Hi!
Recently, I tried to get external encrypted access to my HA working, using the Duck DNS Add-on. I reversed the changed I’d made when I found that both internal and external access were not possible for some reason. Immediately after this, devices via deCONZ were greyed out in HA and the integration displayed an error. The Phoscon UI is still accessible. The deCONZ application through VNC isn’t.
I tried:
- updating the ip address in
/config/.storage/core.config_entries
to the one displayed in Phoscon.
This got rid of the “greyedoutness” and the error on the integration page, but when I try to turn on or off a light, after a few seconds an error appears “Failed to call service light/turn_on.” In the error log, I found this:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/deconz/light.py:234
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: February 17, 2023 at 16:28:16 (6 occurrences)
Last logged: 11:48:43
[2628862328]
[2620692200]
[2628768672]
[2620713808]
[2634037208]
File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 142, in request_with_retry
return await self.request(method, path, json)
File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 167, in request
response: dict[str, Any] = await self._request(
File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 194, in _request
_raise_on_error(response)
File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 225, in _raise_on_error
raise_error(data["error"])
File "/usr/local/lib/python3.10/site-packages/pydeconz/errors.py", line 73, in raise_error
raise cls(
pydeconz.errors.BridgeBusy: 901 /lights/5/state/on Internal error, 951
raise cls(
raise cls(
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1787, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1824, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 968, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 720, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 571, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/deconz/light.py", line 234, in async_turn_on
await self.api.set_state(id=self._device.resource_id, **data)
File "/usr/local/lib/python3.10/site-packages/pydeconz/interfaces/lights.py", line 174, in set_state
return await self.gateway.request_with_retry(
File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 155, in request_with_retry
return await self.request_with_retry(method, path, json, tries)
File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 158, in request_with_retry
raise BridgeBusy
- Uninstalling and re-installing the integration. This got me back to where I started. I tried updating the ip address in
config_entries
again, but to the same result.
Anyone got any ideas to try, avoiding having to completely reset the Conbee stick? Would be much appreciated! Thank you.
