I have the same issue here with raspbee and a pi3.
I have already put the lines in config.txt but I have not installed ha-bridge addon (seems stupid to me)
Any ideas? What can I check?
Please update the info in the addon. I think it could be useful to also add the information to disable bluetooth module on rpi3 modifying the config.txt in the correct way.
I am talking about the GUI to manage the ZigBee mesh network. I have some EnOcean PTM 215z wall switches that I want to implement in deConz. These switches are really the same that are inside Philips Hue Taps but I need to access the Zigbee Network to find what signals they send.
I have pi3 wirh raspbee, hassio with installed addon deconz and general I followed what is written on addon page in short and I did like below:
You need to disable BT:
with some reason btroot did not worked soe only disable-bt is good for myself.
you have to click Advanced icon, and get to unlock screen when you have Authenticate app.
I did so and all is good not need to install HA bridge. Hue light were discovered very quickly.
To do firmware update you have to follow what is written on addon page.
I agree all process is not very straightforward but it is working and cost much less than hue bridge. It is discovering my xiaomi zigbee smart plugs without an issue as well.
I can help maybe if someone struggle with this set up.
