Hi everyone,
I´m using hasso on rpi3 when I updated to 0.84.6 I started facing a problem, my dark sky is giving this error and not showing in my frontend:
019-01-15 08:32:01 ERROR (SyncWorker_0) [homeassistant.components.sensor.darksky] Unable to connect to Dark Sky: HTTPSConnectionPool(host='api.darksky.net', port=443): Max retries exceeded with url: /forecast/b5dadd6836074028261ee0e4c44eb2fe/-23.5733,-46.6417?units=si&lang=en (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x727dbf70>: Failed to establish a new connection: [Errno -3] Try again',))
The max retries (1000 per day) should be resetet after 24 hours.
How long doesn’t it work?
Maybe log in on the darksky site and see how it goes.
The default settings for the update intervall should be enough, but maybe set higher?
BTW: The url in the above error shows your darksky key and your location.
You should hide it and change the key.
Hi following this matter, I´ve noticed my cloud is also broken as my spotfy component, found this:
Logs from supervisor:
-01-16 13:19:44 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://s3.amazonaws.com/hassio-version/stable.json: Cannot connect to host s3.amazonaws.com:443 ssl:None [Try again]
19-01-16 13:24:51 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-01-16 13:21:58 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://s3.amazonaws.com/hassio-version/stable.json: Cannot connect to host s3.amazonaws.com:443 ssl:None [Try again]
my hassio logs:
Unexpected error
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/iot.py", line 97, in connect
yield from self._handle_connection()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/iot.py", line 153, in _handle_connection
yield from hass.async_add_job(auth_api.check_token, self.cloud)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/auth_api.py", line 108, in check_token
if cognito.check_token():
File "/usr/local/lib/python3.6/site-packages/warrant/__init__.py", line 260, in check_token
self.renew_access_token()
File "/usr/local/lib/python3.6/site-packages/warrant/__init__.py", line 555, in renew_access_token
AuthParameters=auth_params,
File "/usr/local/lib/python3.6/site-packages/botocore/client.py", line 312, in _api_call
return self._make_api_call(operation_name, kwargs)
File "/usr/local/lib/python3.6/site-packages/botocore/client.py", line 592, in _make_api_call
operation_model, request_dict)
File "/usr/local/lib/python3.6/site-packages/botocore/endpoint.py", line 141, in make_request
Unable to connect to Dark Sky: HTTPSConnectionPool(host='api.darksky.net', port=443): Max retries exceeded with url: /forecast/b5dadd6836074028261ee0e4c44eb2fe/-23.5733,-46.6417?units=si&lang=en (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x728170d0>: Failed to establish a new connection: [Errno -3] Try again',))
Well I see the same here for dark sky, google travel and arlo using duckdns and ssl.
But on another installation, not using duckdns and ssl I dont get the error.
I don´t quite get it it seems some problem with the netwrok comunication, I´ll try to disable duck dns and see if I can get it to work, but in the meantime I realized also that I not receiving any update to make for the 0.85 I´m stuck in the 0.84.6. I´ll really apreciate if someone with more knowledge could help
I´m asking the same thing since I updated to 0.84.6, I´ve tried to return to 0.83 but didn´t work as well, google api, dark sky, spotfy all went down here
Hey this is maybe a coincidence, but since my last HA update to 0.84.6 I have no more web access for components BOM sensor or BOM weather, Pushbullet, and YR.No weather. Sounds very similar as all require web access…
I use both the Dark Sky Sensor and Weather components and I’ve been on 0.84.6 for a while. I also use duckdns and ssl. Dark Sky has been working fine for me. FWIW, I don’t use hass.io; my HA is installed in a Python venv on Raspbian.
