Hi anyone knows how to fix ? After update I don’t find the denon avr entities to control.
I am also experiencing this. I have tried auto discovery and ip address to no avail.
//// some logs
Error handling request
9:25:51 AM – components/denonavr/receiver.py (ERROR) - message first occurred at December 21, 2020, 5:41:38 PM and shows up 10 times
Missing receiver information: manufacturer 'None', name 'Denon AVR', model 'None', type 'avr'
9:24:54 AM – Denon AVR Network Receivers (ERROR)
Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
9:24:54 AM – /usr/local/lib/python3.8/site-packages/denonavr/denonavr.py (ERROR)
Host 192.168.0.1 returned HTTP status code 404 to GET request at end point /goform/formMainZone_MainZoneXml.xml
9:24:54 AM – /usr/local/lib/python3.8/site-packages/denonavr/denonavr.py (ERROR) - message first occurred at 9:24:52 AM and shows up 6 times
Connection timeout when getting device information
Getting renamed and deleted sources failed.
9:24:52 AM – /usr/local/lib/python3.8/site-packages/denonavr/denonavr.py (ERROR)
No connection to /goform/AppCommand.xml end point on host 192.168.0.1
Getting the exact same error for my Marantz NR1710. Worked perfectly before upgrading to 2020.12.7. Any help in resolving this issue would be much appreciated.
Same here on HassIO
Working perfect on HassIO v118.5
Not working on last update 2020.12.7. Can’t detect AVR
Denon Model AVR-X1500H
Tried to delete and reinstall integration with no success.
2020-12-27 18:55:10 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py”, line 422, in _handle_request
resp = await self._request_handler(request)
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py”, line 499, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py”, line 118, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 18, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 72, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 127, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 129, in handle
result = await result
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 169, in post
return await super().post(request, flow_id)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 106, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 155, in async_configure
result = await self._async_handle_step(flow, cur_step[“step_id”], user_input)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 213, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File “/usr/src/homeassistant/homeassistant/components/denonavr/config_flow.py”, line 106, in async_step_user
return await self.async_step_connect()
File “/usr/src/homeassistant/homeassistant/components/denonavr/config_flow.py”, line 160, in async_step_connect
if not await connect_denonavr.async_connect_receiver():
File “/usr/src/homeassistant/homeassistant/components/denonavr/receiver.py”, line 33, in async_connect_receiver
if not await self._hass.async_add_executor_job(self.init_receiver_class):
File “/usr/local/lib/python3.8/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/denonavr/receiver.py”, line 66, in init_receiver_class
self._receiver = denonavr.DenonAVR(
File “/usr/local/lib/python3.8/site-packages/denonavr/denonavr.py”, line 344, in init
self.update()
File “/usr/local/lib/python3.8/site-packages/denonavr/denonavr.py”, line 527, in update
return bool(self._update_avr_2016())
File “/usr/local/lib/python3.8/site-packages/denonavr/denonavr.py”, line 644, in _update_avr_2016
executor.submit(self._audyssey.update())
File “/usr/local/lib/python3.8/site-packages/denonavr/audyssey.py”, line 109, in update
self.dynamiceq = bool(int(param.text))
TypeError: int() argument must be a string, a bytes-like object or a number, not ‘NoneType’
2020-12-27 18:55:11 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ping binary_sensor took longer than the scheduled update interval 0:00:05
2020-12-27 18:55:12 ERROR (MainThread) [aiohttp.server] Error handling request
self.update()
Watching this thread. Got a new Deno S750H receiver for Christmas, and can’t HA to find it.
I also have x1500r, it was working fine and then I updated to 2020.12.7 and it’s not working anymore.
I have tried to remove it and reinstall it with no luck.
the integration can find the AVR but the controls doesn’t do anything.
