Blueprint to support the Xiaomi Cube Controller
Thanks for inspiration
@bobchadwick for this
#wmn79 for this
Supported actions:
Actions with respect to which of the six faces are up:
- Slide
- Knock
- Flip90
- Flip180
- Rotate clockwise
- Rotate counter-clockwise
Actions without respect to which of the six faces are up:
- Drop
- Shake
Version: 1.2 - Fixed double actions by @mbacks
blueprint:
name: Aqara Magic Cube (Z2M)
description: Control anything using Aqara Magic Cube (Z2M) - V1.2
domain: automation
input:
remote:
description: Magic Cube to use
selector:
entity:
integration: mqtt
domain: sensor
slide_face_0:
name: Slide the cube with face 0 up
default: []
selector:
action: {}
doubletap_face_0:
name: Double tap the cube with face 0 up
default: []
selector:
action: {}
flipped90_face_0:
name: Flip the cube 90 degrees to face 0
default: []
selector:
action: {}
flipped180_face_0:
name: Flip the cube 180 degrees to face 0
default: []
selector:
action: {}
rotate_cw_face_0:
name: Rotate cube clockwise with face 0 up
default: []
selector:
action: {}
rotate_ccw_face_0:
name: Rotate cube counter clockwise with face 0 up
default: []
selector:
action: {}
slide_face_1:
name: Slide the cube with face 1 up
default: []
selector:
action: {}
doubletap_face_1:
name: Double tap the cube with face 1 up
default: []
selector:
action: {}
flipped90_face_1:
name: Flip the cube 90 degrees to face 1
default: []
selector:
action: {}
flipped180_face_1:
name: Flip the cube 180 degrees to face 1
default: []
selector:
action: {}
rotate_cw_face_1:
name: Rotate cube clockwise with face 1 up
default: []
selector:
action: {}
rotate_ccw_face_1:
name: Rotate cube counter clockwise with face 1 up
default: []
selector:
action: {}
slide_face_2:
name: Slide the cube with face 2 up
default: []
selector:
action: {}
doubletap_face_2:
name: Double tap the cube with face 2 up
default: []
selector:
action: {}
flipped90_face_2:
name: Flip the cube 90 degrees to face 2
default: []
selector:
action: {}
flipped180_face_2:
name: Flip the cube 180 degrees to face 2
default: []
selector:
action: {}
rotate_cw_face_2:
name: Rotate cube clockwise with face 2 up
default: []
selector:
action: {}
rotate_ccw_face_2:
name: Rotate cube counter clockwise with face 2 up
default: []
selector:
action: {}
slide_face_3:
name: Slide the cube with face 3 up
default: []
selector:
action: {}
doubletap_face_3:
name: Double tap the cube with face 3 up
default: []
selector:
action: {}
flipped90_face_3:
name: Flip the cube 90 degrees to face 3
default: []
selector:
action: {}
flipped180_face_3:
name: Flip the cube 180 degrees to face 3
default: []
selector:
action: {}
rotate_cw_face_3:
name: Rotate cube clockwise with face 3 up
default: []
selector:
action: {}
rotate_ccw_face_3:
name: Rotate cube counter clockwise with face 3 up
default: []
selector:
action: {}
slide_face_4:
name: Slide the cube with face 4 up
default: []
selector:
action: {}
doubletap_face_4:
name: Double tap the cube with face 4 up
default: []
selector:
action: {}
flipped90_face_4:
name: Flip the cube 90 degrees to face 4
default: []
selector:
action: {}
flipped180_face_4:
name: Flip the cube 180 degrees to face 4
default: []
selector:
action: {}
rotate_cw_face_4:
name: Rotate cube clockwise with face 4 up
default: []
selector:
action: {}
rotate_ccw_face_4:
name: Rotate cube counter clockwise with face 4 up
default: []
