umrath
(Thoralf Will)
January 18, 2021, 2:28pm
1
The Tibber integration is working quite nicely. I get the data for the next 24 h - just as promised.
My problem:
How do I display this data in a card?
I would like to show a graph displaying the electricity costs for the next 24 hours. But I fail to find an option to do that.
So far, every card seems to work with historic data, without any option to choose anything else.
How is the next 24 h data received? Do you get it as the state of any sensor or even state attribute?
umrath
(Thoralf Will)
January 18, 2021, 3:45pm
3
It’s a sensor: https://www.home-assistant.io/integrations/tibber
There is a nice example for an automation on the page. But I have no idea how to display data.
If its a sensor, then you just need to check out this custom card.
umrath
(Thoralf Will)
January 18, 2021, 3:53pm
5
But how do I display future data points?
I do have the Tibber price in exactly this graph. But it shows the last 24 hours. That’s interesting - but not helpful if I want to know what happens tomorrow.
Oh i got you now. If you are using grafana addon, there is a provision for plotting forecast values. Other than that there are no ready made solution available. But if you have some experience with javascript you can edit this custom card and make it adapt to tibber sensor.
This is to forcast rain but I have heard the script is simple
umrath
(Thoralf Will)
January 18, 2021, 4:27pm
7
I was afraid to hear that.
Grafana is the simpler option but you will need to use any database addon like influx db to push data to it.
You could use this custom component:
umrath
(Thoralf Will)
April 8, 2022, 1:46pm
10
Sadly, this solution is broken now.
ghassan
(Ghassan Christensen)
January 10, 2023, 9:08pm
12
I guess my approach here solves your problem:
I had the same need to display electricity prices for the next 24 hours on a graph, And got a good, simple idea to solve that.
This is my approach:
I get the data from a rest service and save these to an array
I create a sensor to hold electricity price 24 hours from now
I have an automation that runs each hour and updates the sensor with the price 24 hours later, from the already cached values in my price arrays.
Then displaying the sensor on a normal history graph for 24 hours, will i…
umrath
(Thoralf Will)
January 11, 2023, 12:55pm
13
Well, it looks like a reasonable workaround.
(I wouldn’t call it a solution, as it really is just a workaround with quite some effort.)
Did you look up this solution: Display future values in a graph - #7 by lowlander1977 ?
I did not try it yet, but it seems to exactly do what you want. My usecase would also be to display future electricity prices, in my case from awattar
EdwardTFN
(Edward Firmo)
February 2, 2023, 7:14am
15
I have recently moved away from ApexChart and now I have my future price chart using Plotly. I’m enjoying the results so far…
There is (including versions for Tibber and NordPool):
Also looks good.
This is my first attemp, easy to configure:
Why did you move to Plotly? Since i don’t have any experience with it, what is better there? Maybe i stop investigating in apex and also use plotly.
EdwardTFN
(Edward Firmo)
February 3, 2023, 12:55pm
17
My main reason to move was the capability to easily navigate into the past data, zoom, etc…
But to be honest, I’m not using those functionalities that much… maybe just because I’m not that familiar with this yet…
lweberru
(Lukas)
March 29, 2023, 1:08pm
18
This looks really great! Can you please share the code or explain how i could get this nice graph?
Sure
This is an Apex Card: ApexCharts card - A highly customizable graph card
Readme: apexcharts-card/README.md at master · RomRider/apexcharts-card · GitHub
The Code is as follows:
type: custom:apexcharts-card
experimental:
hidden_by_default: true
graph_span: 45h
all_series_config:
stroke_width: 2
span:
start: hour
offset: '-25h'
now:
show: true
update_interval: 5min
header:
show: true
title: Strompreisprognose (€/kWh)
show_states: true
colorize_states: true
series:
- entity: sensor.awattar_full
yaxis_id: left
type: line
float_precision: 5
curve: stepline
unit: €/kWh
show:
in_header: false
extremas: true
legend_value: false
data_generator: |
return entity.attributes.data.map((record, index) => {
return [record.start_timestamp, record.marketprice /1000 * 1.20];
- entity: sensor.awattar_current
yaxis_id: left
type: line
float_precision: 5
unit: €/kWh
curve: stepline
extend_to: now
fill_raw: last
show:
hidden_by_default: false
legend_value: false
- entity: sensor.awattar_median
yaxis_id: left
type: line
curve: stepline
fill_raw: last
float_precision: 5
unit: €/kWh
show:
legend_value: false
- entity: sensor.awattar_terzil2
yaxis_id: left
type: line
curve: stepline
fill_raw: last
float_precision: 5
unit: €/kWh
show:
legend_value: false
- entity: sensor.wirkenergie
curve: stepline
type: area
opacity: 0.3
extend_to: now
show:
in_header: false
legend_value: false
yaxis_id: right
group_by:
func: delta
duration: 1h
fill: zero
yaxis:
- id: left
decimals: 2
min: 0
- id: right
opposite: true
decimals: 2
min: 0
max: 10
show: false
lweberru
(Lukas)
March 30, 2023, 12:16pm
20
notacoderjustauser:
sensor.awattar_full
Thanks, so sensor.awattar_full is somehow providing future data, right? I am using tibber. Nor sure if I can use their sensor, for this, too.
