can you tell me what the steps are after downloading and extracting the files?
can I replace its files and restart hassio?
thank you in advance,
@sparkydave
Well who knew??? An invisible drop down box! I wonder how many other integrations have these unseen options. I guess I’ll be clicking on everything from now on.
Thank you for the simple but not so obvious answer.
kartcon
@kartcon If it’s invisible it’s because of your theme. In the screen shot it does show a down arrow, or “triangle” if you prefer.
Yeah, its definitely not hidden. Must be an issue with your theme
It can be quite small and hard to see. Perhaps @ludeeus should make obvious in one of his screenshot/videos.
Guess I waited 1 day too long. After 17.4 was released, 16.3 is no longer there. How do I do a manual upgrade? Just download the 16.3 files and overwrite or will that screw up my setup?
Yes, just like that
Hello
I have a problem with hacs component. i upgraded yesterday and everything broke. i saw here that i was supposed to do in certain order.
I uninstalled everything: deleted hacs folder in component, removed entry from configuration.yaml and restarted [weird that HA still waited a long time for hacs, don’t know why].
And tried installed from scratch.
Still is somewhat broken design. For example, i don’t see the upper main menu
What can i do ?
You are missing the .translations
folder
where it should be, and what content it should be in it ?
The same place and content as in the zip file
Hey, i recently upgraded to the newest version (from 16.x), but now all my custom components is gone from the HACS-page, it is as if i never installed any. Do i need to do anything special to upgrade?
similar issue: i’ve upgraded to 17.4 and now the screen is blank. I suppose I was not running 0.16.2 or newer
I’m currently getting a blank white screen when hitting the Community icon Is there any way to fix/downgrade?
Also upgraded to HACS 17.4 from 16.3 and all integrations have disappeared - where can I find what I had installed previously, didn’t have too many (10) but dont recall which ones I was using?
In your config directory under custom_components
is where they live.
@ludeeus I found some strang german translastions. How can I help to make them better. Didn’t found the german translation file in your repository
Did you remove the entries under resources from your lovelace config
installed this component, now when put anything in the search bar, no component is shown
any clues?
