Wow that looks great.
Could you show your code please?
Not much action here. Well I have spent these last days to investigate and learn a lot. I have now succeed with adding four nice buttons in my Dwains Dashboard, they are functional, can only be active on at a time, and they activate my scenes. I have prepared the automation to switch according to motion sensors and buttons from xcomfort, but that is the only thing I havent tested so far as I havent included those yet. I have included other xcomfort units though so I assume this will work as well.
I got this error message
Uncaught (in promise) TypeError: e.C() is undefined
dwains-dashboard.js:281
dwains-dashboard.js:425
dwains-dashboard.js:281:12
How to solve this?
@dwains: this problem have more users.
Can you fix that?
Hi Dashbord shows home/not_home instead of Zuhause/Abwesend in Overview .
In Popup everything is ok it shows Zuhause/Abwesend. How can i change this ?
thx for help really nice Dashboard
regards
Dirk
This is a bug caused by the latest HA version.
Thx for the Info !
regards
Dirk
After a lot of work I just released a beta version of 3.5 to fix all the current issues on my Discord Server. Let some people try it for some days and if it works for everyone I can release it official
17 days since my last visit and as I have learned a lot this 17 days, I must admit this dashboard is awesome. Have a question though, is it possible to switch the outdoor temp coming from the weather forecast with an actual temp sensor? I havent figured that out yet.
Hi, I keep getting the “dwains dashboard custom element doesn’t exist dwains-dashboard-layout” error. It happens only in the mobile app when I connect to HA remote https url with a cloudflare tunnel. But if I change the HA url in the companion app settings to a non secured http (ie. changing the HA url from “https://myhaurl.com” to “http://myhaurl.com”) then it is ok.
This happens only with app, connecting to the https url by PC is ok.
I already cleared the app cache and also purged cloudflare cache.
So to summarize:
Any idea? thanks
Hi guys! I’ve been using Dwains for the past two years, but the areas are getting messy as I grow my smart home.
Is it possible to create group of devices inside an area? Like entities that have a relation, for example, pool entities on garden, curtains in living room.
Any advices?
@prenazol I run into the same issue everytime HA is upgraded. Only a logout and login from the server helps (or wipeing the complete app memory). In both cases you loose the mobil app settinge.
I’ve just started playing with this and have hit a problem. Apologies if this has been covered before.
I have a number of entities that have been created using yaml (e.g. a number of ping
services). They cannot be edited through the GUI because they don’t have an entity_id
. As a consequence I can find no way to assign them to an area.
As far as I know, you cannot.
Aah, that’s a shame as it rules out using this dashboard. Pity as it’s really nice.
I’ll go back to ui-minimalist and see if I can replicate those lovely entity cards that incorporate the entity history graph.
You can add a unique id to it in YAML and then add t hem in a area its possible.
Hello all,
Can someone tell me if there is a way to fix the below with Dwains dashboard. For someone reason, the door is showing as “off” rather than closed. And when I click into it, it shows “closed” in the standard lovelace window.
2 screenshots provided below.
Thank you all!
Another question I have is:
Is there anyway to change the order of the page navigation icons at the top of the dashboard?
An additional issue I have found is that I have created a 10th new page in my dwains dashboard however when I click it on the more pages page, it takes me to the home page rather than the page I had just created. The url changes properly at the top of the browser but the correct page does not show up on the screen. I noticed that upon completion of the 10 new page, an icon for that page did not show up at the top of the screen. Is there a limit of new pages on dwains dashboard or something that could be causing this. Screenshots included below. Second screenshot shows url but it just navigated me back to the homepage.
It appears that you can’t for the ping
platform: With the following:
binary_sensor:
- platform: ping
host: 10.29.5.1
entity_id: sensor.rut-951-ping
I get:
Invalid config for [binary_sensor.ping]: [entity_id] is an invalid option for [binary_sensor.ping]. Check: binary_sensor.ping->entity_id. (See ?, line ?).
Without the entity_id
line it works fine.
