I’m not certain where to get those from…
19-07-03 19:07:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-07-03 19:07:58 INFO (MainThread) [hassio.host.services] Update service information
19-07-03 19:07:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-07-03 19:07:58 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-07-03 19:07:58 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
19-07-03 19:07:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-07-03 19:07:58 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.95.4
19-07-03 19:07:58 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/15ef4d2f repository
19-07-03 19:07:58 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-07-03 19:07:58 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/3833edd4 repository
19-07-03 19:07:58 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-07-03 19:07:58 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 63 new - 0 remove
19-07-03 19:07:58 INFO (MainThread) [hassio.addons] Found 26 installed add-ons
19-07-03 19:07:58 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/amd64-addon-mariadb with version 1.2
19-07-03 19:07:58 INFO (SyncWorker_2) [hassio.docker.interface] Attach to hassioaddons/vscode-amd64 with version v0.6.0
19-07-03 19:07:58 INFO (SyncWorker_5) [hassio.docker.interface] Attach to samccauley/amd64-googlebackup with version 1.6.2
19-07-03 19:07:58 INFO (SyncWorker_1) [hassio.docker.interface] Attach to hassioaddons/portainer-amd64 with version v0.7.0
19-07-03 19:07:58 INFO (SyncWorker_0) [hassio.docker.interface] Attach to hassioaddons/influxdb-amd64 with version v3.1.0
19-07-03 19:07:58 INFO (SyncWorker_7) [hassio.docker.interface] Attach to homeassistant/amd64-addon-check_config with version 2.1
19-07-03 19:07:58 INFO (SyncWorker_3) [hassio.docker.interface] Attach to homeassistant/amd64-addon-deconz with version 3.1
19-07-03 19:07:58 INFO (SyncWorker_5) [hassio.docker.interface] Attach to hassioaddons/ide-amd64 with version v2.0.0
19-07-03 19:07:58 INFO (SyncWorker_1) [hassio.docker.interface] Attach to hassioaddons/appdaemon3-amd64 with version v4.0.0
19-07-03 19:07:58 INFO (SyncWorker_3) [hassio.docker.interface] Attach to hassioaddons/sonweb-amd64 with version v0.8.0
19-07-03 19:07:58 INFO (SyncWorker_8) [hassio.docker.interface] Attach to homeassistant/amd64-addon-samba with version 8.1
19-07-03 19:07:58 INFO (SyncWorker_7) [hassio.docker.interface] Attach to homeassistant/amd64-addon-configurator with version 3.4
19-07-03 19:07:58 INFO (SyncWorker_5) [hassio.docker.interface] Attach to esphome/esphome-hassio-amd64 with version 1.13.6
19-07-03 19:07:58 INFO (SyncWorker_6) [hassio.docker.interface] Attach to homeassistant/amd64-addon-letsencrypt with version 3.0
19-07-03 19:07:58 INFO (SyncWorker_2) [hassio.docker.interface] Attach to hassioaddons/log-viewer-amd64 with version v0.6.0
19-07-03 19:07:58 INFO (SyncWorker_4) [hassio.docker.interface] Attach to hassioaddons/node-red-amd64 with version v4.0.1
19-07-03 19:07:58 INFO (SyncWorker_9) [hassio.docker.interface] Attach to hassioaddons/glances-amd64 with version v0.5.0
19-07-03 19:07:58 INFO (SyncWorker_3) [hassio.docker.interface] Attach to hassioaddons/adb-amd64 with version v0.5.0
19-07-03 19:07:58 INFO (SyncWorker_7) [hassio.docker.interface] Attach to homeassistant/amd64-addon-ssh with version 6.0
19-07-03 19:07:58 INFO (SyncWorker_0) [hassio.docker.interface] Attach to hassioaddons/grafana-amd64 with version v2.2.1
19-07-03 19:07:58 INFO (SyncWorker_2) [hassio.docker.interface] Attach to hassioaddons/zwave2mqtt-amd64 with version v0.2.0
19-07-03 19:07:58 INFO (SyncWorker_1) [hassio.docker.interface] Attach to hassioaddons/bitwarden-amd64 with version v0.2.0
19-07-03 19:07:58 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/amd64-addon-mosquitto with version 5.0
19-07-03 19:07:58 INFO (SyncWorker_5) [hassio.docker.interface] Attach to hassioaddons/adguard-amd64 with version v2.0.0
19-07-03 19:07:58 INFO (SyncWorker_6) [hassio.docker.interface] Attach to homeassistant/amd64-addon-git_pull with version 7.3
19-07-03 19:07:58 INFO (SyncWorker_8) [hassio.docker.interface] Attach to hassioaddons/thelounge-amd64 with version v0.4.0
19-07-03 19:07:58 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-07-03 19:07:59 INFO (MainThread) [hassio.snapshots] Found 4 snapshot files
19-07-03 19:07:59 INFO (MainThread) [hassio.discovery] Load 3 messages
19-07-03 19:07:59 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-07-03 19:07:59 INFO (MainThread) [__main__] Run Hass.io
19-07-03 19:07:59 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-07-03 19:07:59 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-07-03 19:07:59 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-07-03 19:07:59 INFO (MainThread) [hassio.addons] Phase 'system' start 5 add-ons
19-07-03 19:07:59 WARNING (MainThread) [hassio.addons.validate] Unknown options quiet_logs
19-07-03 19:07:59 INFO (SyncWorker_5) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-deconz with version 3.1
19-07-03 19:08:00 INFO (SyncWorker_9) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-mosquitto with version 5.0
19-07-03 19:08:00 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on hassioaddons/zwave2mqtt-amd64 with version v0.2.0
19-07-03 19:08:00 INFO (SyncWorker_7) [hassio.docker.addon] Start Docker add-on hassioaddons/sonweb-amd64 with version v0.8.0
19-07-03 19:08:00 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-mariadb with version 1.2
19-07-03 19:08:00 INFO (MainThread) [hassio.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
19-07-03 19:08:01 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_zwave2mqtt
19-07-03 19:08:05 INFO (MainThread) [hassio.addons] Phase 'services' start 11 add-ons
19-07-03 19:08:05 WARNING (SyncWorker_9) [hassio.docker.addon] Glances run with disabled protected mode!
