Custom Component: HACS
Got Hacs upgrade the other day without it deleting the folder this time. Was great until the update today. Now it looks like I have two installed. Not sure if I should try the upgrade. lol.
That won’t effect your installation. Just ignore it, upgrade and it will dissapear.
Perfect. thanks
I have now the issue that the categories are repeated in the “store” section
not only “python scripts” as well themes (even 4 times)
ignore it. restart of hass solved it
Hello , maybe this is a very noob question, but… … How can I add themes to HACS?
Thanks and sorry, for ask this
As a theme author? See the dev docs
As a theme user? See the configuration docs
Both here https://hacs.xyz
Thanks so much again
I think there are url’s broken
Which?
Well, don’t show nothing about how to
Same with python_scripts
How to what?
@ludeeus, he is pointing out that your page doesn’t contain anything useful.
Sure…
There is an issue for that. https://github.com/hacs/documentation/issues/1
But it does not fit with the initial question https://community.home-assistant.io/t/custom-component-hacs/121727/626?u=ludeeus since it’s not one of the places I pointed to :man_shrugging:
that was precisely what I wanted to say, thanks
What I was asking was how to see the themes, not how to upload one created by me, I’m sorry for my bad English
Today, installing the Hassio update at the restart HACS stopped working, giving me this message: “The frontend of HACS has been disabled until you restart Home Assistant.”. I tried to restart HASSIO, reinstall HACS, but nothing the message keeps appearing.
@pollinolas https://hacs.xyz/docs/configuration/start
@echopage https://hacs.xyz/docs/issues
0.16.2 is now live, it has a fix for downloading zip releases, from 0.17.0 HACS will only be complete as a release asset, meaning that you need to be on at least 0.16.2 before upgrading to 0.17.0 when that time comes.
Fixed: completely eliminated HACS, eliminated all components, cleaned the browser cache, installed version 15.11 and then upgraded to 16.2. Now everything works perfectly
