"Dark" theme, or "night" mode/theme
5 posts were split to a new topic: Another Dark Theme
when you enable themes there’s a dropdown list under configuration > configuration.yaml scroll to the bottom.
again, select the theme you want to use to apply it.
@ahs I’ll try it this weekend and give feedback. Thank you!
Yes indeed much more elegant solution. I will change my code aswell. Thanks
thanks a lot I managed to get it working when I select a theme.
Sorry if this is a silly question but if you change the Theme to another color how do you get back to the “normal” default colors? Is it as simple as saying
frontend.set_theme
or do I need to define the color values back to the original by defining a Theme called “default” ?
Oh yes, I see… Actually I don’t have any badges, so I forgot it in my themesetup… Thanks for letting me know :slight_smile:
2 posts were split to a new topic: Dark Cyan Theme
There’s already a ‘default’ theme selection that allows it to revert back to blue/white
These themes are bomb. Added a few to my setup. Thanks much for sharing!
Midnight is amazing :smiley:
Hello all and thanks for all the nice themes you’ve created.
Is is possible to also increase the size of different elements, or perhaps there is a setting to magnify the whole UI by a factor of, let’s say, 1.3x?
It is possible to change also icons on the setting menu at left?
Here’s a script I use when working on groups, automations and themes so I don’t have to constantly restart HA. Just put script.reload somewhere where its easy to activate on your frontend.
  reload:
    sequence:
      - service: automation.reload
      - service: homeassistant.reload_core_config
      - service: frontend.reload_themes
Hi @Jer78,
Sounds interesting, can you let me know where this would be placed, is it part of an automation, or is “reload” a component i haven’t heard of…
Assuming it get triggered as part of a input select or a button click?
Put it in the script section.
Do just like @lambtho posted in post 79, how to setup it, so you can change it from the frontend. That will create a dropdown list where you can choose your theme…
https://community.home-assistant.io/t/dark-theme-or-night-mode-theme/446/79?u=broesie
Hi everybody !
I’ve got trouble with my themes…
I added few themes in my frontend and it works very well when I choose one with Services :
services
But when I choose with an input_select it doesn’t work !!
themes
I have automations behind input_select, for example :
  - alias: 'Current Theme at Night'
    initial_state: 'on'
      - platform: state
        entity_id: sun.sun
        to: 'below_horizon'
      - service: input_select.select_option
          entity_id: input_select.select_theme
          option: 'Midnight'
  - alias: 'Theme midnight'
      platform: state
      entity_id: input_select.midnight
      - service: frontend.set_theme
Could you help me please ?
Thank you !!
Put 'midnight' in quotes
Shouldn’t the trigger of your second automation be something like this?
      platform: state
      to: 'Midnight'
