All working ok here
Is it correct that no backup is made when an automatic update is done?
I came home from the store and found a not-so-smart house and the last deConz backup I had was from 2 months ago. That one worked, but a lot of devices has been added since. Do I have to add everything back manually now, since there is no other backups?
.1 working for me too.
IF you were prompted to make a backup before updating to 6.11.0, your backup can be found here:
configuration > addons, backups and supervisor > backups > addon_core_deconz_6.10.0
bit of a noob to this - how do I install 6.11.1? I found this git page but don’t know what to do with it (if i even use it?!) :
Thanks!
Same issue, rolled back, everything works again.
Was worried that my recently updated firmware on the Conbee II stick has something to do with that issue, but no…seems that you folks experience similar problems. The backup helped…phuuu.
Btw. running on a Pi4
Need to correct myself: Just updated to ver 6.11.1 and everything works. Thank you!!!
Can confirm 6.11.1 look working. Only the LQI update very slow, at the moment. All device are active and working
Can confirm that update to 6.11.1 works - but I still cannot pair Aqara Door/Window Sensor ver. E1…should I add something called DDF?
Hi, here no update 6.11.1 available, the last is 6.11.0, is there a way to push the new 6.11.1 from anywhere?
Go to store and force reload
Thanks, that worked!
Hi! After Updating to 6.11.1 and Conbee2 Firmware 26580700 the device can not be connected to homeassistant anymore. It will not be found and listed in hardware. So i am not able to start deCONZ
When connected to the PC it seems working as normal (without devices)
Do you have any adivce for me?
try re-flashing the firmware on a different pc
Hi tried this already but got an error flashing an older version.
But i got i working now. I had to switch from USB3 to USB2. USB3 worked for me before.
Thanks for this!
v6.10.11 is working but now a new integration od deConz is discovered every time, why?
Version 6.11.1 is not working for me. My Conbee2 is not recognized and I can’t get deCONZ to start.
Try restarting home assistant and/or disable current deconz integration and then reenable it.
I was stuck on 6.11.0 and receiving errors when I tried to update. Disabling deCONZ and then restarting HA seemed to fix the problem and allowed me to successfully install the update to 6.11.1.
After updating, I had to restart HA, close my browser and then open HA again to get the deCONZ web application running successfully.
My temperature sensors and heat switch worked correctly after updating, but my Xiaomi motion sensors were not reporting and needed to be manually bumped to get them going.
