I am sometimes accused of having too much time on my hands and this maybe a perfect example.
Anyway, @Frazzyfin, looking at your script and your chat with @wombateer got me thinking if there was a way to do what you are trying to do without having to do it for each room separately and be able to boost/cancel to achieve the Goldilocks room temp - not too hot, not too cold! .
So, below, is a link to what I have got. This will go as a recipe on the integration repo when it has been tested in the wild. It needs to have the current dev branch of the integration which has the current_schedule_temp attribute.
Edit: Found the answer, it should be true not 'true'
Iām struggling to create a switch that boost/cancel the boost in the new version of this integration. The problem is that the switch immediately turns off, even though the attribute Iām testing against is remains true.
This is my switch. Any idea what is wrong with it?
This looks really good. Iāll give it a go when I get some time this week.
Just one thing I saw while skimming through the code - in the Automation 1 condition, shouldnāt the logic be to subtract the sensor from the setpoint, not the other way round? Or perhaps Iāve misunderstood the code.
no, HACS works by linking to the github releases, so everytime we release it then becomes available. What we have been doing is creating āpre-releaseā, aka beta, releases, these also become available.
I think you could clone the repo to a local directory on your computer and then copy the files acrossā¦ Not tried this though, and HACS might get upset if you override the manifest file
I updated to 3.0.20 and copied your automation to my setup. I also use the Aqara sensors, so I hoped this would be a copy/paste job, but I get this error in the logs:
Error while executing automation automation.adjust_wiser_boost_for_ext_temp_sensor_heat_management: Error rendering data template: UndefinedError: 'dict object' has no attribute 'event'
Not sure I understand what the issue is. Any ideas?
Did you run the automation manually? It relies on a temp sensor triggering a state update to provide the event details. Just tested running actions manually and get the same error - which is expected.
Let it run and see what happens. If you look a climate device, you will see in the history where is boosts and also in its log book it shows if it has boosted due to reading from temp sensor.
EDIT: To add, I am finding that the Aqara sensors seem to not update very regularly. I understand they will only send update if temp raises by x to save battery but not yet convinced this is right. However, after running for a few days with my boost settings, it does seem to do a pretty accurate job of managing to correct temp. You may need to play around with these if yours doesnāt.
Nice, based on this Ive bought myself a Aqara sensor, and was tinkering with itā¦ I wish the wiser TRVs had a ādeltaā setting, ie i record 18c but its really 20ā¦
Yes, I was running it manually to see whether my assumption was correct regarding entity naming. Iāll let it run normally and see what happens. Thanks again!
I donāt know if it has any influence on their development, but probably as good a place as any to make further suggestions and perhaps build some public support for ideas.
since upgrading to v3 my history stats sensors for calculating how long each room has been heating for donāt seem to work accurately. This is confirmed by checking the insights in the wiser app.
If there a LTS for calculating this info, I know there is for heating demand but that is a percentage not a time value.
Hi, Iāve just set this up and it seems great so far when it works. I do have an issue though that my HA has lost connection with the hub and now canāt reconnect despite multiple tries. It this a bug or simply a matter of the signal from the hub being too weak? The hub is in the loft but I have a mesh wifi network so itās not that far to the nearest access point.
It was showing all the iTRVās upstairs as having good signal before everything stopped working and there is an AP on this floor.
It is giving this log:
Connection error trying to update from Wiser Hub 192.168.68.101. Error is HTTPConnectionPool(host=ā192.168.68.101ā, port=80): Max retries exceeded with url: /data/v2/domain/ (Caused by NewConnectionError(ā<urllib3.connection.HTTPConnection object at 0x7f0a75ef8190>: Failed to establish a new connection: [Errno 111] Connection refusedā))
22:16:58 ā (ERROR) Drayton Wiser Integration for Home Assistant (custom integration) - message first occurred at 21:58:11 and shows up 17 times
Sandy, are you sure that is the IP of your hub? Youāre unlikely to get a connection refused from a Wiser hub unless there is something wrong with it or something is blocking like a firewall or something. A connection refused means the IP is valid but it is not listening on port 80. Hence why i wonder if your IP is correct.
On checking, you are correct, the IP given in the error does not match the IP of the hub. Why would that be? I had everything working yesterday, I can see in my history when it went down but I canāt think what I changed. I have been playing with various stuff all day though
This then would point me to a dhcp issue. It seems like the ip of your hub has changed. You will need to set an allocated IP to your hub in your WiFi Ap.
