if I was doing HA automations every day - but unfortunately I am nowhere near that…
Thanks for any guidance
As I see it the automation algorithm is then to:
- Check if sun is up(!)
- Check if EV is connected to the charger
- Increase or decrease AMP until “Household Power + EV Charge Power” is just below “Solar Power”
- If AMP increase with 1 phase cannot get it up to match Solar Power then switch to 3 phases
- If AMP decrease with 3 phases cannot get it down to match Solar Power then switch to 1 phase
Step 3-5 should then be a script running frequently (every 5 min?) to adjust the AMP and PSM
But I still need to isolate EV Charge Power from the NRG key - @syssi is that the same value as the “Total power average” in your Diagnostic section of your component?
Edit: No, it seems to be “Current power” that you also supported, but it is not in your Diagnostic section or?
May be the sensor definitions of the custom component could help here:
The sensor your are looking for is “current power”.
Thought so - thanks @syssi !
Hi, my sensors state remain in state unavailable
The goe-Charger is connected to my Mosquitto broker, I can see the values in MQTT Explorer.
I have a goe-Charger V1 Firmware 0.40
Is there anything that needs to be set, e.g. in configuration.yaml?
Edit: ok, I have seen that API V1 is not supported.
Thanks for the integration. I’m looking forward to get this working.
I’m unfortunately not getting any data, most likely due to this error from the logs:
Logger: homeassistant
Source: components/mqtt/client.py:214
First occurred: 3:23:25 PM (3 occurrences)
Last logged: 3:29:27 PM
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/util/logging.py", line 151, in async_wrapper
await async_func(*args)
File "/usr/src/homeassistant/homeassistant/components/mqtt/discovery.py", line 282, in async_integration_message_received
result = await hass.config_entries.flow.async_init(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 225, in async_init
flow, result = await task
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 252, in _async_init
result = await self._async_handle_step(flow, flow.init_step, data, init_done)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/goecharger_mqtt/config_flow.py", line 79, in async_step_mqtt
assert subscribed_topic == "/go-eCharger/+/var"
AssertionError
File "/usr/src/homeassistant/homeassistant/util/logging.py", line 153, in async_wrapper
log_exception(format_err, *args)
File "/usr/src/homeassistant/homeassistant/util/logging.py", line 115, in log_exception
friendly_msg = format_err(*args)
File "/usr/src/homeassistant/homeassistant/components/mqtt/client.py", line 214, in <lambda>
f"Exception in {msg_callback.__name__} when handling msg on "
AttributeError: 'functools.partial' object has no attribute '__name__'
This assert seems to be blowing up async_step_mqtt
At the very least, the config process should probably be aborted with self.async_abort
there so that there is feedback to the user.
Also, that assert is a bit odd given that there are two topic names listed in the manifest.json
"mqtt": [
"/go-eCharger/+/var",
"go-eCharger/+/var"
Thanks for your bug report! Could you create an issue at github? I will have a look.
Will do. And thanks for the quick response.
FYI, I just got it working by
- Comment out
- Change base topic from
/go-eCharger
togo-eCharger
during setup
Works great after that.
For posterity, the issue is: Setup failing due to AssertionError · Issue #55 · syssi/homeassistant-goecharger-mqtt · GitHub
can anyone tell me - where can I find the go-eCharger app or integration?
HA is talking with my go-eCharger but i can only see it in the log!
Thank you!