selector:
action: {}
slide_face_5:
name: Slide the cube with face 5 up
default: []
selector:
action: {}
doubletap_face_5:
name: Double tap the cube with face 5 up
default: []
selector:
action: {}
flipped90_face_5:
name: Flip the cube 90 degrees to face 5
default: []
selector:
action: {}
flipped180_face_5:
name: Flip the cube 180 degrees to face 5
default: []
selector:
action: {}
rotate_cw_face_5:
name: Rotate cube clockwise with face 5 up
default: []
selector:
action: {}
rotate_ccw_face_5:
name: Rotate cube counter clockwise with face 5 up
default: []
selector:
action: {}
shake:
name: Shake the cube
default: []
selector:
action: {}
fall:
name: Drop the cube
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/z2m-xiaomi-cube-controller/263006
mode: queued
max: 5
max_exceeded: silent
- platform: state
entity_id: !input 'remote'
condition:
- condition: and
conditions:
- condition: template
value_template: >-
{{ trigger.from_state.attributes.action != trigger.to_state.attributes.action }}
value_template: >-
{{ trigger.to_state.attributes.action in ('rotate_right', 'rotate_left', 'flip90', 'flip180', 'slide', 'tap', 'shake', 'fall') }}
- variables:
event: '{{ trigger.to_state.attributes.action }}'
sub_event: '{{ trigger.to_state.attributes.side }}'
- service: system_log.write
level: info
message: 'Blueprint Script: {{ event }} {{ sub_event }}'
- choose:
- conditions: '{{ event == "slide" }}'
sequence:
- choose:
- conditions: '{{ sub_event == 0 }}'
sequence: !input 'slide_face_0'
- conditions: '{{ sub_event == 1 }}'
sequence: !input 'slide_face_1'
- conditions: '{{ sub_event == 2 }}'
sequence: !input 'slide_face_2'
- conditions: '{{ sub_event == 3 }}'
sequence: !input 'slide_face_3'
- conditions: '{{ sub_event == 4 }}'
sequence: !input 'slide_face_4'
- conditions: '{{ sub_event == 5 }}'
sequence: !input 'slide_face_5'
- conditions: '{{ event == "tap" }}'
sequence:
- choose:
sequence: !input 'doubletap_face_0'
sequence: !input 'doubletap_face_1'
sequence: !input 'doubletap_face_2'
sequence: !input 'doubletap_face_3'
sequence: !input 'doubletap_face_4'
sequence: !input 'doubletap_face_5'
- conditions: '{{ event == "flip90" }}'
sequence:
- choose:
sequence: !input 'flipped90_face_0'
sequence: !input 'flipped90_face_1'
sequence: !input 'flipped90_face_2'
sequence: !input 'flipped90_face_3'
sequence: !input 'flipped90_face_4'
sequence: !input 'flipped90_face_5'
- conditions: '{{ event == "flip180" }}'
sequence:
- choose:
sequence: !input 'flipped180_face_0'
sequence: !input 'flipped180_face_1'
sequence: !input 'flipped180_face_2'
sequence: !input 'flipped180_face_3'
sequence: !input 'flipped180_face_4'
sequence: !input 'flipped180_face_5'
- conditions: '{{ event == "rotate_right" }}'
sequence:
- choose:
sequence: !input 'rotate_cw_face_0'
sequence: !input 'rotate_cw_face_1'
sequence: !input 'rotate_cw_face_2'
sequence: !input 'rotate_cw_face_3'
sequence: !input 'rotate_cw_face_4'
sequence: !input 'rotate_cw_face_5'
- conditions: '{{ event == "rotate_left" }}'
sequence:
- choose:
sequence: !input 'rotate_ccw_face_0'
sequence: !input 'rotate_ccw_face_1'
sequence: !input 'rotate_ccw_face_2'
sequence: !input 'rotate_ccw_face_3'
sequence: !input 'rotate_ccw_face_4'
sequence: !input 'rotate_ccw_face_5'
- conditions: '{{ event == "shake" }}'
sequence: !input 'shake'
- conditions: '{{ event == "fall" }}'
sequence: !input 'fall'