19-07-03 19:08:05 WARNING (SyncWorker_7) [hassio.docker.addon] Portainer run with disabled protected mode!
19-07-03 19:08:06 WARNING (MainThread) [hassio.api.security] No API token provided for /api/config
19-07-03 19:08:06 INFO (SyncWorker_9) [hassio.docker.addon] Start Docker add-on hassioaddons/glances-amd64 with version v0.5.0
19-07-03 19:08:06 INFO (SyncWorker_0) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-ssh with version 6.0
19-07-03 19:08:06 INFO (SyncWorker_8) [hassio.docker.addon] Start Docker add-on hassioaddons/adguard-amd64 with version v2.0.0
19-07-03 19:08:07 INFO (SyncWorker_5) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-samba with version 8.1
19-07-03 19:08:07 INFO (SyncWorker_7) [hassio.docker.addon] Start Docker add-on hassioaddons/portainer-amd64 with version v0.7.0
19-07-03 19:08:08 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_glances
19-07-03 19:08:08 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on hassioaddons/vscode-amd64 with version v0.6.0
19-07-03 19:08:08 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on hassioaddons/grafana-amd64 with version v2.2.1
19-07-03 19:08:08 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_adguard
19-07-03 19:08:08 INFO (SyncWorker_6) [hassio.docker.addon] Start Docker add-on hassioaddons/adb-amd64 with version v0.5.0
19-07-03 19:08:09 INFO (SyncWorker_1) [hassio.docker.addon] Start Docker add-on hassioaddons/bitwarden-amd64 with version v0.2.0
19-07-03 19:08:09 INFO (SyncWorker_3) [hassio.docker.addon] Start Docker add-on samccauley/amd64-googlebackup with version 1.6.2
19-07-03 19:08:09 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_portainer
19-07-03 19:08:09 INFO (SyncWorker_9) [hassio.docker.addon] Start Docker add-on hassioaddons/influxdb-amd64 with version v3.1.0
19-07-03 19:08:14 INFO (SyncWorker_7) [hassio.docker.interface] Start homeassistant/qemux86-64-homeassistant
19-07-03 19:08:16 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_vscode
19-07-03 19:08:18 WARNING (MainThread) [hassio.api.security] No API token provided for /api/config
19-07-03 19:08:19 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_influxdb
19-07-03 19:08:19 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_bitwarden
19-07-03 19:08:19 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_adb
19-07-03 19:08:19 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_grafana
19-07-03 19:08:23 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_sonweb
19-07-03 19:09:06 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-03 19:09:06 INFO (MainThread) [hassio.addons] Phase 'application' start 5 add-ons
19-07-03 19:09:06 INFO (SyncWorker_9) [hassio.docker.interface] Clean addon_a0d7b954_thelounge application
19-07-03 19:09:07 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on esphome/esphome-hassio-amd64 with version 1.13.6
19-07-03 19:09:07 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on hassioaddons/node-red-amd64 with version v4.0.1
19-07-03 19:09:07 INFO (MainThread) [hassio.api.security] /host/info access from 15ef4d2f_esphome
19-07-03 19:09:08 INFO (SyncWorker_9) [hassio.docker.addon] Start Docker add-on hassioaddons/thelounge-amd64 with version v0.4.0
19-07-03 19:09:08 INFO (SyncWorker_0) [hassio.docker.addon] Start Docker add-on hassioaddons/log-viewer-amd64 with version v0.6.0
19-07-03 19:09:08 INFO (SyncWorker_3) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-configurator with version 3.4
19-07-03 19:09:08 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_nodered
19-07-03 19:09:09 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_logviewer
19-07-03 19:09:09 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_thelounge
19-07-03 19:09:13 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-07-03 19:09:13 INFO (MainThread) [hassio.core] Hass.io is up and running
19-07-03 19:09:25 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-03 19:09:25 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-03 19:09:25 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-07-03 19:09:25 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
