Discovered device - homekit, help required
I have some Eufy cameras but I have come to realise that Eufy cameras are not currently supported in Home Assistant. Recently seen a new integration for Homekit/Eufy security, so HA has detected this somehow. I don’t have homekit but I do have an old iphone 4s that is registered to me. Can I somehow set this up and use the homekit integration to view my cameras?
Apparently I need a homekit code.
When I try to add the camera or hub it asks me to pair with homekit - which I don’t use.
An odd thing though is whenI try to integrate my cams/hub with HA - my hub speaks to me telling me to pair with homekit, so they must be communicating somehow.
Totally confused - any help would be greatly appreciated.
Pete
We have a phillips hue hub that apparently is homekit compatible - could we use this as a bridge.
Sorry if I come across as a complete idiot, but actually I am!
Thanks in anticipation.
Pete
Not sure if you ever found what you needed, but what you’re seeing is HA pick it up as a homekit entity, as HA can function as a HomeKit Controller. Add your base, it will give you instructions, and they cameras will function as motion sensors.
From there, either set up RTSP to a server (like motionEye, or use nonsleepr’s Eufy Security integration for a cloud feed.
Thanks bacarp89 - no I didn’t get it working yet but thanks for the advice. I will try as you suggest and report back.
I’ve finally worked out how to trick Eufy Homebase to connect to HA via the built-in homekit intergration.
You require an apple device iphone/ipad and also the Eufy Security app, this will not work with the android version of the Eufy Security App.
Go in to settings or your Homebase and you should see an option for HomeKit, from there you can then enable your camera device, it will ask to connect to Home Bridge on the Eufy App which from there you can then add the Eufy devices via HA integration as it automatically detects the homekit compatible device
Hopefully the above makes sense, here is a screenshot of it in action once its fully connected.
Showing the camera feed, motion detection and battery level.
Do you need the Apple device just for once to set it up?
Could you please share the info needed in the configuration.yaml
Yes you only need it once, install the Eufy app on to a Apple device and sign in.
On the Eufy App in ‘Settings’, select HomeKit and follow the instructions - it will ask to connect Home Bridge which will put the Eufy device in to HomeKit acceptance mode.
It should be discoverable in the ‘Integration’ tab, so you should see it appear in there.
Enter the HomeKit code that is on the back of your HomeBase or Camera (if its a standalone units).
I don’t have anything in my configuration.yaml relating to the above, it should automatically be enabled in HA.
Do you loose your integration with the “eufy Apps” on your phone device by enabling HA integration through HomeKit?
No you don’t loose connection to the Eufy Security App on the phone. Also note that you will need to use the app to add new cams. If you do add new cams then you’ll need to go back and edit the homekit authentication setting in the homebase’s settings.
Hi. You say you can see the camera feed. I’m using Eufy battery cameras via the Homebase 2 and only get a snapshot of the last motion event, no live video.
Are you in the same situation or have you made it work another way?
Has anyone managed this with a HomeBase3 (S380)?
Mine doesn’t seem to have a pairing code on it although the trick above to use an Apple device to get the HomeBase to show up in HomeKit in HA worked:
I’m in contact with Eufy about getting the pairing code but they aren’t being very helpful.
Hey I know this post is old but did you ever find a solution to this. I am currently experiencing the same problem I don’t have a pairing code nor do I have an Iphone or Ipad.
Not yet, I’m still “in conversation” with Eufy about it.
Ah ok please keep me updated if you find a solution. Right now I am trying to use homekit bridge integration to scan tbe QR code directly into HA without an apple device I will let you know if I have any success.
I tried scanning the QR code on my HomeBase 3 with the camera on my Pixel 7a and absolutely nothing came up. I haven’t tried from within the HA app though so am interested to see how you get on.
Eufy have escalated the issue to their Engineering Team and I am waiting to hear back from them…
If i reset my device wil i lose al my settings in the app on my phone?
And on the bottom of my homebase 3 i have a 8 digit code
Are you able to post a photograph of the bottom of your HomeBase 3 (with MAC, serial #, etc masked) to show where the 8 digit code is, please?
Mine does not appear to have one but maybe I’m missing it. The grey text on a silver background is ruddy hard to photograph and read!
I’m having a hard time finding the pairing code, too. I’m curious to hear on eufy’s response if you get one.
Thanks guys!
The last response that I received from Eufy stated that, of the 3 devices (video doorbell, SoloCam and Floodlight E30) connected to my HomeBase, the first two would not receive HomeKit integration and the Floodlight E30 integration was being worked on.
They completely ignored my request about the pairing code for the HomeBase itself, so I have gone back to them again!
I’m tempted to submit a different request about Home Assistant integration and get them going on that path since I also have a Eufy robot vacuum.
