The hue dimmer switch is able to send a reset signal to close 15cm devices. You need to press the I and the O for some seconds until they blink and they have been factory reset.
OK - Thanks!
Sounds like Hue is not my solution here. Any other floodlight suggestions?
Why dismiss the Hue? The Hue dimmer switch is cheap (20 dollars or so) and you can use it as a switch on your Zigbee network. In have them everywhere. And you can use this one single remote to reset any Hue bulb or Hue LED strip in future. The dimmer switch can be in use for something else but when you need to reset a Philips Hue bulb you just grab it and hold it close to the bulb and press 1 and 0 simultaneously until the bulb flashes. It is actually a neat way to reset a bulb instead of the six times on off which small kids easily trigger by accident.
Thanks Kenneth!
Hue might be an excellent choice, but within my around 140 devices in my mesh I do not have a single Hue yet. I would like to hear if there is any other options. Also in my cases floodlights are in very hard to reach positions - to get near with dimmer switch might be harder if you compare for instance “power cycling” reset.
But yes - I am very open to hear other options also.
Thanks!
I knew that list and it is basically great. One thing is a bit confusing there: once you open the item from the list you will see:
So it looks like “confirmed” in description page is not updated with Dezonz. From that list you can also see there really is not too many brands with floodlights.
If you buy a standard dumb floodlight you can control it with one of these
https://www.sunricher.com/zigbee-ac-phase-cut-dimmer-sr-zg9101sac-hp.html
They are sold under many OEM names but if it looks the same then it is the same. They exist in on/off and dimming versions. I use one in my hallway where I have ceiling lights designed for G4 12V 10W and I had 3 switches that toggled a latching relay. I replaced this by this dimmer, a 12 V dimmable LED driver, and 12 V dimmable G4 LEDs. I can confirm that these zigbee dimmers work great with deconz and then you have the advantage that you can still use the old mechanical walk switches to toggle the light and the status gets reported correctly back to HA via deconz.
And these are relatively cheap. So are standard LED floodlights.
Thanks Kenneth!
I know, my current solution is Sonoff zigbee switch in my junction box and with around 5 € I have purchased nice led floodlights for outdoor use. I have 4 of those and they work just great. However I have often thought when there will be more zigbee floodlights …
That was my original question.
Unable to log in to marthoc deconz VNC, anyone know what the default username is?
I can only see where pw is specified
Oh FFS, its more unavailable than working…
What is wrong?
What is wrong?
18:49:13:901 discovery for zombie 0x0017880108b0a15f dropped, last try was 180 s ago
18:49:17:742 discovery for zombie 0x0017880108b0a15f dropped, last try was 184 s ago
18:49:20:402 Current channel 15
18:49:20:416 Device TTL 6240 s flags: 0x7
18:49:21:581 discovery for zombie 0x0017880108b0a15f dropped, last try was 188 s ago
18:49:25:421 discovery for zombie 0x0017880108b0a15f dropped, last try was 192 s ago
18:49:29:261 discovery for zombie 0x0017880108b0a15f dropped, last try was 195 s ago
18:49:33:101 discovery for zombie 0x0017880108b0a15f dropped, last try was 199 s ago
18:49:36:941 discovery for zombie 0x0017880108b0a15f dropped, last try was 203 s ago
18:49:40:781 discovery for zombie 0x0017880108b0a15f dropped, last try was 207 s ago
18:49:44:621 discovery for zombie 0x0017880108b0a15f dropped, last try was 211 s ago
18:49:48:461 discovery for zombie 0x0017880108b0a15f dropped, last try was 215 s ago
18:49:52:301 discovery for zombie 0x0017880108b0a15f dropped, last try was 218 s ago
18:49:56:141 discovery for zombie 0x0017880108b0a15f dropped, last try was 222 s ago
18:49:59:981 discovery for zombie 0x0017880108b0a15f dropped, last try was 226 s ago
18:50:03:821 discovery for zombie 0x0017880108b0a15f dropped, last try was 230 s ago
18:50:07:661 discovery for zombie 0x0017880108b0a15f dropped, last try was 234 s ago
18:50:11:501 discovery for zombie 0x0017880108b0a15f dropped, last try was 238 s ago