This is my log:
2021-01-06 19:28:08 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:28:08 ERROR (SyncWorker_3) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:28:08 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:28:08 ERROR (ThreadPoolExecutor-0_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:28:08 ERROR (ThreadPoolExecutor-1_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:28:08 ERROR (ThreadPoolExecutor-1_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:28:10 ERROR (ThreadPoolExecutor-0_0) [DenonSSDP] During DenonAVR device identification, when trying to request http://10.0.0.18:8080/description.xml the following error occurred: HTTPConnectionPool(host='10.0.0.18', port=8080): Read timed out. (read timeout=2)
2021-01-06 19:28:10 ERROR (ThreadPoolExecutor-0_0) [DenonAVR] Unable to get device information of host 10.0.0.18, can not use the serial number as identification
2021-01-06 19:28:10 ERROR (ThreadPoolExecutor-2_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:28:10 ERROR (ThreadPoolExecutor-2_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:28:10 ERROR (SyncWorker_3) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:28:31 ERROR (SyncWorker_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:28:31 ERROR (SyncWorker_0) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:28:31 ERROR (SyncWorker_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:28:31 ERROR (ThreadPoolExecutor-4_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:28:31 ERROR (ThreadPoolExecutor-4_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:28:31 ERROR (SyncWorker_0) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:28:51 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:28:51 ERROR (SyncWorker_3) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:28:51 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:28:51 ERROR (ThreadPoolExecutor-6_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:28:51 ERROR (ThreadPoolExecutor-6_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:28:51 ERROR (SyncWorker_3) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:28:51 ERROR (SyncWorker_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppMute.xml?1+MuteOn
2021-01-06 19:29:01 ERROR (SyncWorker_6) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:29:01 ERROR (SyncWorker_6) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:29:01 ERROR (SyncWorker_6) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:29:01 ERROR (ThreadPoolExecutor-8_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:29:01 ERROR (ThreadPoolExecutor-8_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:29:01 ERROR (SyncWorker_6) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:29:01 ERROR (SyncWorker_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppMute.xml?1+MuteOn
2021-01-06 19:29:11 ERROR (SyncWorker_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:29:11 ERROR (SyncWorker_1) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:29:11 ERROR (SyncWorker_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:29:11 ERROR (ThreadPoolExecutor-10_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:29:11 ERROR (ThreadPoolExecutor-10_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:29:11 ERROR (SyncWorker_1) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:29:31 ERROR (SyncWorker_7) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:29:31 ERROR (SyncWorker_7) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:29:31 ERROR (SyncWorker_7) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:29:31 ERROR (ThreadPoolExecutor-12_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:29:31 ERROR (ThreadPoolExecutor-12_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:29:31 ERROR (SyncWorker_7) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:29:31 ERROR (SyncWorker_4) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:29:41 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:29:41 ERROR (SyncWorker_3) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:29:41 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:29:41 ERROR (ThreadPoolExecutor-14_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:29:41 ERROR (ThreadPoolExecutor-14_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:29:41 ERROR (SyncWorker_3) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:30:01 ERROR (SyncWorker_2) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:30:01 ERROR (SyncWorker_2) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:30:01 ERROR (SyncWorker_2) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:30:01 ERROR (ThreadPoolExecutor-16_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:30:01 ERROR (ThreadPoolExecutor-16_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:30:01 ERROR (SyncWorker_2) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:30:21 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:30:21 ERROR (SyncWorker_3) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:30:21 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:30:21 ERROR (ThreadPoolExecutor-18_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:30:21 ERROR (ThreadPoolExecutor-18_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:30:21 ERROR (SyncWorker_3) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:30:41 ERROR (SyncWorker_5) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:30:41 ERROR (SyncWorker_5) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:30:41 ERROR (SyncWorker_5) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:30:41 ERROR (ThreadPoolExecutor-20_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:30:41 ERROR (ThreadPoolExecutor-20_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:30:41 ERROR (SyncWorker_5) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:30:41 ERROR (SyncWorker_6) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:30:51 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:30:51 ERROR (SyncWorker_3) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:30:51 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:30:51 ERROR (ThreadPoolExecutor-22_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:30:51 ERROR (ThreadPoolExecutor-22_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:30:51 