Blueprint to support the Aqara MFKZQ01LM Cube Controller thanks to @Savjee for this example.
Supported actions:
Wake
Slide
Double tap
Flip 180 degrees
Flip 90 degrees
Shake
Drop
Rotate Clockwise
Rotate Counter Clockwise
blueprint:
name: deCONZ - Aqara Magic Cube MFKZQ01LM
description: Control anything using Aqara Magic Cube
domain: automation
input:
remote:
description: Magic Cube to use
selector:
device:
integration: deconz
manufacturer: LUMI
wake:
name: Cube wake up
description: Action to run when cube wakes
default: []
selector:
action: {}
slide:
name: Slide the cube
description: Action to run on slide movement
default: []
selector:
action: {}
double_tap:
name: Double tap the cube
description: Action to run on a double tap
default: []
selector:
action: {}
flip_180:
name: Flip the cube 180 degrees
description: Action to run on a 180 flip
default: []
selector:
action: {}
flip_90:
name: Flip the cube 90 degrees
description: Action to run on a 90 flip
default: []
selector:
action: {}
shake:
name: Shake the cube
description: Action to run when the cube is shaked
default: []
selector:
action: {}
drop:
name: Drop the cube
description: Action to run when the cube is dropped
default: []
selector:
action: {}
rotate_cw:
name: Rotate cube clockwise
description: Action to run when the cube is rotated clockwise
default: []
selector:
action: {}
rotate_ccw:
name: Rotate cube counter clockwise
description: Action to run when the cube is rotated counter clockwise
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/deconz-xiaomi-aqara-mfkzq01lm-cube-controller/255988
mode: restart
max_exceeded: silent
- platform: event
event_type: deconz_event
event_data:
device_id: !input 'remote'
- variables:
event: '{{ trigger.event.data.event }}'
- choose:
- conditions:
- '{{ event == 7000 }}'
sequence: !input 'wake'
- conditions:
- '{{ event in [1000, 2000, 3000, 4000, 5000, 6000] }}'
sequence: !input 'slide'
- conditions:
- '{{ event in [1001, 2002, 3003, 4004, 5005, 6006] }}'
sequence: !input 'double_tap'
- conditions:
- '{{ event in [1006, 2005, 3004, 4003, 5002, 6001] }}'
sequence: !input 'flip_180'
- conditions:
- '{{ event in [1002, 1003, 1004, 1005, 2001, 2003, 2004, 2006, 3001, 3002, 3005,
3006, 4001, 4002, 4005, 4006, 5001, 5003, 5004, 5006, 6002, 6003, 6004, 6005] }}'
sequence: !input 'flip_90'
- conditions:
- '{{ event == 7007 }}'
sequence: !input 'shake'
- conditions:
- '{{ event == 7008 }}'
sequence: !input 'drop'
- conditions:
- '{{ event | int > 0 }}'
sequence: !input 'rotate_cw'
- conditions:
- '{{ event | int < 0 }}'
sequence: !input 'rotate_ccw'
Please note: for both the rotations and movements to work the two sensors need to have the same name. This can be checked through the deCONZ rest api
