Actually they are. The BOM card is a fork of this card with added features and changes but will work fine with the darksky config or the BOM config.
Yeah, I guess that wasnāt technically correct was it.
I was trying to point out that by installing that card by using HACS that you wonāt be installing this card. But I didnāt do a very good job of it.
Yeah thatās correct⦠but if you setup Lovelace for this card, it will work with that card as wellā¦
Awesome card. Just installed it and love it. HACās integration would complete it.
I am using the BOM Card on HACS. I do not want to use any of the left or right slots. I added them all to the config like below in the hopes it would remove the large space between the Current and Forecast sections. The space is still there. Is there a way to remove the space?
slot_l1: remove
slot_l2: remove
slot_l3: remove
slot_l4: remove
slot_r1: remove
slot_r2: remove
slot_r3: remove
slot_r4: remove
Anyone else experiencing the custom card erroring out when accessing homeassistant (hassio .98.4) through an nginx proxy and duckdns.org?
Works fine as soon as I VPN in and use the local host name for my hassio install.
Is it possible to show the name of the place, as with the āLovelace animated weather cardā ?
Hi there,
Since today I am facing this error:
dark-sky-weather-card.js?track=true:1 Uncaught SyntaxError: Identifier 'LitElement' has already been declared
    at dark-sky-weather-card.js?track=true:1
dark-sky-weather-card.js:1 Uncaught SyntaxError: Identifier 'DarkSkyWeatherCard' has already been declared
    at dark-sky-weather-card.js:1
This is causing the card not to load (Custom element doesnāt exist: dark-sky-weather-card.) while the card-file itself itās correctly loading in the network tab.
I am not sure if yesterday was working because of cache, the latest update I did were HA (0.99.2) and some Customer Cards and Components using HACS (donāt remember exactly which one unfortunately).
Any idea?
Also, will this card be updated to work with HACS?
Andrea
I just updated to 0.99.2, and updated HACS and all my integrations/cards in HACS, and my Dark Sky weather card is working fine. I did a clear cache/hard reload in Chrome and it still looks okay.
Is it possible to hide the forecast section for a more streamlined view?
If you mean the little blurb at the bottom of the card that gives a small summary then find and comment the following line in the card config:
entity_daily_summary: sensor.dark_sky_daily_summary
no, I mean the daily forecast block in the center. See below. I have am trying to save some screen real estate.
that kind of defeats the purpose of this card⦠thatās the main bit!
Agree and I use the full card on my main interface. I have two small tablets around the house. I just donāt need the forecast on those but i still prefer the top section of this card over any other weather card out there. Just curious if I was missing a setting/toggle somewhere.
Is anyone having issue since last HA update with this card?
Despite the fact that I can see the card code (and a 200 response) in the network tab, the card return an error as if it is not existing.
In the console tab I got this error:
Andrea
I had no issues with it since a few releases.
Now on beta and no problems.
Hello guys
I“m trying to make this work, but can“t seem to make the card work. I“m getting
2019-10-04 20:04:46 ERROR (MainThread) [frontend.js.latest.201909191] https://*****.*.:8123/local/custom_ui/dark-sky-weather-card.js?v=7.1:7:1 Uncaught SyntaxError: Unexpected token ā<ā
repeatedly. Anyone with the same problem?
You need to download the raw file.
Can it bit that it is conflicting with some other card?
After some digging I have found that the card stop working when Lovelace loads the card button-entity-row.js
If I disable that card from the resources, the Weather Card works correctly.
Would someone be able to install it (via HACS) and confirm that is not just me?
Who should I open an issue to? This card or the Button Entity Row?