18:50:15:341 discovery for zombie 0x0017880108b0a15f dropped, last try was 241 s ago
18:50:19:181 discovery for zombie 0x0017880108b0a15f dropped, last try was 245 s ago
18:50:20:401 Current channel 15
18:50:20:414 Device TTL 6180 s flags: 0x7
18:50:23:021 discovery for zombie 0x0017880108b0a15f dropped, last try was 249 s ago
18:50:26:861 discovery for zombie 0x0017880108b0a15f dropped, last try was 253 s ago
18:50:30:701 discovery for zombie 0x0017880108b0a15f dropped, last try was 257 s ago
18:50:34:541 discovery for zombie 0x0017880108b0a15f dropped, last try was 261 s ago
18:50:38:382 discovery for zombie 0x0017880108b0a15f dropped, last try was 264 s ago
18:50:42:221 discovery for zombie 0x0017880108b0a15f dropped, last try was 268 s ago
18:50:42:386 GW firmware version: 0x26660700
18:50:42:386 GW firmware version is up to date: 0x26660700
18:50:46:061 discovery for zombie 0x0017880108b0a15f dropped, last try was 272 s ago
18:50:49:901 discovery for zombie 0x0017880108b0a15f dropped, last try was 276 s ago
18:50:53:741 discovery for zombie 0x0017880108b0a15f dropped, last try was 280 s ago
18:50:57:581 discovery for zombie 0x0017880108b0a15f dropped, last try was 284 s ago
18:51:01:421 discovery for zombie 0x0017880108b0a15f dropped, last try was 288 s ago
18:51:05:262 discovery for zombie 0x0017880108b0a15f dropped, last try was 291 s ago
18:51:09:101 discovery for zombie 0x0017880108b0a15f dropped, last try was 295 s ago
18:51:12:941 discovery for zombie 0x0017880108b0a15f dropped, last try was 299 s ago
18:51:16:781 discovery for zombie 0x0017880108b0a15f dropped, last try was 303 s ago
18:51:20:401 Current channel 15
18:51:20:414 Device TTL 6120 s flags: 0x7
18:51:20:621 discovery for zombie 0x0017880108b0a15f dropped, last try was 307 s ago
18:51:24:461 discovery for zombie 0x0017880108b0a15f dropped, last try was 311 s ago
18:51:28:301 discovery for zombie 0x0017880108b0a15f dropped, last try was 314 s ago
18:51:32:141 discovery for zombie 0x0017880108b0a15f dropped, last try was 318 s ago
18:51:35:981 discovery for zombie 0x0017880108b0a15f dropped, last try was 322 s ago
18:51:39:821 discovery for zombie 0x0017880108b0a15f dropped, last try was 326 s ago
18:51:43:661 discovery for zombie 0x0017880108b0a15f dropped, last try was 330 s ago
18:51:47:501 discovery for zombie 0x0017880108b0a15f dropped, last try was 334 s ago
18:51:51:341 discovery for zombie 0x0017880108b0a15f dropped, last try was 337 s ago
18:51:55:181 discovery for zombie 0x0017880108b0a15f dropped, last try was 341 s ago
18:51:59:021 discovery for zombie 0x0017880108b0a15f dropped, last try was 345 s ago
18:52:02:861 discovery for zombie 0x0017880108b0a15f dropped, last try was 349 s ago
18:52:06:701 discovery for zombie 0x0017880108b0a15f dropped, last try was 353 s ago
18:52:10:541 discovery for zombie 0x0017880108b0a15f dropped, last try was 357 s ago
18:52:14:381 discovery for zombie 0x0017880108b0a15f dropped, last try was 360 s ago
18:52:18:221 discovery for zombie 0x0017880108b0a15f dropped, last try was 364 s ago
18:52:20:402 Current channel 15
18:52:20:413 Device TTL 6060 s flags: 0x7
18:52:22:061 discovery for zombie 0x0017880108b0a15f dropped, last try was 368 s ago
172.30.32.2 - - [02/Nov/2020:17:52:23 +0000] "GET /pwa/index.html HTTP/1.1" 200 107404 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/ingress.html" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:23 +0000] "GET /pwa/login.html?1604339541894= HTTP/1.1" 200 27118 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/index.html" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:23 +0000] "GET /api/config?_=1604339542313 HTTP/1.1" 200 265 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:23 +0000] "GET /api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/api/config?_=1604339542339 HTTP/1.1" 403 140 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:24 +0000] "GET /api/config HTTP/1.1" 200 265 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/login.html?1604339541894" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
18:52:25:901 discovery for zombie 0x0017880108b0a15f dropped, last try was 372 s ago
