This is actually a much nicer and more elegant solution than sidebarMenu
Great work Sir!
anyone who could might help?
Hi @Flo.C,
What do you mean with push through? Is that longpress do you het pop-up? If hat you can set a tap_action to control An entity when you tap/click it.
I Will check the animation maybe i can add something Nice
I could animate the background color but he uses icons with colors so cant do that.
Hey @DBuit,
Thanks for coming back
Sorry for my unprecise question. It was late
My intent is that I simple toggle or “short press” the tile and the cover is simply open or closing. If I need to have it on a certain position, I would can use the “long press”.
So basically like the light tiles
About the animation: If the icons would have no color, would it work then? I like the one with the closing toilet or the fan
Thanks for your support man. Appreciate it!
Hi man,
So you could do it like this i think i have no cover to test:
entities:
- title: Navigation
entities:
- entity: cover.demo
tap_action:
action: call-service
service: cover.toggle
service_data:
entity_id: cover.demo
Thats it!! Perfekt! Thanks a lot.
The only thing is now that the icons are always yellow on the cover tile. Any possibility to change this? So grey when they are closed?
Te check out offStates
in documentation on github to fix that
You Sir are a legend!
One last thing and then I’ll stop (promise)
What else do I need to insert in the code above to have the cover stopped if I toogle it a second time?
I saw that there is cover.stop
But I don’t know how to implement it. Do I need a template or something?
Hi man,
No problem!
If you want that it is more complicated you need to save that it is running or something and if you than tap it it should stop.
I guess you need a script but i don’t know how you need to find some HA script master!
@DBuit Hi, is it possible to change the brightness/volume/cover percentage color above the slider of your popup-cards? I have a white background and can’t read the percentage anymore. I tried some codes by using inspecting elements, but it didn’t work.
I want it to match my text colors in my theme, but the percentages are hardcoded to white.
Also a way to change the icon color when active of the popup-cards? It’s yellow now but I’d rather use a color matching my theme.
Any chance you can share your config, Im having a hard time wrapping my head around this…thank you.
@DBuit I am having trouble getting your media_player popup card to work on tap action.
It works if I set tap_action to more-info it shows the standard more-info card on tap but your card only works on long press. Here is my config:
In Lovelace UI root:
media_player.humax_receiver:
card:
entity: media_player.humax_receiver
type: 'custom:media_player-popup-card'
style:
'--iron-icon-fill-color': '#FFF'
align-items: center
background: 'rgba(0, 0, 0, 0.8)'
display: block
flex-direction: column
height: 100%
justify-content: center
left: 0
margin: 0
position: fixed
top: 0
width: 100%
z-index: 999
and the card is as follows:
- entity: media_player.humax_receiver
fullscreen: false
tap_action:
action: more-info
popup:
actions:
- icon: 'mdi:skip-previous'
service: media_player.media_previous_track
service_data:
entity_id: this
- icon: 'mdi:volume-mute'
service: media_player.volume_mute
service_data:
entity_id: this
is_volume_muted: true
- icon: 'mdi:skip-next'
service: media_player.media_next_track
service_data:
entity_id: this
scenesInARow: 2
Hi
Did you manage to fix this issue? I’m seeing the same alignment problem
I did
This is what I used:
#OFFICE
- type: state-icon
entity: light.office
deep_press: true
tap_action:
action: toggle
hold_action:
service: browser_mod.popup
service_data:
title: Office Light
larger: true
style:
width: 100%
height: 100%
card:
type: custom:light-popup-card
icon: mdi:lightbulb
actionsInARow: 2
supportedFeaturesTreshold: -1
brightnessWidth: 130px
brightnessHeight: 380px
borderRadius: 35px
sliderColor: "#FFD60A"
sliderTrackColor: "#2c2c2e"
sliderThumbColor: "#2c2c2e"
DeviceID:
- this
How do you add a camera view? Id like to create a 2 wide carde using “wider” but have the camera displayed on the front of the button. live view. is that possible? thank you.
Is there a way to change the icon color? I want to use an other color than yellow when on for specific entities.
keep getting error:
Custom element doesn’t exist: homekit-card.
type: ‘custom:homekit-card’
how to install it
cant find instructions
thx
Hi @DBuit,
Thanks for sharing this card with us. I have couple questions that I am not able to find an answer by myself.
- What would be the action if I want to use tap_action instead of hold_action for covers to have the custom pop-up card popup?
- With my Iphone I do not get any haptic when I toggle the lights or any other button. Is that something that can be added?
- Is it possible to add the on top right circle (like the sensors already have) for other cards? Ex. person.examle to have the last_changed on top-right circle (not sure if I explained this one right)
