Dreo Fan Integration?
That is correct, yes.
If yours is only controllable via an IR remote, I’d suggest playing around with the BroadLink IR Blaster; it’s well supported by HA.
Likely something else. Diagnostic logs from the integration will tell you if it found devices, but just not supported.
Pulled the trigger and bought the DR-HCF002S ceiling fan. Everything is working perfect. One thing I can’t seem to find, is the RGB light. Any chance you got that working? Issue 213 on GitHub talks about this fan, everything else everyone was asking for I can see, except the RGB light ring. Not the end of the world, but still a cool feature to play with if I can.
Pretend I’m a baby and don’t know how to install this on a dedicated odroid device that runs HAOS that I access through webgui.
Pretend also that I don’t know how to get to whatever homebridge is or even know how to check if I have it installed.
I can’t find homebridge in the add-on store even with advanced settings enabled and the method where you install it on a terminal here seems like its for stuff running in docker.
Is this the same thing?:
If so, how do I add your dreo repo to it?
Edit:
I actually was shown this HACS guide for DREO integration that I must’ve somehow missed or misread before, and I have this running on my HACS add-on now. It works!
The only thing I can’t seem to get it to do is observe my temperature offsets I’ve set up in the Dreo app. Do you know how to make it do that?
Hi @JeffSteinbok - thanks for your work on this integration :+1:
Please can you confirm if the DR-HSH003S and DR-HSH004S are supported? I see mention of DR-HSH003S in the /tests dir on github, but not listed in the Tested Models in the readme.
I have DR-HSH003S here (and DR-HSH004S arriving this week) and confirm that it’s seen in HA using your integration (I have the .json log file with it included) but I don’t see how to include it on any dashboards, though I am new to HA so may be missing something obvious. Anyway, let me know if I can do anything helpful towards getting it added if it isn’t currently.
Thanks,
James
This card is awesome I would really appreciate it if you could also share the automations to make it 100% working
From time to time my ceiling fans become unresponsive. Not even the remote works then. Only solution is cutting power for a few seconds.
Strange thing is - it happens at the same exact time. I have 3 ceiling fans by Dreo, and two are the same model (521S) - always happens to both at the same time - so it must be somewhat related to either the app, or the home assistant integration (Jeff Steinbock) going rogue and causing it.
Has not yet happend on my newest 521S-RGBic (also known as 521AS or DR-HCF007S but to both my DR-HCF001S
Please open an issue at GitHub - JeffSteinbok/hass-dreo: Dreo Smart Device Integration for Home Assistant · GitHub with full logs and diagnostics.
@JeffSteinbok - fantastic card thank you - Am I being blonde or can I not add custom modes? I've set up 2 but the dreo app itself doesn't let you choose which custom mode to use when setting up schedules (:thinking:) Is that something that could be possible?? - I have 2 TurboPoly table fans