172.30.32.2 - - [02/Nov/2020:17:52:28 +0000] "GET /api/config?_=1604339547418 HTTP/1.1" 200 265 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:28 +0000] "GET /api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/api/config?_=1604339547527 HTTP/1.1" 403 140 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
18:52:29:741 discovery for zombie 0x0017880108b0a15f dropped, last try was 376 s ago
18:52:33:581 discovery for zombie 0x0017880108b0a15f dropped, last try was 380 s ago
172.30.32.2 - - [02/Nov/2020:17:52:34 +0000] "GET /api/config?_=1604339552651 HTTP/1.1" 200 265 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:34 +0000] "GET /api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/api/config?_=1604339552685 HTTP/1.1" 403 140 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
18:52:37:421 discovery for zombie 0x0017880108b0a15f dropped, last try was 384 s ago
172.30.32.2 - - [02/Nov/2020:17:52:39 +0000] "GET /api/config?_=1604339557755 HTTP/1.1" 200 265 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:39 +0000] "GET /api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/api/config?_=1604339557769 HTTP/1.1" 403 140 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
18:52:41:261 discovery for zombie 0x0017880108b0a15f dropped, last try was 387 s ago
18:52:41:432 created username: 6B32943193, devicetype: Phoscon#B412x421
172.30.32.2 - delight [02/Nov/2020:17:52:41 +0000] "POST /api/ HTTP/1.1" 200 55 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/login.html?1604339541894" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:41 +0000] "GET /api/6B32943193/groups HTTP/1.1" 200 641 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/login.html?1604339541894" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:41 +0000] "GET /pwa/index.html?1600076120000=&gwid=00212EFFFF05A59E HTTP/1.1" 200 107404 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/login.html?1604339541894" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:41 +0000] "GET /api/6B32943193/config?_=1604339560261 HTTP/1.1" 200 6783 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/index.html?1600076120000&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:41 +0000] "GET /api/6B32943193/config?_=1604339560262 HTTP/1.1" 200 6783 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/index.html?1600076120000&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:41 +0000] "GET /api/6B32943193/groups?_=1604339560263 HTTP/1.1" 200 749 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/index.html?1600076120000&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:41 +0000] "PUT /api/6B32943193/config HTTP/1.1" 200 58 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/index.html?1600076120000&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:41 +0000] "GET /api/6B32943193/lights?_=1604339560264 HTTP/1.1" 200 1181 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/index.html?1600076120000&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:42 +0000] "GET /api/6B32943193/sensors?_=1604339560265 HTTP/1.1" 200 440 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/index.html?1600076120000&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:42 +0000] "GET /api/6B32943193/config?_=1604339560266 HTTP/1.1" 200 6783 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/index.html?1600076120000&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
18:52:42:704 New websocket 127.0.0.1:60436 (state: 3)
172.30.32.2 - - [02/Nov/2020:17:52:44 +0000] "GET /pwa/settings-gateway2.html?_v=61826e5f8164073a2f2966706f479fe8020f9de6,10,1,18&gwid=00212EFFFF05A59E HTTP/1.1" 200 53625 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/index.html?1600076120000&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
18:52:44:108 Websocket disconnected 127.0.0.1:60436, state: 0, close-code: 1000, reason:
172.30.32.2 - - [02/Nov/2020:17:52:44 +0000] "GET /websocket HTTP/1.1" 101 4 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:44 +0000] "GET /api/6B32943193/config?_=1604339562750 HTTP/1.1" 200 6783 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/settings-gateway2.html?_v=61826e5f8164073a2f2966706f479fe8020f9de6,10,1,18&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:44 +0000] "GET /api/6B32943193/config?_=1604339562751 HTTP/1.1" 200 6783 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/settings-gateway2.html?_v=61826e5f8164073a2f2966706f479fe8020f9de6,10,1,18&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