ERROR (SyncWorker_3) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:30:51 ERROR (SyncWorker_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:30:51 ERROR (SyncWorker_6) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:30:51 ERROR (SyncWorker_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:31:01 ERROR (SyncWorker_4) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:31:01 ERROR (SyncWorker_4) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:31:01 ERROR (SyncWorker_4) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:31:01 ERROR (ThreadPoolExecutor-24_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:31:01 ERROR (ThreadPoolExecutor-24_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:31:01 ERROR (SyncWorker_4) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:31:01 ERROR (SyncWorker_6) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:31:01 ERROR (SyncWorker_7) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:31:01 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:31:01 ERROR (SyncWorker_2) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:31:01 ERROR (SyncWorker_5) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET command at end point /goform/formiPhoneAppPower.xml?1+PowerOn
2021-01-06 19:31:11 ERROR (SyncWorker_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:31:11 ERROR (SyncWorker_1) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:31:11 ERROR (SyncWorker_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:31:11 ERROR (ThreadPoolExecutor-26_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:31:11 ERROR (ThreadPoolExecutor-26_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:31:11 ERROR (SyncWorker_1) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:31:31 ERROR (SyncWorker_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:31:31 ERROR (SyncWorker_1) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:31:31 ERROR (SyncWorker_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:31:31 ERROR (ThreadPoolExecutor-28_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:31:31 ERROR (ThreadPoolExecutor-28_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:31:31 ERROR (SyncWorker_1) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:31:51 ERROR (SyncWorker_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:31:51 ERROR (SyncWorker_0) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:31:51 ERROR (SyncWorker_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:31:51 ERROR (ThreadPoolExecutor-30_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:31:51 ERROR (ThreadPoolExecutor-30_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:31:51 ERROR (SyncWorker_0) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:32:11 ERROR (SyncWorker_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:32:11 ERROR (SyncWorker_0) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:32:11 ERROR (SyncWorker_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:32:11 ERROR (ThreadPoolExecutor-32_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:32:11 ERROR (ThreadPoolExecutor-32_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:32:11 ERROR (SyncWorker_0) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:32:31 ERROR (SyncWorker_2) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:32:31 ERROR (SyncWorker_2) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:32:31 ERROR (SyncWorker_2) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:32:31 ERROR (ThreadPoolExecutor-34_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:32:31 ERROR (ThreadPoolExecutor-34_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:32:31 ERROR (SyncWorker_2) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:32:51 ERROR (SyncWorker_6) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:32:51 ERROR (SyncWorker_6) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:32:51 ERROR (SyncWorker_6) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:32:51 ERROR (ThreadPoolExecutor-36_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:32:51 ERROR (ThreadPoolExecutor-36_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:32:51 ERROR (SyncWorker_6) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:33:11 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:33:11 ERROR (SyncWorker_3) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:33:11 ERROR (SyncWorker_3) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:33:11 ERROR (ThreadPoolExecutor-38_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:33:11 ERROR (ThreadPoolExecutor-38_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:33:11 ERROR (SyncWorker_3) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:33:31 ERROR (SyncWorker_5) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:33:31 ERROR (SyncWorker_5) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:33:31 ERROR (SyncWorker_5) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:33:31 ERROR (ThreadPoolExecutor-40_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:33:31 ERROR (ThreadPoolExecutor-40_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:33:31 ERROR (SyncWorker_5) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
2021-01-06 19:33:51 ERROR (SyncWorker_5) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to POST command at end point /goform/AppCommand.xml
2021-01-06 19:33:51 ERROR (SyncWorker_5) [DenonAVR] Getting renamed and deleted sources failed.
2021-01-06 19:33:51 ERROR (SyncWorker_5) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:33:51 ERROR (ThreadPoolExecutor-42_0) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXmlStatus.xml
2021-01-06 19:33:51 ERROR (ThreadPoolExecutor-42_1) [DenonAVR] Host 10.0.0.18 returned HTTP status code 403 to GET request at end point /goform/formMainZone_MainZoneXml.xml
2021-01-06 19:33:51 ERROR (SyncWorker_5) [DenonAVR] Missing status information from XML of Main for: Power, InputFuncSelect, Mute, MasterVolume
I am having same issues, is this being discussed on any other thread or topic?
Thanks,
Al
I am also following this thread, however it may not be exactly the same thing: Keep losing connection with Denon AVR
solution that worked for me:
disconnect the AVR from the socket and return it after a minute
