This is a fork of the blueprint from Bram Kragten (Thanks for the inspiration!) with the following differences:
- left/right buttons change color temperature to warmer/colder temperatures,
- number of brightness and color temperature adjustment steps is configurable,
- only one light entity (no areas or devices) is supported
- This light entity needs to …
- provide either both
min_miredsandmax_miredsattributes or thergb_colorattribute and - support the
color_tempargument of thelight.turn_onservice.
(If you know how to make it more generic regarding areas and devices and keep the color temperature adjustment feature somehow, please let me know.)
This is a blueprint for the IKEA five-button remotes (the round ones), specifically for use with deCONZ.
The middle “on” button, toggles the lights on/off.
Dim up/down buttons will change the brightness smoothly and can be pressed and held until the brightness is satisfactory.
Left/right buttons will change the color temperature smoothly and can be pressed and held until the color temperature is satisfactory.
The ‘min/max color temperature override values’ are fallback values for light entities without min_mireds and max_mireds attributes (e.g. color lights with rgb_color attribute instead). They are only used to determine the color temperature step value to be applied on left/right button press.
For these light entities the current color temperature is approximated from (and only from) the rgb_color attribute using the inverse formula from here for color temperatures between 689 mireds (~1500 K) and 151 mireds (6600 K). Only for these rgb light entities, color temperatures can only set within this range.
The force brightness option allows you to configure a brightness which alyways should be used when turning the light on. If force brightness is off, the last brightness from when the light was turned of is used. However, with the latter, it is not possible to have a transition effect when toggling the light.
Force Brightness vs Transition Behavior
| force brightness | on | off |
| transitions on toggle? |
yes | no |
| brightness when turning on? |
the one you set in the blueprint configuration |
last brightness from when turned off |
This is what the Blueprint looks like from the UI:
Changelog
2021-02-27
- Light now stays on at lowest brightness, when short/long pressing down button repeatedly
- Added force brightness option (default off)
- If force brightness is off, the last brightness from when the light is turned off is used when turning it on again, but there is no transition anymore. A smooth transition when toggling can only be achieved with the force brightness option.
2020-12-31
- Limit set color temp to min/max color temp override values (for rgb light entites only). Setting cold color temperatures close to the valid approximation interval is now possible.
- Extend valid approximation interval from 1900 K to ~1500 K (526 mired to 689 mired)
- Set default values for min/max color temperature override to interval borders of valid approximation interval
2020-12-28
- Introduce fallback color temperature approximation from
rgb_colorattribute so color temperature change does also work with color light entities and not just with white spectrum light entities.
2020-12-20
- Initial release
Blueprint, which you can import by using this forum topic URL:
blueprint:
name: deCONZ - IKEA five button remote for lights with color temp
description: 'Control light entities with an IKEA five button remote (the round ones).
The middle "on" button, toggles the lights on/off.
The min/max color temperature override values are fallback values for light entities without
min_mireds and max_mireds attributes (e.g. color lights with rgb_color attribute).'
domain: automation
input:
remote:
description: IKEA remote to use
selector:
device:
integration: deconz
manufacturer: IKEA of Sweden
model: TRADFRI remote control
light:
description: The light entity (can be a group) to control
selector:
entity:
domain: light
force_brightness:
name: Force turn on brightness
description: 'Force the brightness to the set level below, when the "on" button on the remote is pushed and lights turn on.'
default: false
selector:
boolean: {}
brightness:
description: Brightness of the light(s) when turning on
default: 50
selector:
number:
min: 0.0
max: 100.0
mode: slider
step: 1.0
unit_of_measurement: "%"
brightness_step_count:
name: Brightness Adjustment Steps
description: Steps/seconds needed to adjust brightness between 0% and 100%.
default: 6
selector:
number:
min: 1.0
max: 10.0
mode: slider
step: 1.0
unit_of_measurement: steps
color_temp_step_count:
name: Color Temperature Adjustment Steps
description: Steps/seconds needed to adjust color temperature between min and
max value.
default: 6
selector:
number:
min: 1.0
max: 10.0
mode: slider
step: 1.0
color_temp_min_override:
name: Min Color Temperature Override
description: "Minimum color temperature value in mireds for light entities without 'min_mireds' attribute (e.g. color lights)."
