It looks like it gets created when you click on the triple dot - list the lights - and submit.
And it does not get listed as a group in Phoscon.
In HA it gets picked up as a light group. And I just disabled it also. Then it is invisible again in HA. Seems to be a new feature in Phoscon app that you can turn off a group of lights in the UI. Since you only need to disable it once in your life in HA I would not be too worried
Wrong. It was automatically created. I only spotted the source of it by checking out the Phoscon web app.
Not in the group section (we know and are used to) for years. But technically, it’s the same - just not in the UI.
That’s what I did too. Interestingly, according to the Phoscon UI you can also bind power switches there. Probably another switch group will be created then in HA. But - I don’t really care. I just would have known this before. Reading all available release notes of 6 months twice and still getting surprised by new “features” - funny
When you pair a new switch an empty group is created with the switch associated with no lights. I personally never used these.
You can manually add a group, add lights (and plugs), and assign a switch, and you can also do some programming of buttons if Deconz knows the switch.
The advantage of this is that HA can be down and the lights still work.
The disadvantage is that same switch in HA is more difficult to assign multiple values to. I actually need to try that!! Personally I only have lights in my groups and no switches.
The huge advantage I have seen is that even when a light appear to be disconnected from deconz (grayed out), it often still reacts to the group messages, so noone notice that the light is in limbo until you look at HA or try to turn the light on and off as a single light. That is a huge home approval factor as 95% of all turnings lights on and off is either automatic or by a switch that controls an entire room. If you only have two lights in a group, it may not be worth it. But in a normal living room with 4-10 lights or worse a celing with many individual spots, you really have an advantage of almost always seeing all lights turn on and off even if one is marked as unavailable. It is the light itself that knows it is in a group and reacts to the group messages.
Could anybody explain me, how to use DDF?
I have been found file on site Deconz Toolbox with the same manufacturer and model and this file I’ve tried to upload. Looks that file has been uploaded with success. But what to do now?
I’ve been tried delete device in VNC and add it again but still no difference and no new device in Phoscon.
Thanks for your help.
So I’ve no idea what changed
I have done several reboots
Restoration of back ups and this morning disconnected my ConbeeII stick upon reboot I decided to try the update again and it’s finally worked.
not discovered? → “manual enter” (the whole translation is quite adventerous)
IP: HA-IP. Port: as configured in deCONZ addon of HA (40850 as default). Hit “search”.
login: it shows another IP address of 172.xxx.xxx.xxx range, which seems to be the HA internal IP address. Anyway, login attempts fail with “login attempt failed”
The whole app also is not very responsive (hitting buttons does nothing very often).
That way the iOS is currently completely unusable (for me) unfortunately.
Edit: after the fifth attempt the HA IP was finally used and shown for the ConBee 2 device, login possible. Wow, that app is buggy and laggy as hell. But getting off-topic here.
