I’ve updated my old domogik plugin to control plcbus switch trough a 1141U usb device.
For now it allows only switch ON/OFF (no Dimmable, no Curtain, no Scenes)
it handle also only one-phase modules not 3.
scenes should be handle by Home Assistant neither it’s easier.
Note that due to a not found method for the moment it request all unit (making noise), going to use all_id_on_pulse to solve this but one of my unit module do not answer to those commands.
Still a lot to do, only basics are done for now (little more than just a POF ).
Add it manually with HACS for now until i done more.
Hey, I recently started exploring home assistant and have a plcbus based system in my house.
. Although I am not yet familiar with the structure of home assistant, I have experience in python and managed to send commands to 3 phase system, create scene addresses etc using 1141.
Let me know if I can help (:
Hi tikismoke, congratulations !!! and excelent work.
I use plcbus in my house I installed your plcbus custom component an I will try.
I saw that all the plcbus address that we configure in the configuration.yalm appears as switches. (A1, A2, etc…).
switch:
unfortunally I can turn on/off my lights. it’s a message that says:
ERROR (Thread-4) [custom_components.plcbus.lib.PLCBusSerialHandler] WARN : Message 0205D10122000003 sent, but ack never received
I think that my serial connection is not configured correctly.
Is there something that I can do to troubleshoot it?
Hello Tikismoke,
I was using dianemo or linuxmce in the past - with them I could handle the dimmer function as well. by the way linuxmce is an opensource project and Hari was the developer of that plcbus module.
In the weekend I will check the model number of my adapters (I have dual module on/off and dual module dimmers) both are the mini version that can be installed inside the electricity box. My gateway is PLCBUS-1141.
I’m not shure about the D1 at all I installed this plcbus like 9 years ago, I will check that in the weekend.
If you can shared with me the script to test I will appreciate!!
Best regards,
Hernan
Ok,
D1 house code it’s from 0 to 255 in hex 00 to FF so you could test them all, but it will take time
Same gateway as mine so it will not be the problem. Dimmer will as i haven’t any of them.
Ido was working on 3 phase integration but no more news.
So has said you should refind your house code before any try (pretty sure it’s somewhere in linuxMce conf) and you will have to help me make dimmer works as i have nothing to test (hope you have some python knowledge ).
Script example is here expect it’s bad truncated house code is D1 and 17 is the unit address (in fact 18-1):
So refind your house code and unit address and it will be easy for On/Off device.
Note that i upload all docs in the repo to help understand the protocols.
Hi Tikismoke,
Now I know that my house code is A1.
I tested it with plcbus.exe and for instance if I like to turn on A1 light the message that plcbus sends is “0205000022000003” and it works. but when I use home-assistance plugin it doesn’t work, (I’m testing with switch.plcbusswitch_a1_a1 from lovelace).
How I can debug this to know the message that plugin is sending?
Just add house code in the configuration y’all part.
It should poll the bus and show you all device available.
Or add directly A1 in the device list in config:
In this case my house code is D1 it find all device automatically excepted A1 to A4 and b6 to b9.
I know those one exist and are the good one but they don’t answer to polling.
After that it will create all A,B and auto-discovered switch in ha.
I just went through this error. In my case I had to install the files then restart the server management but do this before updating configuration.yaml. After that I made the configuration.yaml changes. The reason for this is that with the configuration.yaml changes in place the server manager saw the error and would not reboot.