default: 151.0
selector:
number:
min: 151.0
max: 689.0
mode: slider
step: 1.0
unit_of_measurement: mireds
color_temp_max_override:
name: Max Color Temperature Override
description: "Maximum color temperature value in mireds for light entities without 'max_mireds' attribute (e.g. color lights)."
default: 689.0
selector:
number:
min: 151.0
max: 689.0
mode: slider
step: 1.0
source_url: https://community.home-assistant.io/t/deconz-ikea-five-button-remote-for-lights-with-color-temp/257617
mode: restart
max_exceeded: silent
variables:
light_entity: !input 'light'
force_brightness: !input 'force_brightness'
is_white_spectrum_light: '{{ (not state_attr(light_entity, "min_mireds") == none)|int }}'
brightness_step_count: !input 'brightness_step_count'
color_temp_step_count: !input 'color_temp_step_count'
color_temp_min: !input 'color_temp_min_override'
color_temp_max: !input 'color_temp_max_override'
brightness_step: '{{ (255/brightness_step_count|int)|round(0, "ceil") }}'
color_temp_step: '{{ (((state_attr(light_entity, "max_mireds")|default(color_temp_max|int, true) - state_attr(light_entity, "min_mireds")|default(color_temp_min|int, true))/color_temp_step_count|int)|abs)|round(0, "ceil") }}'
- platform: event
event_type: deconz_event
event_data:
device_id: !input 'remote'
- variables:
event: '{{ trigger.event.data.event }}'
- choose:
- conditions:
- '{{ event == 1002 }}'
sequence:
- choose:
- conditions: "{{ force_brightness }}"
sequence:
- service: light.toggle
entity_id: !input 'light'
transition: 1
brightness_pct: !input "brightness"
default:
- conditions:
- '{{ event == 2002 }}'
sequence:
- service: light.turn_on
brightness_step: '{{ brightness_step }}'
transition: 1
- conditions:
- '{{ event == 2001 }}'
sequence:
- repeat:
count: '{{ brightness_step_count }}'
sequence:
transition: 1
- delay: 1
- conditions:
- '{{ event == 3002 }}'
sequence:
brightness_step: '{{ -([state_attr(light_entity, "brightness")-1, brightness_step]|min) }}'
transition: 1
- conditions:
- '{{ event == 3001 }}'
sequence:
- repeat:
sequence:
transition: 1
- delay: 1
- conditions:
- condition: and
conditions:
- '{{ event == 4002 }}'
- '{{ is_state(light_entity, "on") }}'
sequence:
color_temp: '{{ [(state_attr(light_entity, "color_temp")|default(1e6/([[[2.7182818284**(((state_attr(light_entity, "rgb_color")|default([0,0,0], true))[1]+161.1195681661)/99.4708025861)*100, 6600]|min, 1000]|max, [[(2.7182818284**(((state_attr(light_entity, "rgb_color")|default([0,0,0], true))[2]+305.0447927307)/138.5177312231)+10)*100, 6600]|min, 1900]|max]|sum/2), True) + color_temp_step), color_temp_max|int*(1+10*is_white_spectrum_light)]|min }}'
transition: 1
- conditions:
- condition: and
conditions:
- '{{ event == 4001 }}'
sequence:
- repeat:
count: '{{ color_temp_step_count }}'
sequence:
transition: 1
- delay: 1
- conditions:
- condition: and
conditions:
- '{{ event == 5002 }}'
sequence:
color_temp: '{{ [(state_attr(light_entity, "color_temp")|default(1e6/([[[2.7182818284**(((state_attr(light_entity, "rgb_color")|default([0,0,0], true))[1]+161.1195681661)/99.4708025861)*100, 6600]|min, 1000]|max, [[(2.7182818284**(((state_attr(light_entity, "rgb_color")|default([0,0,0], true))[2]+305.0447927307)/138.5177312231)+10)*100, 6600]|min, 1900]|max]|sum/2), True) - color_temp_step), color_temp_min|int*(1-is_white_spectrum_light)]|max }}'
transition: 1
- conditions:
- condition: and
conditions:
- '{{ event == 5001 }}'
sequence:
- repeat:
sequence:
transition: 1
- delay: 1
