How do I disable bluetooth in hassio? To uninstall the add-on did not really help.
There is an issue with deconzo look for the ConBee stick at /dev/ttyAMA0 that should be the bluetooth if I understod it right. So I need to deactivate bluetooth, any now know how to do it?
I havnât tried it with hass.io. My guess is that you either have to enable the debug mode (https://developers.home-assistant.io/docs/en/hassio_debugging.html) so that you can ssh into the host OS (not the HA container), or you can take out the SD card to see if it is accessible from your âPCâ. I would try the second option first.
Could you advice me, how to find config.txt in Hassio?
I have had HASS running over Raspbian up to now, so it was easy. I have changed to the latest Hass,io during the week-end and I cannot find the file on Hass.io.
Actually, I have Raspberry Pi Zero W, it has a Broadcomm Wifi/BLE chip that has a known problem of hanging up every few days (the same with Pi 3+, though they seem to be more stable to me). Disabling BLE and using an USB dongle if bluetooth is needed, fixes the problem (OK, it hangs up every few month).
Hi. I am also looking into reusing the /dev/ttyAMA0 in my default home assistant Raspberry image - to make use of the RazBerry 7 Pro (as it comes with an antenna for extended range) on a Raspberry PI 4. Is there any advice how to disable the onboard Bluetooth to free up the address for serial via GPIO?
Why does this exact conversation always seem to end here? Every thread (not only on this forum) gets to that point but the proper method for disabling onboard bluetooth for z-wave to use /dev/ttyAMA0 without disabling the potential of using a bluetooth dongle stops at a dangling question and no solution.
Is the config.txt edit the way to go about it?
-or will this prevent a dongle from functioning?
Or should we use bluetoothctl?
-if so, what is the proper command?
-how should one refer to the onboard device in the command syntax?
-will this method survive reboots and updates?
Personally I just installed Home Assistant Yellow and likewise am trying to configure a RazBerry 7 Pro (which has been tested and confirmed to work per an email response I received from the developer when I initially purchased the unit). Thereâs no /boot directory visible within the Home Assistant terminal, so Iâm presuming that if the config.txt method is the way to go, that Iâll need to make the edit on the usb flash installer drive and factory reset the Yellow to reinstall the OS.
The lack of direction and documentation on this is astounding. Can anybody please clear this up?
I had to reinstall hone assistant today due to a failing SD card. Changed it for an SSD.
To disable Bluetooth just add this line to the config.txt of the Boot partition. (RPI4)
# Disable Bluetooth
dtoverlay=disable-bt
The most easy way is to connect the storage directly with your computer.
If you are on MacOS and are using HASSIO and canât easily mount the boot partition I recommend using the SSH approach.
(I needed to do this in order to get my RaspBee 2 to work)
Yes! After hours of debugging this finally worked. I just migrated from SD to SSD and suddenly my Razberry Z-wave stopped working. Took a while before I recall you needed to disable bluetooth. I used this add-on, but had forgotten to disable safe mode.
This worked pefectly. Took a bit of time before I understood the process. Basically, follow the link https://developers.home-assistant.io/docs/operating-system/debugging/ and then come back here. The steps to go through are:
1 format a USB drive
2 generate new SSH key
3 add SSH key to the ssh-agent on your mac
4 copy file to USB drive and rename it
5 insert USB into your Raspberry Pi 4
6 use offecial SSH add on to load SSH
7 use Mac terminal to SSH into raspberry on port 22222
8 execute command
9 reboot and remove USB drive from raspberry.
10 Finished. Use as normal!
Hopefully this will help if you are lost, like I was initially.
After this, I was able to install and use the Zooz 800 Series Z-Wave Long Range GPIO Module ZAC93 LR
This worked for me!!! Thank you so much for the detailed instructions and explaining as to why SSH using port 22 does not give you access to the HOST system files which is why so many people can not find the config.txt file. Accessing SSH using port 22222 is what gives you the proper access to the HOST file system. In order to get into port 22222 you have to login in using RSA Key and the key needs to be copied to the HOST system this is the part that became clear to me after reading your instruction. Once I ran the ha os import command which copies the authorized_keys file you can using any SSH client like Putty, WinSCP, or Linux terminal. Just need to make sure your client has the same private key. Putty makes it very easy to create this connection with the private key.
