deCONZ - Official thread
so its a VNC viewer on WEB?
i roll back using snapshots with ESXI , i always create snapshot first before updating add-ons or HA versions
Clear, ok. I also do that every hour… but that is not “roll back”… if deconz stick gets upgraded thats not covered by this…
Yes, see here:
network
cool, looks good!!
@sender, indeed firmware is not covered indeed, but thats a manual process, and the stick can always be loaded in another desktop to fix things
omg, how do you guys zoom in that new webVNC? when i roll with mouse, it keeps on zooming and it never stops :slight_smile:
i tryed with + or - key , doesnt work :slight_smile:
edit: crap, my netork map is now gone, too much zooming :slight_smile
how to reset the view?
Yeah, I like it too - but the zooming is really annoying haha
Did you try to restart the addon?
great, its back, a restart add-on gives the view back, thank god!
pff, new zooming is USELESS :slight_smile: , it was bad, now is worse!! dont touch the scroll button on your mouse!! :slight_smile:
Here too…
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] firmware.sh: executing...
[17:40:02] INFO: GCFFlasher V3_13 (c) dresden elektronik ingenieurtechnik gmbh
Path             | Vendor | Product | Serial     | Type
/dev/ttyACM0     | 0x1CF1 | 0x0030  |            | ConBee II
/dev/ttyUSB0     | 0x0403 | 0x6015  |            | ConBee
/dev/ttyACM1     | 0x1CF1 | 0x0030  |            | ConBee II
[cont-init.d] firmware.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] novnc.sh: executing...
[cont-init.d] novnc.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[15:40:02] INFO: Running the deCONZ OTA updater...
[15:40:02] INFO: Starting udevd...
[15:40:02] INFO: Running the IKEA OTA updater...
[services.d] done.
[17:40:02] INFO: Websockify waiting for VNC to start
[15:40:02] INFO: Running the OSRAM LEdvance OTA updater...
[17:40:02] INFO: Waiting for device...
[17:40:06] INFO: Starting VNC server (local/no)...
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Hi just upgraded to 6.2.0 and it stops immediately. Was working fine with previous version I think 6.1
Read some posts above, you need to remove the vnc port :slight_smile:
Need to remove? Will it be repaired or is this intentionally (forever?)
I think it’s intentionally, it’s using webvnc now
Can someone tell me very clearly how to start deconz in 6.21?
20-07-28 20:40:55 INFO (SyncWorker_5) [supervisor.docker.interface] Cleanup images: [‘homeassistant/raspberrypi3-homeassistant:0.113.1’]
20-07-28 20:42:33 WARNING (MainThread) [supervisor.addons.validate] Unknown options vnc_password
20-07-28 20:42:33 ERROR (SyncWorker_2) [supervisor.docker] Can’t create container from addon_core_deconz: 404 Client Error: Not Found (“No such image: homeassistant/armhf-addon-deconz:6.2.1”)
EDIT: Used a snapshot from 5.3.6 and got deconz started. Then upgraded to 6.2.1 and everything worked.
SOLVED: Responding to self.
Used the brute force method of uninstalling deCONZ and reinstalling. Rotation gestures of the magic cube returned after that.
Updated and solved! Thanks!
How did you downgrade an add-on?
Over the last months I have got a problem where all the lights are unavailable in Home-Assistant after some reboots or power failuers. I can controll the lights from Phoscon, but not Home-Assistant. To solve it I have to delete the integration and add it once more.
Suggestions?
You mean after a full system restart where both hass and deconz are restarting?
yes that was it, thanks
