Greetings
Can I add:
LG Tv WebOS Remote Control As a card?
You can add any card you want into Dwains Dashboard
Update time!!!
V2.0.4 - Bug fixes and small changes
v2.0.4 is only compatible with HA 2021.10 and newer!
Dwains Dashboard now has a own logo
How to install 2.0.4 fresh (if you are new):
How to update to 2.0.4 manual:
- Download version 2.0.4 and unzip the file.
- Inside this folder you will see a folder called
custom_components
copy this folder. - Go to the main folder of your Home Assistant installation. This is the folder where you config is. (Hint: its the folder where for example the files
ui-lovelace.yaml
andconfiguration.yaml
are located). - Paste the
custom_components
to the main folder of your Home Assistant installation and overwrite all existing files! - Reboot your Home Assistant
- Clear your browser cache on all devices
- You are done!
How to update to 2.0.4. thought HACS:
- Open HACS
- Go to Dwains Dashboard and click update
- You are done!
If you are running older version then 2.0.0:
First upgrade to 2.0.0 and then to 2.0.4. To upgrade to 2.0.0 follow this upgrade guide: Dwains Lovelace Dashboard | An auto generating Home Assistant Lovelace UI dashboard for desktop, tablet and mobile by Dwains for desktop, tablet, mobile
Please consider a donation
Changes:
- Dwains Dashboard notifications are again closed when you click on the ‘X’ mark. (#311)
- The bug with the blue background in the header is fixed, its now black/dark again.
- Added iot_class to manifest.json
- Fixed a bug that person page froze and history was not visible of a person on the person page. (#325)
- Updated light entity card to latest version (#324)
- Updated Spanish language file (#323)
- Support for FontAwesome Duotone icons (#300)
- Fix bug with .installed file not created on some devices (#316)
- Updated German translation (#279)
- Added Slovak language (#278)
- Add support for graph type in the room-page_entities (#276)
- Make it possible to hide lights page from main menu (#276)
- Some small other not noticeable bug fixes.
I’m currently working on v2.1.0 and also on v3.0.0. Version 2.1 will have some new small features and 3.0 will be a total rewriten dashboard.
OK. But in the documentation I think its stated otherwise:
“If you double click on a button it will toggle the entity. So for example: Double click the room button on the homepage will toggle all the lights, double click inside the room on the lights button will togle all the lights, double click on a light button itself will toggle the light.”
now here is what i did. i made a new group.
i found that the name was “light.kok”
Now when i go in to my “kök” i se a button “kök” but when i click on that it turns on or off all the ligths.
i would like to have so that when i click or double click on the light button i get upp all the light so that i can individually manage them.
Is this possible?
yes it is, you just made the group wrong for that. check this.
how i did it: in configuration.yaml
add group: !include groups.yaml
now make a file called groups.yaml
and put it in the same folder as your configuration.yaml
is.
in the groups.yaml
add
kok:
entities:
- light.kok_tak
- light.diskbank
- light.koksbord
- light.kok_fonster
restart your HA and add group.kok
at line 6. reload the theme and you should be good.
EDIT: just checked, that it also works with the Light Group for me (the way you did it). maybe just give the way i showed you a try.
Did anyone come up with a solution for this? I have the same on my phone.
I have an issue on galaxy z fold
when closed the buttons are sized correctly.
When opened theyre sized incorrect.
The rooms are split into 2 columns
the favourites are also 2 columns but the widths do not match
Add an weather entity to global file
Those new foldable phones are a pain in the ass for developers like me I need to look into it but the system think its a phone but the view is a tablet, so I need to tweak some things maybe to get it working.
Lol cheers mate.
If you need anything from me let me know
Any chance we could have 3 or 4 columns for the rooms when unfolded instead of 2?
how can i do this?
im new hw\er
This worked for me! Thank´s a lot
check this
you need to make an own yaml for the stuff you want to add and then add it to your rooms.yaml
Hi guys, thanks for your amazing work here! I’m a noobie, still getting into it, but mostly works (after try & error lol)
One thing, I can’t customize enough to get a custom background image for the rooms buttons/cards (e.g. Bathroom) … is it possible? How/where do I have to change the code? I get normal picture buttons working with my custom picture, so picture path is clear …
I’ve attached an example:
Thanks in advance!
mind sharing your code?
EDIT:
make a new folder in \dwains-dashboard\addons\rooms\
named remote
in this folder you add a yaml named remote.yaml
in that yaml you put your code, for example:
- type: custom:lg-remote-control
entity: ...
add a yaml named button.yaml
in the same folder and add:
# dwains_theme
# Custom button for room addon: hello room
type: custom:button-card
entity: {{ (data | fromjson)['entity'] }}
template: rooms_child
name: {{ name }}
icon: {{ icon|default('fas:puzzle-piece') }}
tap_action:
action: navigate
navigation_path: {{ navigation_path }}
label: >
if(entity){
return entity.state;
} else {
return 'Entity error!';
then open your rooms.yaml
after - name:Living Room
you add this:
addons:
- name: # <-- choose a name
icon: # <-- choose an icon
path: 'dwains-dashboard/addons/rooms/remote/page.yaml'
button_path: 'dwains-dashboard/addons/rooms/remote/button.yaml'
this should work
Yes I think thats the issue indeed. Also check out the Dwains Addons repository for a lot of examples GitHub - dwainscheeren/dwains-dashboard-addons: Dwains Theme Addons
I succeeded Thank you very much