172.30.32.2 - - [02/Nov/2020:17:52:44 +0000] "GET /api/6B32943193/config?_=1604339562752 HTTP/1.1" 200 6783 "http://hass.hass.nl:8123/api/hassio_ingress/WW_ZwlW2lMWhZ_J7pGQHd-AU9TuN_z6Sd6zlkQAQevo/pwa/settings-gateway2.html?_v=61826e5f8164073a2f2966706f479fe8020f9de6,10,1,18&gwid=00212EFFFF05A59E" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
18:52:45:101 discovery for zombie 0x0017880108b0a15f dropped, last try was 391 s ago
18:52:45:334 New websocket 127.0.0.1:60454 (state: 3)
18:52:48:941 discovery for zombie 0x0017880108b0a15f dropped, last try was 395 s ago
172.30.32.2 - - [02/Nov/2020:17:52:49 +0000] "GET /websocket HTTP/1.1" 101 4 "-" "Mozilla/5.0 (Linux; Android 10; SM-N975F Build/QP1A.190711.020; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/86.0.4240.114 Mobile Safari/537.36"
18:52:49:287 Websocket disconnected 127.0.0.1:60454, state: 0, close-code: 1000, reason:
18:52:52:781 discovery for zombie 0x0017880108b0a15f dropped, last try was 399 s ago
thanks! I connected the stick to a PC and I discovered that it wasn’t recognized from Windows too, so I returned it to Amazon and I bought another one. I plan on not upgrade it, when it will arrive.
I just had all kinds of issues pairing to some ikea bulbs. For anyone else reading this, do not turn them off and on one extra time after resetting them.
Started having troubles the last couple of days.
Home Assistant (core 117.2) on VirtualBox within Windows 10
deCONZ software 2.05.81
Conbee II with firmware 26660700
Devices - mix of light, switches and sensors of mainly ikea and xiaomi.
Added to Home Assistant via "Configuration --> Integrations --> + "
The problem ;
Every time I restart Home Assistant the deCONZ integration breaks. Even if I restart through “Configuration --> Server Control --> Server Management --> Restart”
I have to delete the integration then add it again for it to work. Then I have to change entity IDs. Also I have automations set up like this ;
So I have to go into automations to point to the right devices again. Maybe this step could be avoided if I use “Call service” and point to entity ID instead.
I tried upgrading to the newest deCONZ software, but then I’m not able to login to the Phoscon App.
Spent the better part of today trying to solve this.
HI, I have a problem with Xiaomi agara, (temperature, humidity pressure …) Have 3 of the same I have managed to install 2 but not the third in Phoscon interface. It is the same device that does not want to install, has changed the battery. I use the same procedure to install, for all 3 devices, but only 2 devices can be installed. The third is found by Phoscon, it says ready unit, but it is not visible in sensors. Only 2 units are visible in sensors. What could be wrong. Have tried to remove the devices from Phoscon, reinstalled, reset Xiaomi devices, but it becomes the same problem, that device is not visible in Phoscon sensors. Grateful for help
Is it the same thirth sensor? Or is it always the thirth no matter which sensor is? A have 7 of them and no issues.
I am having same issue here with different Xiaomi sensor.
The phoscon UI tells “ready” after having discovered it but I cannot see it in the sensor list (and in HA too).
No way to understand why.
Yes its the same model as the other two, which works and is visible in sensors. But not the third
I have had a few Xiaomi Switches (WXKG02LM) installed for some time and have automations to trigger when it detects the deconz events.
About a month ago I have had to do an initial click on the light switches before the event is detected in HA. So to turn on the lights I would click then click again after. This is beginning to get annoying but I cannot figure out why this has started to happen.
Any help would be appreciated.
Have some issues with these switches too, but never thought of a second click. Just thought they were missing out on clicks. Have to check if that’s the case.
Sounds like an issue with devices going to sleep?
I was using the switches for at least 3-4months before I had this issue.
Is there any way to stop them sleeping?
